The heads are almost sealed, the driver is just held in place by a retaining ring and there is a hole as you noted but when the light is fully assembled it is effectively sealed.
Yes, putting it in a container with some silica could indeed help.
The clicking is normal, it is just the metal expanding with the heat, this is much more noticeable on a large light like this.
If you can not see the imperfection in the beam even when held close to the wall, then it will have virtually no effect on the performance of the light. I have been surprised with even fairly large imperfections having little effect in the past.
Thanks for the beamshots… last week when I got my blf gt70 and I seem some hint of green… green tint disappears or less noticeable this week. Maybe led get break in or my eyes…
I can see green color in the corona only. And only at lower output…
Maybe because at high output I get blind and no longer see anything at all on a white wall :cowboy_hat_face:
The left spot in this pic is the de-domed GT.
Don’t be perplexed, the tint shit in the lower modes is horrendous, I can’t stand it. But from 50–100 power it is a massive change in tint. Get rid of the phosphorous around the LED and the corona is greatly reduced on a shaved dome, complete de-domed LED, barely a ring, usually a blue halo from the sides of the LED die.
Now the clean de-domed LED only measures 6,200lm, it was making 8,500-8,800 depending on what batteries I used, before I shaved it really close (meh too close I guess) and diced the pad clean, but then after a couple Turbo blast, it started to burn, so I completely de-domed it. Smoked up my reflector a bit.
Left is clearly the dedomed one in the second pic, just looks bigger in the first pic probably due to higher spot brightness.
Also very clear tint shift to warm white/yellow.
There’s a lot of lumens being lost from slicing the sides off of the phosphor, since the phosphor on the sides of the LED also gets excited.
Hi,
is it possible to be set on list for one conversion kit in NW.
Maybe NW dedomed?
Is output like in video in post #2: XHP70.2 Dedomed plus Mosfet?
Thanks a lot.
You just need to fill out the form in post #1 to get on the list.
Dedoming (technically slicing the dome off) is not a factory option. You will have to do that yourself. I think I’ve posted two videos of Vestureofblood doing it.
If your going to slice off the dome, the color becomes warmer, so it’s suggested by Texas_Ace to start with the Cool White.
Thanks, I´ve filled it out.
Warmer Tint about 4000K would be great, so If I order one 5000K, it will be good for me after slicing.
sorry for stupid question. What output modes have TA driver V2 for this light?
And will be the illuminated switch also illuminated after changing driver / LED?
Thanks a lot.
The switch light will work just the same as the stock GT.
You have the original GT light, correct? The GT70 driver will operate exactly the same. It has the same style of ramping and can also be switched to mode sets to give you low, medium and high, etc…
Guys I have a favor to ask. Can someone please test the GT70 with the 35E cells from the xhp35 version? Money is kinda short for me right now and I wanted to know if the extra 40$ for the 8x 30Q set is worth it. Already spending 55$ for the conversion kit, I really don’t wanna drop 100$ right now unless it’s absolutely necessary. I have read somewhere that the amperage per cell, using all 8 cells, would be only 5 amps. I believe the 35E is capable of delivering that without much sagging. What I wanted to know is how much output will I lose if any at all. Thanks!
Did any in the USA that ordered caps and or straps for their light receive them with their light order. I was told by email that my caps and straps would be shipped to the USA with my light order, but that did not happen. I had great communication with Leo/Lumintop prior to getting my light, but now cannot get a response concerning the accessory order. Starting to get a little concerned about ordering a NW second light as regular consumer demand ramps up.
