It’d be easier to say what’s the same. They both run on the same hardware, more or less. They both have smooth ramping with a very similar ramp interface, and they both have discrete levels… though the method for discrete levels is different. Otherwise, almost everything is different.
Same basic idea, when painted with broad strokes. But the details are all pretty different.
Want one of these just can’t manage to pull the trigger and spend more money. Just a bit more than I can justify. Damn this site and it’s temptations! :rage:
i though id give it a try and order one but the colour of the aux leds look the same as the torch from Int-outdoors. i’ll try and get a photo later when im home
Just to put it out there, white is only white when there are no shades. In my line of work, when a bride spends over $2000 for a white wedding dress it DANG SURE BETTER look white in the pictures! Never mind she stood in front of blue, green yellow and red stained glass with the sun shining through, she paid for white and it’s white she wants! No shades!
Yeah, it’s pretty rough.
I’ve got this light in my cart and know that as soon as I buy it and it ships there will be some more options. Hank is good about adding things after the launch and I am bad about waiting for them.
I keep saying “This is the last one for a while!”.
As a relative long-timer to the flashlight hobby what keeps drawing me back in is the amazing value, output, UI, and prices. We can buy for $48 something that 10x that much wouldn’t have bought 10 years ago. It’s a great time to be a flashoholic.
+The auxiliary cyan LEDs are pure awesome. They just faintly glow, and I would have them no other way.
+The size is very ergonomic. I already assumed it would be coming in, as I love the feel of 26650 tubes.
+The side switch is done just right— its surroundings are raised up for easy location, but the switch itself is recessed to prevent accidental activation. I hate switches that are hard to find (Catapult V6), but this one is easy and natural.
+The beam profile is nice— broad-ish hotspot with tint shift being minimal.
-The sharp edges along the lanyard hole stick out like a sore thumb. They prevent this from being the ultimate ergonomic light. Upon close look it doesn’t even seem to be chamfered.
- I wouldn’t say the tint is horrible, but bad—it’s noticeably green. I’m not even just comparing it to my rosy ROT66 either, I’m comparing it to my SC600 MK3 high, and more importantly, my Catapult V6 neutral white, which is also 5000k. I remember my Manker E14 (also sporting 5000k 90+ CRI 219Cs) to be greenish as well, but perhaps not as bad as this one.
-Feels light/hollow. Doesn’t have the same inspiring heft as my other lights.
No stainless steel bezel. I know it’s a budget light, but I’m going to put this on there anyways. When lights fall, then tend to hit themselves on their head. Even a tiny one as like on the Catapult V6 or Zebralight SC600 MK3 HI would suffice.
The sharp edges on that nub really rub me the wrong way, but its my only complaint about the light. The edges of the nub aren’t chamferred, and nor are the edges of the hole. It pretty much guarantees that any lanyard will be cut through before long, unless you use steel cable, and then you’ll end up sawing through the aluminum eventually.
Filing the edges is a functional fix, but I shouldn’t have had to do it. I hope he’ll have a fix down the road.
Can anyone tell me any real world differences between the xP-G2 and the XP-L HI. I was wondering what the real world differences are between the two LEDs such as output, thermal and battery run times. I have googled and read that the XP-L is more efficient above 1a but didn’t know if this was something that is real world noticiable or only paper noticeable. Thanks everyone
If we look at one led the XP-G2 only can draw around 4,5A or a little more with a DD fet driver due to higher forward voltage. At this current it puts out 1000-1100 lumens. But an XP-L or HI version can draw about 6A because lower forward voltage. And those leds put out 1500-1700 lumens so an XP-L has more output but higher current and more heat and faster draining battery.
