I don’t know what specific rule he broke, but it was obvious that he was more interested in trolling than content. He deliberately threw around insults and slipped provocative comments into his posts on a regular basis.
Ah, so venting is allowed. That makes sense. 130°C is pretty rediculous.
Yeah, 60°C is normal. They even store the cells at 60°C for a month to make sure they hold their charge.
What is interesting is the Sanyo/Panasonic data says the “polyolefin separator may get damaged” above 80°C. I wonder if this kind of separator is common among all the other brands of batteries as well. This might be considered the true temperature limit before venting. What do you think?
The “No fire, No explosion” means venting is allowed. A venting is a undramatically event to prevent explosion. But it can be dramatically if there is anything that can ignite the venting gas (Like sparks).
This is surface temperature, the inside will be warmer.
I guess it depends where the heat is coming from. If the heat is from an external source like battery tube or heater then I don’t think the interior will be warmer.
If the heat is from high discharge, then the inside will be warmer.
I’m glad your on this thrwad. I guess someone pointed you in this direction? Edit: Oh yes, post #39. I forgot.
[/quote]
If the battery powers it, the battery will get hot and this means the battery will be warmer.
The reason I use relative temperature in my battery test is because the temperature is above ambient and if the battery is inside a hot tube, the tube temperature is ambient.
I think my general conclusion is the Zanflare T1 is not a defective or dangerous device. It seems to keep the batteries within a safe operating range.
No device is 100% safe. If you use a Li-ion battery that is abused by being over discharged, over charged, dropped, etc… then it will be more susceptible to over heating and venting.
Most devices may still be able to use these abused cells because the devices heat range is limited. In the T1, the heat range is higher than most devices, so that makes it more likely to push a bad battery to its thermal limits and cause it to vent. It doesn’t mean the device is bad, it means the battery was bad.
So I guess the moral of the story is to heed all Li-ion battery precautions. If you’ve got a battery that gets really hot while being recharged at a nice safe rate or doesn’t seem to terminate charging, that battery may be damaged inside. Get rid of it in a safe manner.
Be cautious of laptop pulls or old batteries. Test them out thoroughly before using them in your devices. If it acts funny, can’t hold a charge or runs hot for unknown reasons, it’s better to get rid of it than risk it venting on you.
I had a brand new 16340 battery act funny on me a while back. It would not terminate a slow charge and it got really hot in the process. I had the manufacturer send me a replacement. Better safe than sorry.
This is my opinion on the matter. What do you guys think? Have you drawn any conclusions yet or do we need to do more testing?
I’m curious if the battery temps will exceed 60°C in a 35°C ambient environment.
I pretty much agree with you Jason. I feel like it is safe enough to use given the results you & others have posted, as well as what I have experienced using mine.
The T1 is definitely safe to use even in the brightest mode till the cell goes down in voltage, goes a notch down as the cell depletes with lower brightness until the LVP kicks in.
Tried it again today for confirmation.
Edit: I once experienced my Klarus Mi7Ti with a 14500 accidentally turn-on inside a holster (from my Eagletac D25A) and went into turbo until the holster was melting and nearly burned it. I never held a light as hot as it was, it was scalding hot.
Yet the light and the cell are still alive up to today.
Thanks to all for contributing data points to this thread.
I’m not yet prepared to rule this as “safe under all conditions” but I don’t plan to try to heat my house to 35+ C just for testing purposes. I’ll sure be keeping an eye on this as we move into summer down here.
If the cell can reach the mid 50s in a 25 deg ambient, then I think there is some cause for concern when you start adding another 10-15 on top of that. (Yes, I’ve experienced temps of 35-40C indoors on a summer night.)
Lithium ion won’t go into thermal runaway until the 115C (240ºF) range. You’re plenty safe. The temps everyone is posting is with the lantern on full brightness anyway.
Protected cells are still a viable solution. I’m not sure if the o-ring was able to be compressed using my 69mm cell. You don’t need to fully compress it unless your outside where it might get wet. I think a thicker o-ring would get compressed. Or you could double up the o-rings.
HKJ, have you ever tested the thermal limits of a protected cell to see if it kicks in at a certain temperature?
The point of this thread was that DBSAR had a battery vent in his lantern at 65°C or maybe lower. We are not sure the actual temperature. I think we all suspect that his battery, even though it seemed to work fine, was damaged internally. Maybe it was due to it’s age, or maybe it had been over discharged at some point. We don’t really know. We don’t even know why his latern got that hot to begin with.
Maybe the lantern only got up to 55°C and then the battery got so hot internally that it heated the lantern up instead of the other way around.
My country also routinely goes up to 35-40c (even 44c in some provinces during the summer months) and I don’t think the ambient temp is linear in adding to the cell in this case, but perhaps by a few degrees…can somebody more knowledgeable correct me on this?
I haven’t noticed any substantial difference even in my modded, much hotter lights in Turbo at 26c and 35c.
That’s odd, I see this data a lot in battery ads. I don’t have too many protected cells. I’ve got a Panny B 3400 from KeepPower, but I notice it doesn’t mention temperature protection, just over charge, over discharge, over current, and short-circuit.
My others are Panny GA 3500 from Evva.
It says:
Built-in Seiko IC and Three MOSFETs to protect battery from over charge, over discharge, short circuit, over temperature and low temperature.
I’ve looked at a lot of the protection circuit details on many batteries in the last couple years and it seems like most do mention over temperature protection. Obviously that’s not a standard feature across all protection circuits. I thought it was. Well, that’s a bummer.
It can potentially be dangerous as the battery temperature can be quite close the limits and a not perfect battery or a little bit more outside temperature can cross them.
Also, for our purposes, venting equals explosion as there are no safety vent-holes to T1 - or any other flashlight that I know of - to relieve the pressure (as there are on many ecigs exactly for this reason).
That is a ring inside the battery that will change to high resistance if it gets too hot, this will basically disconnect the battery. It is not used in all batteries.
This is not true. The T1 battery tube is not sealed. If pressure were to build up, it would go through the positive end of the battery tube, through the pcb and into the white plastic housing. Then the white plastic would break relieving the pressure. So it would not be any kind of pipe bomb if that’s what your thinking.
On flashlights I have seen some pictures where it vents through the driver board and then through the switch hole.
