Hi HKJ, I’m here, HydrAxx, I’m helping the vape community with lithium-ion batteries of all sizes and types of discharges, I’m testing and analyzing for myself, too. sometimes helps Mooch in terms of results, comparisons and technical documentation on different cells, I come to you to suggest the test of a cell, which I have serious doubts about the capabilities announced by the rewrapper, he This is a 20700 cell probably made by Howell, but which is not yet referenced and documented, its capacity is 3400mAh and its continuous discharge announced at 30A by Listman, in short, I give you two links: the first is the official page on the rewrapper Listman’s website and the second, a page of the FastTech site, where you can order this rewrap individually, by two or even by four.
ps: I have already asked to perform the test of this cell to Mooch, unfortunately it is currently overloaded with work pending (many cells, chargers / dischargers / analyzers, various mods mechs, etc …) so it does not I do not really have a lot of time right now, knowing that I’m the only one to have her test this cell, personally I think if my fears are not based on Listman’s cell specs, it may that it is a good alternative to the Sanyo NCR2070C (20700 / 3500mAh / 30A), that’s hoping that you accept my suggestion.
I have not answered because I had not decided yet. Sometimes it is difficult to decide and I just let them stand until I am missing cells to review, then I look back and may order something.
In your case I am missing lower capacity batteries to review and the 2800mAh fit that bill and I have ordered it.
Fenix ARB-L16-700UP - Fenix’s second 16340 with a built-in charger, supposedly a higher-discharge one.
I don’t know any EU source for it, HKJ, if you’re interested, I can look.
Hi HKJ, I would have another suggestion to make you on a cell of a format little standard, the “Zhiyun IMR 26500 3600mAh / 13.3Wh” or existing also in another version of rewrap the “EVO Gimbals IMR 26500 3600mAh / 13.3Wh ”, I would be curious to know the continuous discharge capabilities knowing that the device that uses them (the Zhiyun Crane-M for example, a stabilizer) can fired up to 6 continuous amps. Here are some pictures and links to places where you can buy them.
Cells rewrapped by Zhiyun
Cells rewrapped by EVO Gimbals
Cells with their original wraps
Extract from the technical paper Zhiyun Crane-M regarding electrical consumption and battery used.
I do not mean to sound too judgmental, but the price of these Zhiyun cells is offensive, outrageous. Totally looks like whoever has designed such device is just trying to milk the cows. Seems like the previous version of the Zhiyun used standard 18650 cells, they could have gone any other industry standard format this time, like 26650. This totally smells like I said above. If it were me, I would say some kind :| words to that people in that regard.
All depends on the site where you buy them because I only gave links for purchase as an example, it is not the best prices of the net that I chose specifically, for example look at this one: https://www.hobbygaga.com/en-2pcs-3-7v-3600mah-26500-battery-for-zhiyun-crane-m-gimbal-p274006.htm , the price of 2 batteries 26500 3600mAh is 12.89 € ie 16 $ This is not very expensive for two cells in this category.
The following are only a few suggestions, first two LiFePO4 cells for which I'd like to se how accurate are their ratings (33A continuous and up to 1800mAh in 18650 cells is interesting):
I remember having suggested the Samsung ICR18650-32A in the past here (#384) and there (#465), guess it was forgotten and/or something went wrong… :???:
How about the above LiFePO4 cells? Heter is a quality cell manufacturer, but I have seen next to no reviews of its cells.
Good question with the 32A, I have tested them long time ago, but did not publish it when I found out it was at the wrong voltage (4.2V charge, they are only about 2700mAh at the voltage).
I have some cheap LiFePO4 in queue and I may also look at your last suggestion, but 20S is not in stock.
The following is a few suggestions from a seller in AliExpress who is rewrapping some kind of chinese/korean OEM cells or whatever. Noticed the ukrainians behind the video in the thread “Testing 18650 Safety - Russian Style” were using EAIEP 26F pink wrapped cells, cells which totally look and seem to behave like some fake 25R cells I got months ago. Decent and cheap stuff:
