I have always used Paypal for the Sofirn store - where it shows payment method there should be an option âchangeâ on the right side of the screen - pick that and you should see paypal option
If you post here you should be good to go. The front page list has not been updated since you first posted. Last name on list was from 9/4. You signed up 9/5.
We are still waiting for the Amazon coupon, so no big rush. I donât even see it on Amazon US yet.
Is the Sofirm Q8 has built in reverse protection? The battery I ordered are all unprotected samsung button top. I have flat top but still works with blf Q8. Sorry if this is mentioned somewhere. Thanks
There is a diode that keeps a reverse mounted cell from ruining the driver, but in this case one cell in backwards and three in forwards will cause you a much larger issue! The 4 cells are parallel, inserting one cell backwards could well cause you to learn a new danceâŚ
All 4 cells in backwards should not hurt the driver, wonât work of course. Possibility of blowing the reverse protection diode though, in which case the driver wouldnât work until the diode was replaced.
HONDARIDER if you figure it out could you PM me please? I messaged Sofirn store and they said they take PayPal. Just wasnât very clear on how exactly to do it.
It creates a short circuit on the battery. Like taking a wire and going from the positive to the negative. The battery could get super hot and explode. Itâs the same as putting a wrench across your car battery terminals. Very, very bad.
In the Q8, the springs usually get hot in less than a second and go soft from the heat ruining the spring.
