Boaz has DC-Fix for sale as well:
This stuff is fantastic. I’ve used it on a lot of lights, and it turns the ugliest beam into a work of art.
Just bought 2 meters roll
Thanks maukka for doing the testing for us. Now, could someone make those before and after CRI test charts into a mouse-over so that the miniscule differences can be seen quickly?
Thanks for testing, Maukka.
Only 5 - 10% loss in output is better than i thought it would be.
A test with everything you could possibly want to know about using dc-fix on your flashlight
Great test! :+1:
Thanks for taking the time to do this. It’s good to have this sort of information documented.
Long term, it might be nice to have this kind of information indexed somewhere for easier access than sorting through forum threads.
Also, has anyone ever done a controlled comparison of DC-Fix vs. a matte finish tape like Scotch “Magic?” I’m curious if the DC-Fix diffuses a different amount, is more durable, sticks better, etc.
Thanks guys. I didn’t actually do anything really, just gathered the data from some of my old scattered posts.
What is 803?
Also, measurements don’t look like 5-10%
http://shop.leefiltersusa.com/Swatch-Book-Designers-Edition-SWB.htm
For heat concerns, Lee makes a Zircon line that is heat resistant:
The 802 Zircon Minus Green reduces lumens by 25, that would be closest to the 1/2 minus Green, that reduces by 28
the following percent numbers are the amount of light transmitted, so 71.5% transmission means 28.5% lumen reduction…
Lee 248 Half minus green: 71.5%
Zircon 802: 75%
Zircon 803: 79.9%
Lee 249 -Quarter minus green : 81.5%
Zircon 804: 83.6%
Zircon 805: 86.6%
Lee 279 -Eighth minus green : 87.2%
Discussed here
Examples of with and without Lee
Thanks for the explanation.
So, output is cut ~10% but intensity is cut ~30%.
Those are just examples from one light. A BLF GT will probably suffer a lot more of a reduction in intensity.
So, a floody light will lose less intensity than a thrower? Is it a logarithmic effect?
I haven’t done the math or the measurements so this is just a guess, but it might just be a function of lens size. Bigger lens = more diffusion film = more diffusion.
Just an educated guess. If you already have a somewhat diffused light (eg small heavy OP reflector or frosted optics), naturally adding more diffusion doesn’t have the same impact as diffusing a very narrow beam (large SMO reflector).
That makes perfect sense. Thanks!
Okay, here’s a thought. It would be nice if someone would test this hypothesis. Compare a small, but throwy light (such as Convoy C8), to a larger, floodier light (such as BLF Q8), both with diffusion film. I’d love to see measured results.
Doesn’t sound right. It seems to me that
Bigger lens = less light hitting any spot = just like lower mode = no effect on diffusion.
Though when pattern size is large in relation to lens size that would be different.
