If you post here you should be good to go. The front page list has not been updated since you first posted. Last name on list was from 9/4. You signed up 9/5.
We are still waiting for the Amazon coupon, so no big rush. I don’t even see it on Amazon US yet.
Is the Sofirm Q8 has built in reverse protection? The battery I ordered are all unprotected samsung button top. I have flat top but still works with blf Q8. Sorry if this is mentioned somewhere. Thanks
There is a diode that keeps a reverse mounted cell from ruining the driver, but in this case one cell in backwards and three in forwards will cause you a much larger issue! The 4 cells are parallel, inserting one cell backwards could well cause you to learn a new dance…
All 4 cells in backwards should not hurt the driver, won’t work of course. Possibility of blowing the reverse protection diode though, in which case the driver wouldn’t work until the diode was replaced.
HONDARIDER if you figure it out could you PM me please? I messaged Sofirn store and they said they take PayPal. Just wasn’t very clear on how exactly to do it.
It creates a short circuit on the battery. Like taking a wire and going from the positive to the negative. The battery could get super hot and explode. It’s the same as putting a wrench across your car battery terminals. Very, very bad.
In the Q8, the springs usually get hot in less than a second and go soft from the heat ruining the spring.
People are accustomed to putting cells in series, because so many devices work that way. So they may accidentally do the same on items where they shouldn’t. It’s not something people do on purpose.
