Sofirn Q8 group buy (gb closed, but try PM to Sofirn for discount)
1281 posts / 0 new
teacher
teacher's picture
Last seen: 2 years 3 months ago
Mikeadoo wrote:
Question out of curiosity for you all that are asking about putting one cell in backwards.
What would that do, or what are you wanting to happen? Brighter light if it doesn’t destroy the light, driver or whatever?
As TK said….. It Is a Mistake when this happens.
DO NOT DO IT ON PURPOSE!!! Wink
L4M4
L4M4's picture
Last seen: 2 min 33 sec ago
ToyKeeper wrote:
People are accustomed to putting cells in series, because so many devices work that way. So they may accidentally do the same on items where they shouldn’t. It’s not something people do on purpose.
Not on Sodacan-lights.
ALlo, I think the springs are a clear marker for the negative pole – because it’s like this everywhere.
teacher
teacher's picture
Sure it is clearly marked….. BUT MISTAKES HAPPEN.
That is why they are called mistakes…… they are not done on purpose. Thumbs Up
JasonWW
JasonWW's picture
Last seen: 10 hours 34 min ago
I remember on the original Q8 thread there were plans to have physical polarity protection around the positive brass ring consisting of two circular slightly raised pieces of plastic. This would prevent the flat negative end of the battery from touching the brass ring. For whatever reason, Thorfire scrapped that idea. Maybe now would be a good time for Sofirn to reconsider adding it. Like an add on accessory for current lights and a factory installed piece on the Q8 v1.5.
Just a thought.
djozz
djozz's picture
Last seen: 1 hour 39 min ago
Physical reversing protection is more needed on a battery carrier than with the current Q8 because with the carrier you don’t see the already inserted batteries very well, while in the Q8, before screwing the head on, you have a clear view of the 4 batteries together, a wrongly inserted one is far more obvious.
Plus, most batteries we use have the wrapper bended around the underside, for those, reversing will cause them not making contact with the brass ring. The Q8 is reverse protected for them.
Plus, as a few people experienced, upon reverse insertion, springs will collapse and contact broken before a battery is damaged.
A Q8 is not a light that I will give my sevenyearold to schoolcamp, for the rest IMO it seems to protect its users well enough.
JasonWW
JasonWW's picture
Does adding physical protection actually hurt anything? I don’t think it does.
A Sofirn engineer has already experienced this problem first hand. Scared the crap out of him. Lol.
djozz
djozz's picture
To keep the discussion clear: this happened to the engineer when filling up a battery carrier, not with the current Q8 design without carrier. And I must admit when filling up the battery carrier of the ROT66 for the first time, it felt weird to put them all 4 in the same direction, so much are we used to series-carriers.
JasonWW
JasonWW's picture
That’s right, we suggested the little white polarity protection discs that other companies use.
I think some protection rings for the Q8 could be machined from plastic or delrin or even 3D printed. The hard part seems to be getting them too stick to the driver. I think that’s why Thorfire decided to not use them. They kept coming unglued.
djozz
djozz's picture
The prototypes of the Q8 used two raised plastic rings, on both sides of the brass ring, it was indeed kind of a manufacturing head-ache for Thorfire so they asked to not use them in the production Q8 and we were ok with that because most batteries are wrapped around the edge anyway, and ultimately the springs were there as a safety backup.
Sillen
Sillen's picture
Last seen: 6 hours 47 min ago
You got a special ROT66, I only got 3 cells in mine Wink
I had an oopsie yesterday. Testing the Keeppower 6000 in my D4S then putting the 5200 back in and had it reversed, positive to the tail cap. I almost tightened all the way then when the Aux Leds didn’t come on it triggered my brain and I undid it with heart in throat. All good Smile
djozz
djozz's picture
Yes, 3 batteries Smile
The D4 had not full reverse protection, the driver protects itself but the battery drains at quite some amps (I believe it was 8A). So if noticed immediately it is no problem, but if kept like that you have a big problem. There was talk about this being improved for the D4S but I’m not sure. Easy enough to test with the tailcap off and a clamp meter (don’t have a D4S myself).
Gerrh
I would like two
AZ US
TheLumberPat
Last seen: 2 years 10 months ago
Interested. Amazon US
bulbeee
Last seen: 5 days 19 hours ago
One please. Amazon USA
Mattfox27
Interested please
RobertB
RobertB's picture
Last seen: 20 hours 6 min ago
I measured a Samsung 25r backwards in a D4. Heated the battery tube up to 115C (215ºF) in about 1 minute. Big Problem is an understatement.
guerrilla154
Out of curiosity, would it be possible to order one of these without the emitters? Could you ask Barry what the price would be in that case? I’d only be getting one to swap something else in, and I don’t want to pay for emitters I’ll never use.
Tomogchi
Last seen: 2 hours 4 min ago
In for one. Amazon us
Also 2x battery extensions! That would be awesome.. do it guys!
It all started with just one flashlight.
Boaz
Boaz's picture
Last seen: 18 hours 4 min ago
guerrilla154 wrote:
Out of curiosity, would it be possible to order one of these without the emitters? Could you ask Barry what the price would be in that case? I'd only be getting one to swap something else in, and I don't want to pay for emitters I'll never use.
 People seemed pretty exited that Sofirn was selling parts .. i looked and my first reaction was the parts weren't all that cheap and just buying a light is going to be about the same as the parts you want.
 I kind of find this to be true about most hosts etc for sale.like a s2+ host for 10$..doesn't make much sense not to just buy the whole light.
GreenLights
Last seen: 1 day 13 hours ago
Interested in one. Amazon US. Thanks.
Just discovered this wonderful addiction.
Bikenjam
Last seen: 1 year 1 week ago
Interested
Sofirn
Sofirn's picture
Last seen: 8 hours 36 min ago
In case you don’t miss the information. Sofirn Q8 is available in our aliexpress store now! Click me
Just place the order and leave a message saying your BLF ID before payment, our staff will modify the price for you, you need to refresh to find out!
Oh, one more thing, long tube for BLF Q8 will come out soon. Wink
RoloFresh
Interested
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 4 min ago
I gave someone an original SRK once. It came back a few years later with two toasted springs because someone put the cells in with alternating polarity. It should be obvious at a glance which way the cells go, given that it has all the springs on one side and a solid contact ring on the other side, but apparently that’s not enough of a hint.
klrman
klrman's picture
Last seen: 2 weeks 23 hours ago
Sofirn wrote:
In case you don't miss the information. Sofirn Q8 is available in our aliexpress store now! "Click me":https://www.aliexpress.com/item/Newest-Sofirn-Q8-4-XPL-HI-5000LM-Powerfu... Just place the order and leave a message saying your BLF ID before payment, our staff will modify the price for you, you need to refresh to find out! Oh, one more thing, long tube for BLF Q8 will come out soon. ;)
Any chance to send 4 x 30Q with the Q8?  I think it is legal to send to Canada if inside a flashlight.
JasonWW
JasonWW's picture
RoloFresh wrote:
Interested
Please follow instructions in post #1
JasonWW
JasonWW's picture
klrman wrote:
Sofirn wrote:
In case you don’t miss the information. Sofirn Q8 is available in our aliexpress store now! Click me Just place the order and leave a message saying your BLF ID before payment, our staff will modify the price for you, you need to refresh to find out! Oh, one more thing, long tube for BLF Q8 will come out soon. Wink
Any chance to send 4 × 30Q with the Q8?  I think it is legal to send to Canada if inside a flashlight.
They don’t sell 30Q. Only their own cells. They have a high drain 3000mah button top. It has gotten some good reviews. Almost the same as a 30Q in amperage. Link to the main Sofirn store.
Link to their battery store.
Tony Cape
Tony Cape's picture
Last seen: 1 week 5 days ago
Good idea I was thinking the same a set of cells would be great .
djozz
djozz's picture
I’m sure most people have found out by now, the Sofirn is for sale now at aliexpress for the discounted price, by following the instructions in the OP. For completeness I wrote an update in the OP also.
For the Amazon buyers it will take another week before the lights are there.
JasonWW
JasonWW's picture
Ah, I’ve been checking out Amazon everyday to see if it gets listed. I guess I can chill out a while. Lol
