I second that thought. The BLF Q8 5000 - by far is the best bang for the buck ($40-$49) for everyday carry, and power consumption. You will not be disappointed. I personally have 6 of them.
First off I am far from clear on exactly what has gone down with your order but my best guess is as follows:
Where are you located? I think that the shipped fee they refer to is due to your location. Some locations need an extra $20 or $40 for shipping. That would explain $20 of the extra $28 and sadly no, this is not refundable. Only the $2 overcharge on the price is refundable if you request it.
I am also guessing that the bag and cap were not included with the first order, which is why a second was needed. That would seem to mean that you need a $8 refund, not $6. So that is odd.
Finally far as them not being shipped together, sadly I can’t say I am surprised, nor can I really blame them. Having had to deal with mass orders like them many times personally, it is oh so very easy to not realize there are 2 separate orders going to the same address ad thus waste money shipping 2 separate orders.
Now the bag and cap should of been sent separately, that I can’t really explain.
I would suggest that you contact Neal, he is the one that actually sourced the bags and caps, it is possible he still has some available and he could sort it out on the back end somehow. I will contact him and give him a heads up.
We have not seen a stock CW dedomed LED yet to know what the final tint would look like, so it is impossible to say if it would be better or worse then the one from KD.
That one from KD should work ok though.
As Jason said, any A or D tint LED should work for dedoming. At least as good as we can get.
So what I mean is: Does a XHP70.2 always look exactly the same, with the same electrical requirements the same pad position, size, etc….? So I can buy any XHP70.2, and it will always fit……
I think this is the case, but I am not 100% sure….
Yes, they are all the same. You can configure to run them at 6V or 12V depending on how the PCB is configured, but the LEDs all have the same pad configuration and package size for the 70.2.
Yep, what he said. I do not know if there is a standard package name for the XHP70.2 footprint though. You could try looking for something like 7070 6v or 12v but I kinda doubt you will find anything.
Okay, I was over thinking it. It’s a simple thing. They usually go by the dimensions of the emitter base.
All 70 and 70.2 are 7mm by 7mm aka 7070.
All XML, XML2, SST-40, 50 and 50.2 are 5mm by 5mm aka 5050
All XHP35, XHP35.2, XPG, XPG2, XPG3, XPL are 3.45 by 3.45, but we call it 3.5 x 3.5 aka 3535.
Nichia 219 and 319 are actual 3535.
The new version Luxeon V are an odd duck at 4040.
So it’s just a matter of matching the package to the pads on the mcpcb.
With the 3535 they just have 2 electrical pads. They can run a 3v xpl, etc… or a 12v xhp35 because it’s 4 dies are wired in series. So you send 3v to an xpl and 12v to a xhp35.
Now the 5050 and 7070 are a bit tricky as you can run them at either 6v or 12v. This is determined by the mcpcb and it’s pad arraignment. You need the right mcpcb for your voltage needs on the 5050 and 7070.
Hopefully that’s enough info for you. We’ve talked extensively about mcpcb pads and the different types of voltage setups back in the GT thread and elsewhere. It helps to use pictures to explain that.
Kingjohn, if you want to keep a list of all the package and die sizes of the most common emitters, just take a screenshot of this LIST to keep with you. This is what I do so that I can quickly see all the details that I need.
I see they’ve added new emitters and it now has links. Cool.
The final set of emails for the neutral white GT70 and conversion kits will be going out next week. So if you want in, now is the time to sign up. The google form will be disabled when the emails go out.
At that point the only way to get in will be to PM me or Jason for the details manually.
Received the BLF GT CW this past week. Customs opened the box but everything was there and in great condition.
This is my first BLF GT - it’s much larger than I thought! Works great with some 30Q batteries. Everything is very well built and intuitive (great interface). Thank you for organizing this!
