I’ve had a similar problem in other lights and believe that the switch is not making contact internally. Sometimes a squirt on the switch itself with something like this and other times a switch replacement is needed.
Like Djozz I have bought these switches of Aliexpress.
OK, that explains that. A lot of us got ours through the M4DM4X / Neals Deals Group Pre-Buy Sale…… probably why mine at least has no sticker as you mentioned. It is a Banggood sticker most likely on yours.
You got much faster shipping than many of us here in the USA too.
Edit to add……
I really doubt it has anything to do with the manufacture date. Especially if they’re making 200 or 300 lights per week.
For instance, if it’s a defective switch, Lumintop may have bought a reel/package of 1000 switches at a time. Of that group, a few might be flaky. I don’t think there’s any way to pinpoint which lights I have a bad switch or not. I guess for right now Lumintop will just take care of it like a normal warranty issue.
(I still wish they would use seperate switches, though)
Neal responded on mail asking if sending a switch so i can replace it myself - I said sadly i have no knowledge in this i hope thats not the only solution and help for this, to me this should go under warranty a light thats barely a month old not much used and already problem isnt why i bought this light to have to replace a switch or whatever myself. And i like i said im not a modder and probably wont be as many in here are… If i would try do it myself i would probably destroy more then fix so like i said its better i not try that…
I mean my old convoy c8 works good almost 2 years old, if that would get a problem i wouldnt care so much…
I take care of my lights and i thought lumintop makes better then this . I prefer the rubber switch emisar has or olight compared to their choice.
Even if they offered a replacement driver, which is relatively easy to swap by soldering two wires, most people still couldn’t do it because the bezel is glued shut. So it definitely needs to be a warranty issue. This is the flip side to gluing your lights.
It’s got a more featured out of the box UI, looks nicer, and doesn’t feature a trashcan feature of reverse polarity protection.
It also seems to have a better, more pleasant finish, and for some people, being able to use protected cells is nice.
And, unrelated a bit, I can pay for it directly in $CA, meaning I don’t get dinged for a 2.5% US dollar conversion on it since I can buy it on Banggood.
You’ll thought the Mini GTs sat in china and took too long to get to the states—check this tracking history out—I made a purchase from IMR batteries (they’re in Houston) I’m in Baton Rouge — 1 1/2 weeks of waiting and this is what I see—— Crazy—-It might end up in China before it’s over with
September 8, 2018, 9:06 am
Arrived at USPS Regional Destination Facility
MEMPHIS TN NETWORK DISTRIBUTION CENTER
Your item arrived at our MEMPHIS TN NETWORK DISTRIBUTION CENTER destination facility on September 8, 2018 at 9:06 am. The item is currently in transit to the destination.
September 4, 2018
In Transit to Next Facility
August 31, 2018, 8:42 pm
Arrived at USPS Regional Origin Facility
DALLAS TX NETWORK DISTRIBUTION CENTER
August 31, 2018, 7:27 pm
Accepted at USPS Origin Facility
HOUSTON, TX 77036
August 30, 2018, 2:46 pm
Shipment Received, Package Acceptance Pending
HOUSTON, TX 77201
August 30, 2018, 11:19 am
