Details of the new Sofirn Q8 version can be found here.
The big difference is that it’s using xpl-hi in Cool White. A more minor change is that they’ve eliminated the flat sections on the battery tube. It’s now perfectly round.
WW is the third most popular. So for right now they’re just trying to cover the first two. Maybe they will open up some more versions if this Sofirn version does well.
I reflowed new leds on MCPCB, connected to driver (no reflector), turned on Moon as usual and one led didn´t work, so reflowed again, assembled, but leds didnt turn on at all (no reflector). I tried to double click and got direct turbo, strobe etc, disconnected tube and from this moment everytime I connect the tube with the head I get direct turbo. The switch does not react to any click.
Could someone advice what went wrong? I cleaned everything, I checked all the wires, resolder the led wires on the driver and MCPCB, checked the wires of e-switch. When I soldered wires to the driver I accidentaly put an solder on other “connection places” for led + (there are four spots), but there is no solder bridge in to the wire, so I guess there should be a problem and I cleaned most of the solder with the wick.
What type of leds did you add? It’s not too uncommon for the moon level to be too low to light up an led. Moon level has 7 adjustments. If you mean the bottom of the ramp (moon level 3), then it might not be any big deal. As long as all 4 work as soon as you give it a bit of ramp up.
After reflowing the leds a 2nd time, they didn’t work at all, or just at the very lowest level?
When a light goes to max when you connect the battery, it’s usually because of a short circuit. The positive of the battery goes straight to the mcpcb, then the mcpcb negative wire goes to the driver which controls the output. Any type of short on this negative wire will cause the leds to go full power. You might check if the reflector is shorting it.
The 4 positive led pads are all connected, you can use any of the 4. Same for the 4 negative pads.
Make sure no driver components are being shorted against the body.
I reflowed Samsung LH351D 4000K on a new MCPCB I bought on Ali (Sofirn original spare parts for Q8).
All four leds work on Turbo. I will check everything you advice in the evening.
First time (before 2th reflow) the 3 leds lighted up on Moon as expected. After 2th reflow, none of them, just a straight turbo after double click, there was no response on single click at all (only led switch turned on/off).
The e-switch is lit and react to on/off flashlight as expected.
Stupid question probably, what would happen if someone put in 4 xhp35 emitters for more throw would that work in this kind of light vs the xpl emitters?
In this case, it would just be better to swap the XPLs for XPL HIs for more throw.
You will get more lumens and more throw with XHP35HIs, but you will need a different battery configuration and a buck driver, which will cost quite a bit.
