You’ll thought the Mini GTs sat in china and took too long to get to the states—check this tracking history out—I made a purchase from IMR batteries (they’re in Houston) I’m in Baton Rouge — 1 1/2 weeks of waiting and this is what I see—— Crazy—-It might end up in China before it’s over with
September 8, 2018, 9:06 am
Arrived at USPS Regional Destination Facility
MEMPHIS TN NETWORK DISTRIBUTION CENTER
Your item arrived at our MEMPHIS TN NETWORK DISTRIBUTION CENTER destination facility on September 8, 2018 at 9:06 am. The item is currently in transit to the destination.
September 4, 2018
In Transit to Next Facility
August 31, 2018, 8:42 pm
Arrived at USPS Regional Origin Facility
DALLAS TX NETWORK DISTRIBUTION CENTER
August 31, 2018, 7:27 pm
Accepted at USPS Origin Facility
HOUSTON, TX 77036
August 30, 2018, 2:46 pm
Shipment Received, Package Acceptance Pending
HOUSTON, TX 77201
August 30, 2018, 11:19 am
Two strap wrenches, and I finally got the bezel off mine. Got all the loctite out of the threads, and the bezel comes off smooth now. Button is seemingly working fine now too.
I think the fires in California, volcanic eruptions in Hawaii, & the possibility that the Super Volcano in Yellowstone may erupt had a direct impact upon this. ………
Congrats to the Tigers on a W tonight too.
Looking forward to our 3 November meeting in ’Deaf Death Valley’
As most times, it should be a good one.
The D1S has a deeper thread at the tube to head connection. It can use the short tube of the D4 IF the user makes some adjustments. There are copper crush washers that come in handy in times like these, Kawiboy found them to work very nicely and I too have found them to be useful. Occasionally one fits without adjustment, other times some filing or sanding may be necessary. But at any rate the copper washer works as a spacer between the driver ground ring and the battery tube to allow the short tube to make contact.
Hello, this is my first post on BudgetLightForums and a week ago I got my GT Mini in the mail from Neal. I noticed that the backlight button is weirdly backlit, not like other GT Mini’s, and at some times its very unresponsive, one time I couldn’t turn the light off for 2 minutes because the button won’t do anything. I hope the button will break in with use and work normally. Here are some links to pictures of the backlight button: Image 1 Image 2 Image 3
all gt minis are backlit like that, mine looks more or less the same like yours. Its clearly that there is an issue with the buttons sadly on some lights. But if u have on a brand new light already a button thats unresponsive i dont think it will get better overtime, mine worked perfect for almost a month then suddenly one day unresponsive…
I hope they will cover us that has issues with this, its clearly something that should go under warranty and i mean 40$ i expected better quality overall…
Sometimes when I try to turn on the light it recognizes one click as two and goes straight to turbo or recognizes 3 clicks and goes to battery check mode, that is frustrating, but overall I like this light.
Yes same problem i have, the light is useless as its defective that way since its a gamble when it will turn on or off or even go turbo no matter if u click ten times not normal behaviour, send Neal a mail and ask for replacement head or something. Even if its just a few under 10 people so far out of 3-400 users its still not fun for the few of use that got the a defective light either at once or after a months use…
well so is mine, its not perfect centered the so called smiley its a bit off but not as off as his no but still….
I asked Neal if maybe a replacement head is an option to send, since that is easy just unscrew and it would probably work but if they dont want do that i have wasted 40$ on a light i will not use since its defective and warranty for a light thats 1 month old should cover normal use…
