KeepPower 26650 5200mAh Protected. I only have two. Need a second set for my Convoy L6. This is the battery Convoy recommend for the L6.
Samsung 30Q. — I’ve got plenty at the moment but I use this cell more than any other.
I would buy 4 quality protected 18650s. A couple of my lights don’t have any low voltage protection. At the moment I’m using unprotected 30Qs in just about all of them. I don’t have a specific cell in mind. I suppose a protected Samsung 30Q, 36G or NCR18650B. High capacity and moderate current would be better as none of the lights I would put a protected cell in need a high current battery.
Thanks guys for the help so far, keep it coming lol. They do already have some of the cells you are suggesting - I have now updated the OP with the ones they already stock.
from Shockli:
“14500 660mAh - currently best 14500 available, can give around 5-7A with tolerable voltage sag. Also, it is better than Sanyo UR14500P capacity-wise, if used above 2A current (according to HKJ’s comparator)
26650 5500mAh - very good high capacity cell with stable 20A continuous current.
from Keeppower:
UH2660 - same as the Shockli 26650 5500mAh within a close margin - except, this has raised positive end, which makes them a good choice for 2×26650 lights like Convoy L6 and Sofirn’s new development SP70.
from Samsung:
18650-24S (better than 20S, according to mooch’s test)
I’ll edit this post later, if I will have further suggestions.
VTC5A button and flat
VTC6 button and flat
Samsung 30Q button and flat
Aspire 1200mah 18350
A year ago those 18650’s were all readily available in the UK/Europe with button top, but now they are a b to find and Banggood always seem to cancel my 30Q orders without reason.
Some notes on the entries:
I see that 24S is better than 20S according to Mooch. OTOH 20S is better according to HKJ.
Aspire 18350 uses Yong Deli cell. So does Keepower P1835C2, though IIRC this one adds protection circuit.
ADDED
Shockli is avaliable as both flat and button top. Button top should be just as good as UH2660.
ADDED:
No, 24S is not better than 20S in Mooch test:
Thank you very much for the time you’ve all given above.
A fair majority of the cells initially suggested are already readily available on the website, but some are being requested in button top (unprotected) format which isn’t an issue, we can solve that.
I should probably state that while cells/batteries aren’t new to us, protected cells for torches/lasers are and as above, we dont have a huge understanding of the most popular ones. Goose got in touch asking for a discount code for you all, so i thought it might be worth while providing you with a code for things you might actually want to buy!
18650UK is primarily a wholesale distributor. Whilst we do have a retail website, the majority of our business/my time is taken up with sourcing, supplying for and consulting on electric vehicles, Motorsport prototyping, military/aerospace and the ebike/personal transport industry. Because of this, we have a pretty good handle on global cell movement and can normally track pretty much anything down.
Ive made a note of the cells in the list above that we dont already have and will look to get hold of them for you all as and when i can squeeze them into shipments!
Hello, I am rather skeptical about the fact that you could get any cell model, because I think of the Samsung INR18650-24S cited several times previously for example, I personally contact a number of recognized suppliers in Asia ( Vapcell, Efest, QueenBattery, Voltaplex, etc … too long is the list to be all cited) because it’s been a long time (over a year) that I try to get them with their original wraps of the brand Samsung, but even in rewrap (Vapcell Purple 18650 2400mAh 30A), and I always get the same answer in a few words: We asked for it, but we have no answer on the delays or even the quantities that will be delivered.
The only thing I’ve learned is a rumor so I do not know if you really need to take it seriously, that one or the wireless power tool manufacturers would book them all from Samsung so grab them the full production of 24S, after that is only one so I repeat: to take with reservations.
We cant guarantee to get “any cell”, but we have over the years built a well qualified list of suppliers along with the factories themselves.
The 24S wasnt designated for powertool use. Due to a strict NDA we cant specify exactly what it was made for, but its not that. Neither was the 20S, nor the rumoured 25S production run. Thats not to say that they might not end up there however. The Sony VTC5D was a Murata tweak of the VTC5A specifically for Dyson, but that hasnt stopped them popping up elsewhere…
Edit - The issue youre having is that you are contacting companies who rewrap new to market cells and sell them at an inflated cost in order to push their brand. They routinely lie about stock. Ijoy did this last year. They claimed the cell under the wrap of their 5 leg positive 20700 (the Molicel INR20700A) was impossible to get. I was sitting on 3000+. Ijoy wanted $8 per cell (before shipping and taxes) with an MOQ of 2000. I was selling the original cell from under their wrap for £5 inc VAT in the UK at the time. Largely because we have the connections, but also because these companies lie to Europe to extort huge markups on their re-wrapped versions. Don’t fall for it.
There’s a nice 3500mAh protected 18650 from EagTac / EagleTac that I like, because it can handle 10A continuous discharge before the protection trips. It’s based on the NCR18650GA and keeps the width & length down, so it fits a lot of 18650 lights.
I thought it was important to point out the 6000mAh Keeppower cell has a 28.6mm diameter. I’d hate for someone buy them without checking the fit first. I used the L6 as an example because there was already a thread on here.
Just to keep you all in the loop, ive been doing a bit of digging on what i can get immediately (IE, inside a week in decent quantities and at a cost that makes sense for us all) and i should have these on the way before the end of the day;
These are a little harder to come by but are cells i have previously supplied to other clients in the EV market. Rest assured these have been a high priority for me;
On the subject of OEM cells (Samsung/LG/Sony) since this is the bulk of my work, does anyone have any idea of the bias over flat/button top? Im happy to pull in some button top variations of the cells we stock, but im unsure of how many devices already have an over-discharge circuit etc and would use a button top option with no protection?
