The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
From post #2:
It will have all the parts you need to convert your existing BLF GT to a Giggle Monster, Including
12v drop in replacement DTP copper MCPCB
XHP70.2 LED reflowed to the mcpcb
Centering ring
12V Texas Avenger V2 driver
To install the kit you will need to be able to open your GT first (easier said then done in some cases), un-solder 2 wires and then solder 2 more wires to the new mcpcb. When soldering to the mcpcb you will need to turn your iron as hot as it will go in order to get the solder to stick, soldering to mcpcb’s can be difficult depending on the quality of your iron. Soldering is required to install this kit, you have been warned.
Notice: The GT head is VERY VERY tight, make sure you can open your light before ordering. Many people report not being to open their light without damage.
From post #4:
Neutral White is a 5000k P2 3C
Cool White is a 6500K P2 1A
  1. First we need one person to buy both, then recieve them, then to take and post pictures. So if this happens, we might see it in 2 weeks maybe?
2. Sure, you can buy whichever one you want. The CW are shipping now, NW in a week I think.
Go ahead and try. I’m not sure if they changed it. Maybe someone here can confirm if it’s a new code or the old.
Ordered NW BLF GT70, NW conversion kit, and a set of battery carriers.
MANY thanks to all of those involved especially Mr. Texas Ace for all of his time getting Lumintop to sell the conversion kits.
I hope that everyone remembers that these new battery carriers require unprotected button top cells. I modified the first couple of posts a couple days ago to reflect this new development.
The website still says protected cells are recommended, but this is incorrect.
With my BLT GT70 order, I selected the 8 batteries Lumintop had offered on the BLT GT70 order page. I'm assuming these are the correct batteries.
Just ordered a NW conversion kit yay!!! Had to pay 10$ shipping fees unfortunately. Total order 65$. The waiting begins.
Yes, they are unprotected button top Samsung 30Q.
I tried ordering nw. The discount code did not work they said i need to pay $388 so i cancelled the order .
Did you try typing it in? Sometimes copy and paste does not work. You can also try a different Web browser.
Just ordered the CW conversion kit, got my razor ready to slice dome it! thanks.
Just ordered the Cool White conversion kit as well! Leaving it as is, dome and all. Cant wait to install and test it out in one of my GT’s!
Hi,
I registered interest for 2 cell carriers, but not for the conversion kit.
With the cell carriers not being available, can I use the conversion kit GB instead?
Ok im a bit confused.
The way it looks on the order page for the conversion kit, it seems to suggest the updated battery carriers are included with the kit.
Is this true?
Or do i need to order the carriers in a separate order and THEN the kit in a separate order ?
Do a seperate order for each item. Carriers are not part of the Conversion Kits.
The cell carriers are available. Yes you can do that if you wish or get both if you wish. :+1:
Then why do it say it…?
GT70 Conversion Kits are for GT70 DIY.
1*XHP70.2 LED, Cold white or Neutral white options
1*Centering Ring
1*TA Driver Giggle Monster
2*Cell carriers
^exactly. I know originally the carriers were not included, but the order page is confusing.
:smiley: Good question. :smiley: . But I would not attempt to answer it on a bet:wink:
