Hello, I am rather skeptical about the fact that you could get any cell model, because I think of the Samsung INR18650-24S cited several times previously for example, I personally contact a number of recognized suppliers in Asia ( Vapcell, Efest, QueenBattery, Voltaplex, etc … too long is the list to be all cited) because it’s been a long time (over a year) that I try to get them with their original wraps of the brand Samsung, but even in rewrap (Vapcell Purple 18650 2400mAh 30A), and I always get the same answer in a few words: We asked for it, but we have no answer on the delays or even the quantities that will be delivered.
The only thing I’ve learned is a rumor so I do not know if you really need to take it seriously, that one or the wireless power tool manufacturers would book them all from Samsung so grab them the full production of 24S, after that is only one so I repeat: to take with reservations.
We cant guarantee to get “any cell”, but we have over the years built a well qualified list of suppliers along with the factories themselves.
The 24S wasnt designated for powertool use. Due to a strict NDA we cant specify exactly what it was made for, but its not that. Neither was the 20S, nor the rumoured 25S production run. Thats not to say that they might not end up there however. The Sony VTC5D was a Murata tweak of the VTC5A specifically for Dyson, but that hasnt stopped them popping up elsewhere…
Edit - The issue youre having is that you are contacting companies who rewrap new to market cells and sell them at an inflated cost in order to push their brand. They routinely lie about stock. Ijoy did this last year. They claimed the cell under the wrap of their 5 leg positive 20700 (the Molicel INR20700A) was impossible to get. I was sitting on 3000+. Ijoy wanted $8 per cell (before shipping and taxes) with an MOQ of 2000. I was selling the original cell from under their wrap for £5 inc VAT in the UK at the time. Largely because we have the connections, but also because these companies lie to Europe to extort huge markups on their re-wrapped versions. Don’t fall for it.
There’s a nice 3500mAh protected 18650 from EagTac / EagleTac that I like, because it can handle 10A continuous discharge before the protection trips. It’s based on the NCR18650GA and keeps the width & length down, so it fits a lot of 18650 lights.
I thought it was important to point out the 6000mAh Keeppower cell has a 28.6mm diameter. I’d hate for someone buy them without checking the fit first. I used the L6 as an example because there was already a thread on here.
Just to keep you all in the loop, ive been doing a bit of digging on what i can get immediately (IE, inside a week in decent quantities and at a cost that makes sense for us all) and i should have these on the way before the end of the day;
These are a little harder to come by but are cells i have previously supplied to other clients in the EV market. Rest assured these have been a high priority for me;
On the subject of OEM cells (Samsung/LG/Sony) since this is the bulk of my work, does anyone have any idea of the bias over flat/button top? Im happy to pull in some button top variations of the cells we stock, but im unsure of how many devices already have an over-discharge circuit etc and would use a button top option with no protection?
Many high powered flashlights will only work with button tops and/or unprotected only cells (650mm height + a couple mm for the button top). For instance BLF Q8 uses 4*18650 button top exclusively, flat tops won’t work. Many flashlights are like this and I can’t recall - but they surely exist - of any flashlight demanding only flat tops. There are many variations but many flashlights use specific combinations only (e.g. Astrolux MF02 can use only button tops - except if modded to accept flat tops by disabling the hardware reverse polarity protection - but can also accept protected ones, Astrolux MF01 will accept whatever MF02 accepts but won’t work on turbo for more than a couple of seconds with protected cells due to very high amp draw and the batteries protection circuit kicking in).
On the other hand, vaping devices are, usually, just the opposite. They need unprotected flat tops and they won’t work with even a couple of mm longer button top battery. Same goes for many powerbanks but with much less amp needs and more capacity needs.
It all depends on where a battery needs to be used.
For example, I am using 30Q button top with all my high powered flashlights, VTC6 flat top with my ecigs, NCR18650B flat top unprotected with powerbanks, NCR18650B protected button top with many low-amp flashlights.
Thanks for that, that mostly answers my querstion. We’re well versed with the vape side of things. I supply several hundred shops in the UK and the same again in Europe and coupled with our primary industry verticals, we will always have flat top unprotected cells on hand. Theres just not been much of a call for the button top variants.
Ill get them in. If i start with the HG2/VTC6/30Q, and go from there?
I think that button-top batteries choice is a lazy choice by many flashlight manufacturers, made just because:
a. they don’t go the extra mile to create software reverse polarity protection (like many ecigs have)
b. find another way (e.g. load the batteries from the tail) for the + pole to make contact in carrier-less multi-cell parallel connections instead of this:
c. can’t use software reverse polarity protection because they use a carrier that only connects with a + and a - to the driver without electronics on its own
In a few words, flashlight companies can solve that but won’t (due to extra cost I believe)
I had hoped that i would have had the button top VTC6 today too but there seems to be a bit of a delay on these. There is in fact a global shortage of VTC6 at the moment that came out of nowhere. Normally we know when a drought of something is coming but this one caught us completely off guard!
I would like to suggest another ShockLi battery (original battery model, which is rewrapped by them - is unknown):
21700 4550mAh (closer to 4000mAh during tests)
It can be regarded as similar to the LR2170SA (which is mostly known in Liitokala rewrap), but it has better discharge curve for the first half of the discharge, and runs noticeably cooler (15A discharge, at 1.5Ah, temp is 16°C above environment).
For reference LR2170SA has a bit worse discharge performance, and gets hot much faster (15A discharge, at 1.5Ah, temp above environment is ~28°C).
The Shockli 21700 4550mAh 22A / 30A is a rewrap of the new Lishen cell: LS LR2170SF, an upgraded version of the Lishen LS LR2170SA you mentioned earlier (the LitoKala rewrap: Lii-40A). This new cell does not do 4550mAh as Shockli indicates but 4400mAh according to Lishen and has a continuous discharge rate of 5C, which explains the continuous 22A write on the rewrap by Shockli because 4.4 (Ah) x 5 (.C) = 22 (A). I put a picture of the new Lishen cell with its original Wrap.
