The only difference should be the newer firmware. That should not effect the parasitic drain. It may have an added capacitor to make it more bump resistant.
Maybe someone can double check that the parasitic drain hasn’t increased. Only a couple people have them so far.
If anyone wants to check, here is how you do it.
You can temporarily deactivate the switch light by turning it on then ramp up or down and turn the light off very quickly.
YMMV, but I’ve seen meters show different values when the probes are inverted as they are in that picture. It can’t be an inverse drain, so of course the probes are on the wrong ends.
In terms of different functionality,or how functionality is implemented, firmware definitely can affect parasitic drain, I don’t know anything about the difference in this case, you are likely correct.
In this case we are talking about NarsilM v1.0 to v1.2. There are only small changes in the code. Whether it takes 6 years to drain or 11 or 2 makes no difference to most people. If your going to store the light for long periods it’s always best to turn the battery tube to cut all power.
Maybe someone will report back the drain they measure.
Maybe because it’s a direct drive light and the measured output actually varies a lot depending on batteries and a lot of other factors.
CW also tends to measure higher than NW. So maybe they’re getting very similar measurements?
You lose trust way too easy. Only a handful of people have actually received it so far so we don’t really know if there’s a problem or not. It may be a simple fix. It’s way too early to tell.
Buying in bulk from a group buy to extort the market, priceless…
Good way to end group buy pricing for the rest of us.
Not to mention using up all the available stock so we can’t get one. Limited number available, even more limited thanks to those who abuse the system. Not cool man!
Oh, I can read just fine, perhaps it’s in how you wrote it?
Regardless, Sofirn never does the spring bypass well so if you were going to resale bulk you would either have to sell em as-is or bite the bullet and do some work for your profits. It is what it is… we have come to accept compromise from Chinese vendors, will your customers learn to accept the same from you?
Still, extorting a group buy to get samples for business use is rather unscrupulous…
Just to be clear, the two Sofirn Q8’s I’m wanting from this group buy aren’t for business purposes. I’m gifting one to my father for pig hunting and the other is for a friend. If they’re good torches I’ll buy more to sell through buying directly.
Well the upside i guess is that it works fine and there’s not some fault. I may just have to drop the price and sell as they are. Hopefully Sofirn correct whatever is needed in the future as it’s an awesome looking light.
I’m sorry about not mentioning the store, just had another member give me a wake up call about this,
I am happy to buy from Alie, I looked just now through Amazon U.S. and didn’t see it but that would be the best but not a big deal.
So Alie would be great and then I can buy some other things from them while I’m there,
I think I have the purchase pause down, I’ve had to do that once before with another vendor, Simon I think…?
Sorry again for my falling asleep at the wheel, hope I didn’t miss out.
Thank You JasonWW…!!
