I installed the entire thing, but have only played around with it and not compiled any code. I cannot say what parts are necessary for flashlight purposes, though people only seem to ever talk about the “studio” part of it…
I’ve read hundreds of posts and finally successfully flashed. Here is a condensed version of the hardware and software you would need if running a Windows computer (I use Windows 10)…enjoy!
I had some trouble figuring out exactly what to buy, but I figured it out after reading all the posts for months. Just get those three things I linked below for hardware.
Please read the previous posts in this thread to learn how to wire the usbasp to the clip and how to use avrdude to flash the chips…I merely wanted to provide quick links to the three hardwares I used and the two softwares I needed.
Thanks to everyone for all the information in this thread and others!
Special holla to ToyKeeper for all of her coding magic and Hoop for all the more detailed info and links!
Hope the above info helps you start flashing UI’s…
Okay just skimmed through all of the posts. Most of it didnt stick. I have a Q8 that wants TK’s candle+lightning mode bad enough that i’m going to try. Ordered parts!
I tried a lot of things and don’t know what is wrong. I get this error message when I testing connection with this command:
avrdude -p t13 -c usbasp -n
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
If it’s tiny25, make sure to use fuse values which match tiny25 instead of tiny13. They are not the same, and bad fuse values can basically brick the MCU.
You’ll also need firmware compiled for tiny25, because the .hex files aren’t compatible from one to the other. Tiny25 code can be flashed on 45 and 85, because they’re the same family… but tiny13 and tiny25 are different families.
Thank you. It is a stock convoy C8 driver and I think I haven’t touched it so it should be tiny13. I will look at it tomorrow morning because now I’m at work. Maybe I mixed up my drivers and that answers everything.
FWIW, the repository’s bin/ directory has scripts to flash tiny13, tiny25, and tiny85. I recommend using those scripts instead of running avrdude directly, because the scripts are much less likely to brick anything.
I’d suggest using the fsm branch instead of trunk, if you want the latest code. It’s newer but not as well-tested. Otherwise though, to build everything on a Linux computer, go into the ToyKeeper/spaghetti-monster/anduril/ directory and run the ./build-all.sh script.
On a Windows computer, it might be simplest to install an Ubuntu environment and do everything from there. It’s relatively complicated getting Atmel Studio configured.
I mean, people could also install a full Linux-based OS, but that usually doesn’t go so well. For new users, the process is typically something like this:
So for a new user it’s usually best to go with a more limited version in a container or VM, which is something Windows 10 supports now.
I would like to burn the program into NANJG 105 8x7135 linear regulator driver.
I need only BECON mode 2sec on 2 sec of .
I can only find a programs that have a lots of programs but you have to switch it to mode, but I need only beacon mode.
My replacememt Q8 driver finally came in. Flashed Anduril before swapping out the old bricked one. Thank you to Hoop for the write up and Toykeeper for the firmware. The whole process was simple and easy to follow. When im not using the light i set it to the lowest brightness momemtary just in case my 2yr old son grabs it.
avrdude: error: programm enable: target doesn’t answer. 1
avrdude: initialization failed, rc=–1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
anyone have any idea what this means?
it was cheap sioc clip from amazon and by looks of it it isnt making physical connection, the pins look too short.
