Of course, you are right. That’s why I wrote to treat it roughly. The author of the question does not give specific diodes. In fact, the author of the question referred to XML and XPL which have successors. Maybe it’s better to ignore this chart.
I have a limited experience crafting with copper, and I can say it definitively started to build up around my cutting bits when chopping a 1mm copper sheet carefully under my vise attached Dremel style multitool. This for sure has to do with its malleability/plasticity with its super high thermal conductivity. I ended up managing fine results, but took careful filing:
Originally posted on Wed, 09/12/2018 - 02:41. Edited for orthography fix.
I missed the first batch, went ahead and purchased one of these from the second batch, XM-L2 T4-7A
Nice work Barkuti, looks very well done.
Just ordered one with XML2 T6-4C. 7135*8 Biscotti. OP Reflector
I will probably change the driver and maybe the emitter. I thought about ordering a host instead but wanted a light that worked out of the box.
Late to the party… Again.
The 4C with the reflector is kinda meh, but throw in a 20mm TIR lens to blend the beam, and you’ll absolutely love it.
29 days later my Copper S2+ is here. Love at first sight
The package was opened along the way, perhaps by UK customs?
The light arrived in perfect condition and in the configuration I requested. As expected it is a second edition.
Biscotti should tide me over until I get an A6 driver. I wonder if my 42W Weller is going to have trouble melting the solder on the retaining ring. It is ok with an aluminium S2.
Any suggestions? Carclo part number??
If single LED… (no Carclo suggestions for now, but Yajiamei works good)
… if you want a buttery smooth creamy beam, go with these (probably 15 deg is very good; 30, 38, 45 are definitely floody; 85 is extremely floody with almost no hotspot):
https://www.aliexpress.com/item/Free-shipping-High-quality-cree-XP-E-lenses-High-power-LED-lens-Diameter-20mm-Frosted-surface/772881051.html
… if you want less spill, and more defined hotspot (but not with the ‘artifacts’, which are present with ‘clear’ optics), go with these:
https://www.aliexpress.com/store/product/Free-shipping-plastic-cree-lens-Diameter-20mm-Bead-surface-15-degrees-High-power-LED-lens-XP/219000_772880537.html
Also, everybody should check, that whether the front lens diameter is at least 20.5mm. Recent S2+ hosts I received, had something like 20.0mm diameter, and with that, the lens gets partially slipped past the green GITD silicone ring, which then results in tilted optics when I fasten the pill.
The new batch of copper S2+ looks different from the previous but I think I like it a bit more. It weighs 170.0g without batteries. I leaving it running on max output measured around 710 lumens to see if it can sustain it indefinitely. At about 10 minutes (didn’t time it) I touched it and it is almost too hot to touch. I guess despite it has the mass, there’s not enough surface area to radiate off the accumulated heat. The lighter aluminum version would heat up much quicker though. I wish there’s a copper light with a lot of heat fins.
This is a 7A tint, which is a very nice warm white matching the copper. No ugly yellow or green in the tint.
The one in my copper S2+ is about 0.802” or 20.36mm. No issues with fit. Unlike my aluminium hosts, the retaining ring was not soldered to the head. phew!
The glass is square with the callipers. Perspective makes it appear otherwise.
Which is the nicest warm XPL HI tint to go for with this?
Also am I right in assuming the 7135*8 driver is the most powerful?
Thanks!
Have a purple S2+ host due in on Thursday, also still have a Hoop copper triple sink/pill AND have an LED4POWER 12A constant current driver, figuring to use Samsung LH351D 80 CRI 5000K emitters for a triple in this one, should be pretty nice, not 100% sure that the LED4POWER driver is the best choice on a triple though, haven’t used many of these drivers and remember that there could be some heat issues? Not sure…
Not with this S2+ kit: https://led4power.com/product/ld-a4-thermal-enhancement-kit-convoy-s2/
But,this is for stock pill, for custom pill you could do the same sandwich 0.5mm TIM + Cu/Al + 0.5mm TIM.
Thanks!
7A is the warm tint. This low CRI tint has an odd-yellow feel to it. It might complement the copper body. Not sure. I like 7A in my desert sand S2. The super warm tints are not as bright as the others.
I have XML2 T6-4C in my copper S2+. This neutral white is ok. It isn’t bad but it isn’t good either. I’m leaning towards changing the emitter or swap in an optic. (See above) I’m still deciding what to do.
7135*8 is the most powerful driver you can get from Convoy. It is 2.8Amps on high. If you want more current, the BLF A6 7135+FET driver will work. Lots of threads with information about this driver swap.
… 7135*8 is the most powerful driver you can get from Convoy. It is 2.8Amps on high. If you want more current, the BLF A6 7135+FET driver will work. Lots of threads with information about this driver swap.
There are other driver options, like the last one reviewed by Henrik per request of me which is LD-25 new version. Available at the Convoy store and at FastTech. Fully linear (PWM free) in all modes and current adjustable, which in my opinion is a lot better than any 7135 @#$%:
Cheers ^:)
Interesting. Looks like a good match for one of the high CRI emitters.
I’ve been thinking about a 3-channel driver with PWM only on moonlight. Maybe the LD-25 is better.
I’ve ordered one with an XPL Hi 4A, 7135*8 and orange peel reflector. I love my grey S2+, so I can’t wait to get this
Just received my copper S2+ yesterday.
It is from the 2nd production run.
I’ve not seen many images of it online.
Thought I’d share some pics for anyone interested.
It’s pretty!
Colour is a little more red (coppery ) in real life.
I like it!
Damn that looks nice. Can’t wait to get mine.
its a very nice Cu light… I EDC them at work… They are taking hits now but they still look sweet
