Does a mod-friendly 2xAAA penlight exist?
8 posts / 0 new
dmsoule
Last seen: 1 hour 56 min ago
My ideal penlight has a 3000K 80+CRI emitter, with max output >100 lumens, a simple UI and no strobe. Either 10440 or NiMH, doesn’t really matter. Since I haven’t been able to find that, I thought I would try an emitter swap. My first and only attempt was with the Nitecore MT06MD (perfect light except for the 5000K led), which I promptly destroyed. Turns out the driver and board are glued in place and impossible to remove, at least for me.
Any other ideas?
lumenzilla
lumenzilla's picture
Last seen: 3 hours 3 min ago
My experience with Sunwayman P02A (which is broken after 1-2 month usage) is that the pill was quite easy to extract but I find difficulty finding sub 10mm driver for this host.
dmsoule
That looks promising, thank you!
TBone
Last seen: 8 months 2 days ago
It is not exactly mod-friendly but there is a thread [!] to disassemble it: Hugsby XP-2.
The light is so cheap you can destroy a few trying.
-X3-
-X3-'s picture
Last seen: 2 hours 49 min ago
Lumintop IYP365.
Around 12 bucks on Gearbest and easily swappable LED
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
dmsoule
The Sunwayman and Hugsby could work, but with that low price on that Lumintop, I couldn’t pass it up. I just ordered two of them in case I screw something up. Thank you, everyone!
BrokeModder
I just tore apart my friend’s Duracell 60-012 daylight 2-AAA pen/work light and was surprised to see it has a nice little aluminum pill with an 11mm driver. The led leaves a little to be desired because that one stopped working but, with a quick filing or sanding to flatten the top it would fit up to a 12 mm mcpcb.
dmsoule
Nice tip, thanks!
