First, djozz, super cool to know this. Like others, I would have thought it cooler as well.
TK, not sure if you have a Rural King in your area, but I just picked up a couple boxes of âTool Shedâ brand LED bulbs rated at 4000K. Cheap brand, Iâm sure, but I surprisingly liked them so much, I picked up an extra box and replaced all my basement bulbs with them. They are âjust rightâ.
That sounds like a wonderful thing to do.
I do have a jar big enough, but how to push the button while the spectrometer is inside?, sure the moonbeams will try to escape if I keep the lid off.
The ambient light from the moonlight is so dim that you are using your rod cells, not your cone cells, hence you are not perceiving that the ambient light is in fact warmer/yellower than the ambient light under sunlight (light of the sun + light from the sky (blue)).
As others have said, Iâve always found this to be the sweet spot for CCT at night time and roughly 3B tint for daytime (about 5200K). The latter is apparently the CCT at sunrise/sunset ⌠Itâs always cool to see these preferences and âattractionsâ be correlated to things in nature.
I've heard Jon Slider talking about this too and have problems understanding people talking about using flashlights during the day ...Just makes no sense to me .If i use a flashlight in the day it's for 11 seconds to find my pen that fell behind the stereo speaker.tint isn't an issue at that point . where do people use a light in the day ?
This thread got me thinking about how the amount of moonlight (reference a full moon at latitudes < 40 degrees from the equator) compares to what we call âmoonlight modeâ (typically less than a lumen). Perhaps a different thread?
Apparently the one full moon is not the other. This time it was warmer, 3400K. The luxvalue was lower than the first recording in september last year. It is attractive to speculate that more haze in the atmosphere (the sky looked very bright though) caused more scattering (affects blue the most) and warming up the CCT. Or the moon was lower than last time (it was), so the light travels a longer distance through the atmosphere, again more scattering.
Whatever the reason, the CCT of moonlight seems pretty variable, but the CRI is invariably high. Letâs wait for a very high moon next time and see what the CCT does then.
I just saw that as an explanation for why this monthâs full moon looks more pink â it rises only to the lowest angle above the horizon.
Iâve seen some wonderful outdoor time exposures of Yosemite waterfalls made with moonlight. They make âmoonbowsâ too dim for the eye that cameras can capture.
