ThruNite T10 V2 EDC (dual chemistry AA size) Full Review
7 posts / 0 new
robo819
robo819's picture
Last seen: 1 month 4 weeks ago
This is the new ThruNite T10 V2 EDC , sent to me for review and NO other compensation other than keeping the light.
The T10 V2 can be found at the main ThruNite site…… http://www.thrunite.com/thrunite-t10-v2-tailcap-magnetic-flashlight/
Or on Amazon site………. https://www.amazon.com/dp/B07GSS9XMZ
Light will be available in the Cool White (same as the reviewed sample) or in the Neutral White versions , at the Thrunite website at least.
The T10 V2 arrived in a padded bubble envelope with the Thrunite box inside that. The outer Thrunite box houses the metal storage case for the light and contents that come with the T10 V2.The contents include the Light itself , 2 extra O-rings , clip , user manual and the Thank you card.
This is a dual chemistry light , meaning it can work from AA , NiMH , or 14500 cells.
The light is pretty compact and has a magnetic tail , so it can be used hands free when stuck to something metallic. The magnet holds pretty firmly especially on a flat surface , as demonstrated with the scissors and 26650 cell in the below GIF.
Here is the T10 V2 (left) pictured with a Thorfire TG06 s (center) and the Sofirn SP10 B (right)
The clip can be used on either end of the T10 V2 as there are grooves at either end for that, so it can be used attaching it to a ball cap or hat as a headlamp or carried head down in the pocket. There is also an Eyelet for a Lanyard if you wish to attach one to the light.
The knurling and the threads are all very well done , and the anodizing seems to be good also, as I have come to expect with the Thrunite products.
The T10 V2 uses the XP-G3 emitter (which is perfectly centered) and has a smooth reflector in it and does give a good overall beam for distance and even up close work (although not as floody as an Orange peel).
The switch is a small metallic one and looks very nice , as well as works very smoothly. The branding (etching) is also well done on both sides of the light.
The UI is pretty simple on the T10 V2 and is as follows……
A long press from OFF to get the Firefly mode (about 1 full second) from there a press of about 1/2 second to advance to Low mode and the same to advance to Medium mode from there. A quick double click gets you to the High mode and from there you can get the strobe with another double click. From any mode double click to go straight to High mode. To turn the light off from any mode a quick click is all that is needed. The T10 V2 will memorize the Low and Medium modes only and will remember which ever of those you turn the light off in.
As with many of the XP-G3 emitter lights …. The beam does have that bit of “olive” ring around the corona area when in the low mode and very slightly noticable in the Medium mode on my sample. In the High mode it pretty much disappears. I do not notice the olive colored ring in normal usage hardly at all however , but mainly notice it when white wall shining or really up close.
The GIF beamshots below will show what I am saying……All beamshots made with 14500 cell.
22 feet from White Garage door…..Low/Med/High
50 and 75 yards from Gate….. Medium and High Modes
25 Yards from Gate …..Low/Med/High
I was pleasantly surpised to see that my sample with the `14500 cell IS getting well over the listed specs (listed as 550 lumens with 14500 cell) as noted in the charts below. I got relatively close with the Eneloop pro cell.
Here are the numbers I got from my lumens testing with the NiMH (Eneloop Pro) and the 14500 (Efest Purple)
Overall the T10 V2 is a very well made light with the Thrunite quality.
The only negatives I have at all are……..
1) I personanlly dont like the XP-G3 emitter in MOST lights because of the olive colored ring that is present around the corona.
2) the clip , while made sturdy , does not sit close enough to the body of the light to hold firmly. This was brought to the attention of Thrunite and acknowledged as a potential flaw and hopefully measures are being taken for future clips.
I simply tweaked the clip on my sample to make it sit tighter to the body , so really not that big of a deal to me.
This light is listed as having an OP reflector on the Thrunite site also , but in fact does have a smooth reflector.
For those that may not want to watch the whole video , but want to see the outdoor live comparison with the T10 V2 and the Thorfire TG06 S , that starts at 10:36 of the video timeline. Just to note , I used 14500 cells in both lights for all beamshots and the live footage.
Video followed by listed specs…………
Product Description
The T10 V2 tailcap-magnetic flashlight is the upgraded version of T10. It adopts the latest CREE XP-G3 LED to make output up to 550 lumens when it is driven by one 750mAh 14500 battery, or 180 lumens when it is driven by one 2450mAh AA battery.
Features and Specifications
•Cree XP-G3 LED with a lifespan of 20+ years of run time.
•Uses one 2450mAh AA battery or one 750mAh 14500 battery(not included).
•Max output: 180 lumens with 2450mAh AA battery OR 550 lumens with 750mAh 14500 battery.
•Working voltage: 0.9V-4.2V.
•Output & Runtime (Tested with 1*2450mAh AA Battery):
◦Firefly (0.5 lumens /49 days)
◦Low (5 lumens /2.1 days)
◦Medium (35 lumens /8 hours)
◦High (180 lumens /95 mins)
◦Strobe (180 lumens /200 mins)
•Peak beam intensity: 1035cd.
•Max beam distance: 64 meters.
•Waterproof: IPX-8 (2M).
•Impact resistance: 1.5 meters.
•Size: 87mm (Length) x 19mm (Diameter).
•Weight: only 40g (without battery).
•Accessories: Spare O-ring x 1, Pocket Clip x 1.
•Compact design fits comfortably in your pocket, backpack, or anywhere else you keep your light.
•Magnetic tailcap free your hands. Be perfect for any hands free mechanic work.
•Reverse polarity protection design to protect from improper battery installation.
•Aircraft-grade aluminum body with premium type III hard-anodized anti-abrasive finish.
•Toughened ultra-clear glass lens with anti-reflective coating.
•OP reflector gives perfect flood.
•Removable pocket clip for easy to use.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 09/24/2018 - 11:11
zak.wilson
Last seen: 1 week 2 days ago
Solid review. The one thing I’d like to see added is runtime graphs. Does it last as long as claimed? Are there stepdowns? Is output stable?
Ceilingbounce – flashlight testing and runtime graphs for Android
robo819
robo819's picture
Thanks zak…..
Sorry I haven’t done the run time testing on this light yet.
I usually do that and amperage testing with most of my reviews , but lately between time constraints and my back giving me a lot of problems from the severe arthritis I have in my spine , I just have not been able to do the run time testing.
-X3-
-X3-'s picture
Last seen: 16 hours 57 min ago
Thank you for that great review.
My personal opinion is based on my use of the precedent version…
I’ve EDCed a 2017 version for a whole year and it was near perfect. The tail switch is IMHO the more practical and fastest type of switch. The 3 modes with memory are perfectly spaced and I mostly use the moon and high. The clip is far from perfect, and I prefer the screwed-on one of the 2014 version.
This new “V2” version is not a T10 IMHO. It’s a shame that Thrunite changed the switch type, and used an XP-G3.
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Jack Kellar
Jack Kellar's picture
Last seen: 1 day 3 hours ago
Nice review, robo, thanks for sharing.
So, Thrunite has moved on from the “AA with tailcap switch” format? Pity, because their v1 design for the T10 works super nicely – one button, reverse clicky, 3 modes ramping up, no muss no fuss. Still, if they’re offering a NW option, I’m more interested in it than in the AA Olight Batons and their insistence on CW.
robo819
robo819's picture
Glad to do the review guys and thanks.
I don’t have the original T10 to compare the T10 V2 with , but I would agree a little better clip and a different emitter would help the new one.
I will just have to trust your opinions on the other things that were mentioned up there. Wink
zak.wilson
I’d have called this the Neutron 1A if I were Thrunite… and I would have kept the Neutron (and TH20) ramping UI. Also, not an XP-G3. There are so many good emitters to chose from these days, and that isn’t one of them.
I’m of the opinion that flashlight companies, even given all the ingredients to get things just about perfect within their existing parts bin will, more often than not, find a way to screw it up.
