Astrolux MF03 - new pictures + video
Try a search with Mateminco MT35 ( = Astrolux MF02) and Mateminco MT70 ( = Astrolux MF04).
No, thats not right:
MT35 = MF02
MT70 = MF02S
MT35 Plus = MF04
MT70 Plus = MF04S
Ten month after this thread was started, what’s the status for this light project?
Think the light was planned to take the lead in the lumens war but Imalent and Acebeam are dropping nukes.
my initial design was accepted to be built even before the mf02...
well problem is u cant take forever because clearly competitors during that time present their monsters haha….
R90C and MS12 are too strong in spec. MF03 can still win over price if price is right. Are they still working on this MF03?
Just forget it… make 21700 carrier that fit 8 cells, and put as many as xhp70.2 you can fit in the mf03… call it done.
For a good buck driver, Lexel was recommending 10 x 18650 to get 21 volts. It’s about the same diameter as the other options.
4 x 18650 can fit in a 44mm circle.
5 x 18650 needs a 49mm circle.
4 x 20700 needs a 49mm circle.
4 x 21700 needs a 51mm circle.
I think the one bonus feature of the MF03 that made it stand out was the added throw from the single xhp35-HI in the middle.
For the MF03 to compete, they may need to enlarge the head diameter to fit more 70.2 (from 7 to maybe 9 or 10) then maybe a bigger reflector for the xhp35-HI.
There are also TIR lenses that fit 70.2. I wonder if they would boost throw by narrowing the spill and improving efficiency. It could set this light more apart from others.
The 44mm is ideal case. Many 4x18650 flashlight has about 50mm battery tube, BLF GT is largest at 55mm.
Ya, that is the nice feature of MF03 with middle XHP35 HI. Someone has to talk to Imalent to put a XHP35 HI or XPL HI for the center LED of MS12, it may hit 250kcd but slightly lower max lumens. Or just factory dedome the center XHP 70 led, it should help. I was thinking can they dedome all the LED.
Martin, do you have news about the MF03 ?
i wish i had :(
at least the project is not dead afaik
any news or? i guess they scrapped this one ?
i just know they still try to build it ;)
I’m patient… :wink:
RIP?
Makes no difference. Subscribe to the thread if you want. We will either see updates or not.
BTW, the original poster said this just 10 days ago in case you missed it:
Just when I think “I will not buy any more flashlights” :person_facepalming:
Lol idoubt you’ll have to worry about this at least till 2020 :frowning:
