I’m no cool white expert but the tint is fairly even across most of the beam and not much blue or green. I didn’t plan on keeping them but they arent so bad it turns out.
Will probably keep them until the longer tube is released. Wish more of Cree’s stuff was like the XP-L HI
I got 120kcd as well. The easiest way for me is to measure out 10 meters exactly (plus an inch for the lux meter) against a wall. Then I mark the point where the led goes (10 meters plus one inch). I set the lights led at this mark and turn on turbo. I walk to the wall and move my lux meter up and down to find the brightest spot, then left and right to again find the brightest spot. Then double check that area just to make sure that’s the brightest. This usually takes 30 seconds which is about the right time to take the measurement.
You can turn the light on at a lower level and find the general brightest section of the beam before going to turbo. This way you know the general area to look at.
On my light, I used button top 30Q from Banggood. Cleaned the contacts with a paper towel.
Texas_Ace Lumen Tube calibrated with Maukka’s S2+.
I may go to the local hardware store tomorrow and see if they have brass screws the right size. They have a nice selection.
I checked the bump resistance by slamming the base of the light as hard as I could into my palm. No effect.
I could have sworn I saw a driver picture with an extra capacitor added somewhere on it. I took a close look at my driver and I don’t see anything unusual except for a double stack of capacitors on C2.
According to FlashyMike an extra cap here can help, but he added one a lot larger than on the factory Sofirn driver. Maybe this smaller cap is sufficient?
Not all items are available for 2 day shipping. What amazon does is not guarantee 2 day delivery, but 2 day shipping. So once it actually ships then it will be 2 days to get to you.
That might help a little. It helps me a lot. A bunch of my orders sometimes don’t make it to the $25 to qualify for free shipping. Plus I watch a lot of Prime Video.
I will never use xpl2 or xpg2/3 again. Lh351 and luxeon v serve a flood role way better. Sst20/40 over xpg anything too. 50.2 is just OK. 70.2 is in a league of its own depending on the host. Im sure I’ll like xhp35 but wont use it till a better boost comes out.
Amazon will easily credit you a month of Prime if they miss their guarantee (just do an online chat). However, what toddcshoe said still applies. The lights were posted for sale but not ready to ship yet and it said as much on the sale page.
Yeah, so Sofirn sent me a code anyway, and I couldn’t resist. It’ll be here Thursday, though I could have picked it up at an Amazon locker on Wednesday, if I’d wanted to, but not any of the ones closest to my house…
Do you mean they are protected and rated at 10A max?
Or do you mean 10A continous?
They will work fine. They won’t give max output like a high drain, but still work fine. You might get 500 less lumen compared to button top 30Q, but to your eye it will be hard to see a difference.
I assure you it did say that when I ordered on Friday. Clearly something is delaying your order but they were not immediately available to ship when the first orders came in so take that however you want. Just open up a chat like I said: https://www.amazon.com/gp/help/customer/contact-us/
I chatted w/AZ and they just repeated that my Q8 would arrive on Friday
No explanation, no reason for others ordering days later and having already received the light
Thanks for listening. I feel better now.
mine has arrived today. Quite fast compared to other Aliexpress orders. Everything seems to work correctly in the flashlight. very happy to have bought it.
