Certainly not
To me it’s beautiful.
The outside is about beauty, the inside is about function. Both are outstanding (but who am I to judge).
I’m just giving him a hard time because of how refined all of his finished products look. However, if you look at hot rod car types or some other hobbies I assure you the inside is not always all about “function” to some
I stuck a Samsung LH351D in a Zebralight SC64c.
I’m jealeaus!
I bet THAT was fun Bob! Nice work!
Today my Uv LED arrived (and a few really nice leds are on its way to me) so i wanted to work out a way to solder the LEDs to the MCPCB (My selfmade hotplate with modded PC Powersupply was damaged because of a broken waterpipe that flooded my workbench a few month back). But i had a few spare heating elements, my old Aluminium Block (i grinded it out of a Amplifier Cooler) and i could revive the temp controller. Using a car battery for the ~10Amps draw and my vise to hold it in place. The right side is cold enough to touch when the left side is above 200°C. Worked like a charm Temp set to 198°C (overshoot to only 203°C with hysterese set to 5°C) . Now i should get a new Powersupply and some kind of case to make it nice.
That’s awesome Docc! Really good work on improvisation, you’re all set to go into the re-flow business now!
Grinded down the zwb2 filter and removed most of the rough machining marks (where the MCPCB is placed).
Today i reflow the UV led and then i have to wait for the driver.
TOD’s hittin’ the mods fast & hard :+1:
Nice work Docc! Really cool what you can do with the glass lenses, neat set up for sure!
Changed my D25c (again) to a sst-20 4000k and A6 fet driver. Pretty decent throw for the size of the light.
Putted Luxeon V in a GT mini. measurements coming in the morning. I hope it is around 9A and 2000 lumens.
Start with this:
2226 lumens GT mini
This is a Lumintop GT mini with Andúril firmware and a Luxeon V 4000K led on led4power DTP MCPCB.
GT mini driver:
Needed to grind the New MCPCB because wire holes didn’t match up.
Filed the 3535 centering ring to fit 4040 led
Left is a stock CW GT mini, and right is the Luxeon V GT mini
No picture but I bypassed the driver spring with a 22 AWG wire. Finally it draws 10,4A and puts out 2226 lumens.
Getting ready to reflow some new emitters for my Nichia D4S. Still on the fence about whether to do SST-20 4000K or LH351D (all 90+ CRI). I’m leaning towards the SST-20, but I have two empty MCPCBs so I might give both a try.
In the meantime, I made up a solder paste gerber and cut a stencil to use so I don’t have to fuss with “bonking” the emitters to try and eject excess solder. I’ve posted the gerber, along with a little info about how I cut the stencil on my blog.
Modding my Armytek Tiara A1 light with Samsung LH351D 5000k 90CRI:
cracked the glass then flick the bezel with flat screw driver then the rest pop out nicely. The lens is exactly the same as convoy S2+ (20mm purchase link )
Stock led is XML and it’s different footprint to Samsung LH351D 5000k 90CRI so i use 3535 footprint on14mm MCPB and it fit nicely and screw down perfect.
original parts
Kaaaaching
close up
Will post beam shot tomorrow when i have time. The tint is much more better but on max it is a little less bright compare to XML.
Moding Armytek is abit more friendlier compare to Zebralight.
Nice done Nicolicous. Was thinking of using the LH351D in H03 but i changed to Lexel FET driver. Would drive the led crispy. Where did you get the small MCPCB (is it copper)?
several of us have put LH351D into Q8’s so I don’t think it would be a problem to use it with a FET driver and a moderate to high discharge battery.
