Opened up the driver bay and they have what appears to be 18ga leads on it already. I swapped the FET for the Infineon FET from my BLF GT mini, to gain only 48.3 lumens. At any rate, I now see 6379.05 lumens at start with fresh charged 30Qs.
Wow! You guys and gal summed it quite clearly. Thank you. I meant to relay the experience so I cut out some details.
I have a Miboxer C4 and of the four (out of 6 button tops I have), they are all under 20 cycles with 36 mOhms for the 25R, ~70 for the 35E and ~100 for Nu 188.
I bought those 30q Ali fakes for a multi- batt light but not button top. Solder blobbing came to mind. Just didn't have time.
As far as series V'S parallel, I'm wary about series but I've been using a 3C light with two 18650s in parallel. New batteries, old pack pulls, etc. w/o problem but I monitor SOC regularly.
I prefer 30q but since I have two 35Es already, I'll probably just buy two more. I'll derive more current via brass screws and spring bypasses.
I read as much on best practices as I can and y'all's posts certainly are part of that curriculum. Thank you!
Maybe, maybe not. I say remarkable because I use the XP-L HI V3ās almost exclusively in most of my 3v builds, it is my favorite, go to Cree emitter, I especially like the V3-1A. I have also seen them vary quite a bit in output, Dale might have got some high end freaks, like in my D4S V3-1A it will do 6300+ on a 30T off the charger and 5800-5820 on a Golisi off the charger repeatably every time and that is with only a thin copper driver contact and copper braid bypassed tail spring, never touched/opened the head on the D4S. I think the new Noctigon Quad board has a lot to do with it also. I have had some V3ās pull over 7-7.25 amps (shocked the hell out of me) for 1780-1800lms naturally at turn on. And I have yet to burn one out, like some have claimed?
It now makes 8659.5 lumens. a gain of 2280.45 lumens over the last iteration and 2884.2 lumens more than when it came out of the box a few hours ago. Sorry it took me so long, had to eat lunch and take care of some other bidness.
Sure Kawi, as youāre aware they only ran less than a minute while I tested the few stages of build.
PM me your addy, was there anything else I was supposed to be sending that Iāve forgotten? Some Samsung LH351D 5000K 80 CRI or something? Got a couple of Oslon Black Flats you can play with too if you wantā¦
Edit: Just cracked it back open and checked, no wires pinched and all wires still solidly soldered. No side switch light. Not that it really matters, Iād turn it off if it was on, but itās odd that it quit working.
Thatās weird. At first I figured I must have broken something, but thatās the same file I just put on mine and it runs normally.
I wonder if the driver design was changed at some point, or if a wire may have come off. If you plug in the usbasp and clip it onto the MCU, but donāt flash it, does the switch light come on? On mine, it does.
Odd, I had 3 5700K XP-L2ās in a sealed tape with the order label accompanying them, and 2 5000K XP-L2ās in a sealed tape with their original order label accompanying them, separted in my emitter kit and clearly labeled. I put the two 5000Kās on first, opposing each other on the board, then I placed the 5700Kās on the remaining opposing pads. Re-flowed it, assembled the light.
So now, checking with a UV light, it doesnāt look like what I know it isā¦
