Itās tempting, especially after reading through the 5K or so posts in this thread and seeing that many users are successfully modifying their code. But it would be a first effort for me, and Iām reluctant to risk one of my favorite toys in a learning exercise. And I remember someone (was it you?) may have mentioned that certain missteps result in an inoperable and unrecoverable (without special hardware) brick.
The D4S seems to be slightly more mod-friendly, and Iām already tempted to buy one of those. And I seem to remember reading someoneās (you again?) notion that maybe a beginnerās hardware/software programming kit could be offered as a turnkey āget startedā package. Iām more likely to get my feet wet that way, then look at the D4 after gaining some confidence.
I havenāt managed to get any stores to carry a starter kit yet, but I still hope that can happen sometime. One of the main steps right now is finding a way to manufacture Lexelās flashing key, and getting more brands to use it on their drivers.
However, itād also be nice to have a kit based on a more common chip clip. (SOIC8 clip)
Iāve read hundreds of posts and finally successfully flashed. Here is a condensed version of the hardware and software you would need if running a Windows computer (I use Windows 10)ā¦enjoy!
I had some trouble figuring out exactly what to buy, but I figured it out after reading all the posts for months. Just get those three things I linked below for hardware.
I bought this: https://www.amazon.com/gp/product/B00AX4WQ00/ref=oh_aui_detailpage_o02_sā¦
and these:
yaā¦cheaper from chinaā¦but not by much, and I prefer Amazon reliable quick ship. Not worth saving 3 or 4$ ordering from china and waiting a month.
Windows programs:
uspasp driver:
here is the driver and manual for the chip programmerā¦read page 7 for install
scroll down for the driver download and manual pdf
If you plan to do this for the first time, I would recommend adding a board like this to your purchase list. It allowed me to program a dummy part without tearing apart my light and risking damage the first time. The one I bought was local and cost less than $4. In the total cost of things it was worth it for sure.
Also DEFINITELY use a wooden tool to try to remove the board. I forgot this on my second attempt, broke a chip resistor using a metal object, and still have not recovered, even after replacing the broken part. I think my clip is just not connecting, but I have put this project down for a bit.
sbslider, thatās why heās interested in learning on the D4S, it has programming vias on the driver board so you donāt even have to remove the driver.
Hey, itās a good tip though, what you saidā¦ for sure Iāve busted up some driver components trying to bust glue before just like you said. Iāve learned to eyeball down in the hole and maybe feel around a bit with the tip of a small jewelers screwdriver in an effort to get on the pcb before hitting it.
I remember one that was a true PITA, couldnāt get it to budge. Finally got it all apart and it was the strangest set-up, they had a small driver board up top of the contact driver board and I had knocked the screwdriver all the way through that first board! Totally annihilated it, what a mess! lol (a solarforce light, if I recall correctly. Had a top board soldered into a brass holder and the bottom board also soldered in then the assembly is press fit, sure a trick to get out)
Changes compared to the previous version of RampingIOS V3:
Added a moon timing hint. When doing a hold from off, this blinks when passing the threshold between āclickā and āholdā, to indicate when to let go for moon.
Better timing consistency on hold-from-off. (before, the stepped ramp took an extra 0.4s to start ramping up)
Fixed a bug where changing ramp style could go to the wrong brightness level. (go to a med mode, turn off, hold for moon, click 3X to change ramp styles, and itād go to the med mode instead of staying at moon)
Added a D4-219C build target. (FET ramp power reduced to 80%)
Wasnt able to reset password. New problem. The light had problem with switching off after got warm, and had been turning on often, but last time it just couldnt turn off so i had to twist head off. I contacted hank but he only said to take bezel off and look there for some screws, but i dont even know what bits to buy, are they philips or waht. This being asked, hank evaporated disappear. Very pity that i actually sent him the whole amount too fast.
Said:
Looks like there is short somewhere, would you please unscrew the bezel, take
the optic out, then try to take those two screws out, and see if it will work fine again.
But when the screws are not there, please use the low mode only, not the turbo mode.
If the light is stuck at a bright mode and wonāt turn off, it generally indicates one of two problems:
There is an unintended connection somewhere, allowing power to bypass the driver entirely. If this is true, then the light should act like a 1-mode twisty ā tightening the tailcap would turn the light on at a very high level, without even pressing the button.
A button wire is broken or shorted or disconnected. If tightening the tailcap causes the light to blink then turn off, but it doesnāt respond to button presses, this is probably the issue.
There was a week long holiday in China. Everyone is just getting back to work.
Most flashlights are easy to take apart. Iām sure someone here can walk you through opening up a D4 if you ask. It is probably somewhere in this threadā¦
Yeah, not sure who that is, but it seems the account was created just to complain about the guy who runs Emisar.
What Hank said was probably correct, and is likely a useful answer. Sounds like something broke, and itās one of two types of electrical shorts. It should be relatively easy to fix.
To add to the list of possible reasons a light would fail to respond to clicks and exit turbo mode, my friends D4 did the same thing after I accidentally popped off the R5 and R4 resistors while disassembling for an Anduril flash. We managed to get R5 back on, and we thought we got R4 back on as well, but it only looked like a good connection, actually it was open circuit.
With R4 essentially unpopulated, the light seemed to run fine, except it would not enter any strobe modes, and once you entered turbo, the only way to exit was to disconnect power. Very strange. According to zeroflow, āR4: MOSFET current-limitā. So this would seem to make sense?
Who knows. I fixed the connection properly and itās back to normal now. Just thought Iād chime in with my experience.
d4buyer. Ok? Cant remember password.
unintended connection somewhere, allowing power to bypass the driver entirely. - how is it easy to fix? I am just an office worker, so i am trying to get answer, as hank is silent for over two months. Just got tired of nokia as a light.
