18,000th Post Giveaway! Winner! David EF! Congratulations!
249 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 1 day 15 hours ago
WE HAVE A WINNER! Entrant number 34, post number 43… DAVID EF! You Win! Congratulations! Give me a shout and let me know which light tickles your fancy!
Generated at 12:31:22 Central Standard Time
EDIT: DEADLINE MET, 156 official Entries. I WIll Be Back… Wink
I am not sure how it happened, but I have passed the 18,000 mark in posts! So I guess that means a giveaway is in order! But what? I little zoomie? Naaaa, that wouldn’t be any good! Gotta be something with some Ooomph! I mean, right? So, I have recently built two lights that are pretty impressive in output, two pretty different lights but not so much difference in some ways. The winner will get to select which one of these 2 lights he/she prefers… One only though! I won’t be able to ship the cells with the light as in the case of the Q8 that would add weight and shipping complexity beyond my interest. I’ll tell you though, the Samsung 25S or Sony VTC5A (or D) will make either of these perform at their best. Neither of these will be likely to work well with a protected cell.
1. To qualify, you must be a flashaholic and have red blood. Silly Be witty if you want, write a poem if it behooves you or post an inspiring or amazing pic, whatever suits your fancy, but start it off with an “I’m In!” so I can see your post easier. Wink
2. I will keep this open until October 8th, 2018, at 12:00 Noon Central Standard Time.
3. I will keep track of the number of “I’m In!” posts and draw with Random.org according to that number. Winner will be notified by PM here and have 3 days to claim their prize. After 3 days, if the winner does not step forward, I will re-draw and start over.
The two lights…
First is an Eagle Eye X6, my favorite host to build on. I bought the quad MCPCB and Angie optic from Hank at Intl-Outdoor and built up the light with Bistro using 4 Samsung LH351D W6 emitters in 5000K tint. Aside from having no fancy blue back lights this is essentially a poor man’s D4S. But with the right cell installed it really rocks at some ~7300 lumens [was thinking of my D4S with a different emitter, well, same emitter in a higher power bin. Sorry. ] (I’ll get the pertinents and come back with that data) I did make a Tellurium/Copper heat sink for this one, it’s noticeably heavy in the head area, quite robust! And there is a very good AR coated lens over the Ledil Angie optic. The switch is bypassed to enable the light to pull the current it needs to supply the 4 Samsungs. The driver spring too is bypassed. Bistro has the fix so the current doesn’t cause issue. This is using the variation of Bistro that utilizes the table, so it has a lot of options on how to set it up.
Edit: I remembered correctly on the use of Samsung LED’s, but forgot which ones… this X6 is using 4 of the 80 CRI 5000K with a U6 power bin. As such, it makes the following numbers on Bistro…
1. 00.01A for 0.7245 lumens
2. 00.03A for 9.591 lumens
3. 00.13A for 57.27 lumens
4. 00.44A for 221.49 lumens
5. 02.04A for 976.35 lumens
6. 06.60A for 2539.2 lumens
7. 16.11A for 5237.1 lumens, at 30 seconds 4805.85 lumens
The last shot shows 278.6 grams with a Sony VTC5A installed.
Edit: Build pics of the Quad X6…
For those new to it, here’s the schematic on the UI of Bistro…
Second is the Sofirn Q8 that just arrived yesterday. It was making decent output at 5775 when I got it, but it’s now making 9453 lumens with 2 XP-L2 at 5000K and 2 XP-L2 at 5700K. With Anduril on the driver and an Infineon MOSFET, using 4 Samsung 25S cells it pulls 33.8A at the emitters. This light has Blue’s large copper alloy springs, with 20 ga bypasses. I didn’t build this to give away, had sold my original BLF Q8 and wanted to replace it, but hey, I talk too much so somebody gets a shot at this awesome little soup can light. Smile I have ordered a replacement high quality lens from flashlightlens.com with an outstanding AR coating, if this makes it here before time to ship it will be included in the light. Wink
EDIT: I got the UCLp lens in today from Chris at flashlightlens.com. Straight swap with no issues using the 54.87mm x 2.9mm thick version of the Acrylic UCLp… and it now makes 9936 lumens out the front on the Samsung 25S cells! Big Smile
A look into the Sofirn Q8 with the use of an UV light…
I can probably slice and dice the emitters in this Q8 to get a tighter beam profile and mostly eliminate the odd hue in the aura. Might cost some lumens, probably would, still it would most likely be worth it.
This should be the appropriate schematic for the UI of Anduril that is on this Q8…
Keep it decent, enjoy!
A little comparison video, showing the X6 and Q8 as they compare to the 21700 Sofirn C8 and Emisar D4S, as well as the highly modified Noctigon Meteor M43. Enjoy! Big Smile
j
Edited by: DB Custom on 10/08/2018 - 14:46
Lexel
Lexel's picture
Last seen: 11 months 1 week ago
I´m in as first
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 9 min 38 sec ago
Congratulations DB Custom!
Thank you for the opportunity of this nice giveaway. I’m in. Smile
bmengineer
bmengineer's picture
I’m in!
Find all my reviews of flashlights and more gear at www.bmengineer.com
BLightSam
Last seen: 2 years 10 months ago
I’m In!
My God, 18,000 posts !!!
Awesome !!!
DB Custom
DB Custom's picture
Gorgeous close-up Lexel! Love it! Love
Nichia UV emitter, right?
nottawhackjob
Last seen: 6 hours 10 min ago
I’m in!
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
pc_light
pc_light's picture
Last seen: 1 day 12 hours ago
Congratulations on 18K posts.
I’m in.
Just got a different light with a gorgeous optic worthy of enlargement.
Seeking the light.
MascaratumB
MascaratumB's picture
Last seen: 5 hours 26 min ago
Congrats on that-many-posts Dale Party Impressive number !!!
I am NOT in, but I’m passing here to say congrats to the member with more posts on BLF (to my knowledge Wink )
Good luck for the GAW Thumbs Up
ohbreeeezy
ohbreeeezy's picture
Last seen: 1 day 14 hours ago
18k post? what a freak! Big Smile
I’m In!
HONDARIDER
HONDARIDER's picture
Last seen: 2 months 17 hours ago
“I’m In.”
If I win-
My Fear of Night,
Will be cleared by light,
Good luck to you all,
We look foreword to the draw.
I felt behooved to say that. Facepalm
Thanks, DB
abhinit90
Last seen: 1 month 1 week ago
I’m in.
O great flashlights,
please light our way,
like a bird takes flight,
to a place far away.
I suck at this Silly
DB Custom
DB Custom's picture
I was a Honda rider too, for many years. Can’t ride anymore and miss it. Sad
abhinit90, that wasn’t so bad… cerebral illumination. Wink
pc-light, I’ve had reflectors with a pattern like that but never an optic, very cool, what light is that?
fireblade893
fireblade893's picture
Last seen: 9 hours 58 min ago
I’m in.
Not sure if I’ve spoke 18,000 sentences this year in the real world, well done you talkative person you. Big Smile
Streamer
Streamer's picture
Last seen: 1 year 9 months ago
I“M IN ! Could really dig a customization by DB!!
And Congrats on 18K…. Thumbs Up
Dioda
Last seen: 1 month 16 hours ago
I`m in! Thanks for the interesting giveaway and good luck to all Thumbs Up
heatwaves
Last seen: 10 months 3 weeks ago
Congrats!
I’m in.
RotorHead64
RotorHead64's picture
I’m in! Congrats
Agro
Agro's picture
Last seen: 1 min 32 sec ago
I’m in.
Congrats DBC!
DB Custom
DB Custom's picture
OH SNAP Agro! What the heck is THAT? lol
Newlumen
Newlumen's picture
Last seen: 1 year 6 months ago
I am in. Thanks for answering all my questions i PM you.
contactcr
Last seen: 4 hours 35 min ago
I’m in for a shot at one of your favorite hosts of all time. (the X6 of course)
slmjim
slmjim's picture
Last seen: 14 hours 49 min ago
I'm in
To win a light
Prob'ly won't
But yet I might.
slmjim
Smile! It makes others wonder what you've been up to.
Time is more valuable than money.
You can get more money, but you cannot get more time.
sbslider
sbslider's picture
Last seen: 4 days 4 hours ago
I am in, Eagle eye if I win please.
I used this one before, but here is it is again
sbslider wrote:
Ok, 5 letters, 4 different ones, two vowels, two neighborly letters, words that can be made include (not all in english)
Miani
animi
mini-a (an old battery type, between the A and AA)
Niami (last name of a film producer)
ainim
Minia
Imina
Amini (famous furnature designer)
inima
aimin
I main
As to who should win the light,
I, man I
And finally (for now)
I am in
BTW, you write alot!! congrats.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Man Without Shadow
Man Without Shadow's picture
Last seen: 5 hours 28 min ago
I’m in!
When I'm spending on¥ foolishly, I like to do it i$el¥...
I have all the flashlights I need, but not as many as I want...
raccoon city
raccoon city's picture
Last seen: 55 min 26 sec ago
I'm in!
Congrats on 18,000 posts, DB Custom!
(And I thought I posted a lot!)
DB Custom
DB Custom's picture
cool sbslider! Wink
I don’t consider it writing, or typing, as I think it all while my fingers transfer the thoughts to the screen. Smile I used to be pretty good at typing, could fly along at the speed of thought, but these days my brain and fingers seem to have lost some contact and I tend to scramble words and have to go back and fix stuff all the time. lol (well, maybe not funny but it is what it is.)
I do the same thing building lights, after all these builds for the past 4 years or so, I still do the stupidest things! The other day I was putting one of the odd little Osram Black Flat’s on a board, took care to use the solder paste mask to have the right amount of paste, had the board clamped in hemostats and the stats held in my table top vice. Checked it when I was done and the test leads sparked, short circuit! So I heated it up and removed it, made sure I had it on right, put it back on, tested it, short! Heated it up again and made sure it was centered just so, let it cool a bit and tested it, still sparks! UGH! Then I happened to glance at my hemostats… clamped on the positive pad of the board and the Black Flat has negative and thermal pad connected. UuuugggGH! I may learn something new every day, but I forget several old things an hour…. Silly
Edit: Hey wait a minute! Does this mean the new things I learn every day are only new as of an hour ago? Facepalm
oto
oto's picture
Last seen: 6 days 10 hours ago
I am in!
Congrats on 18k!
scrumpypaul
scrumpypaul's picture
Last seen: 4 months 1 week ago
I’m in.
I count that as 8.676 posts for every single day you’ve been a member here. That is pretty good going.
SP
BrySig228
BrySig228's picture
I’m in! Congrats!
Caleb
Caleb's picture
Last seen: 1 week 6 days ago
Im in!
Around the world, from hill to Dale
18000 posts, all hail!
