Here is my VS video…not the best…but you sorta get the idea…THANKS FOR WATCHING.
Thanks Brainsick for the reminder. Updated the OP that the group buy is closed.
Thanks…or people will keep asking, for those who missed it, im sure Sofirn will still have deals…
Go to post #695. That’s Sofirn.
Do we have a member here named, So Verne? KnowwhatImeanVerne? Sorry. Couldn’t help it.
Thx to BROODMASTER for code, q8 showed up today. Sofirn did come thru with a code a few days ago. If anyone wants it, PM me, Amazon us.
EDIT: seems code is no longer valid….
Good Video!
Thanks allot…its a great light.
TLDR: If you want to put in cells in parallel, always check their voltages/SOC.
:person_facepalming: . I hate to reveal my ignorance by asking this, but what does ’TLDR’ mean??
’SOC’ = “State of Charge” = ?
TLDR = Too Long Didn’t Read (a summary)
@teacher, always reveal your ignorance. It’s better to be seen ignorant for a second rather than staying ignorant forever :+1:
TLDR: Too Long Didn’t Read
TLDW: Too long Didn’t Watch
SOC: State of Charge
DOD: Depth of discharge
Thank you sorfin group buy and amazon. I received my light today. The beam look perfect nice white tint. It is 250 more lumen than blf q8 which I tested with the Texas ace lumen tube.
Sorfin q8 4960 lumen
Blf q8 4710 lumen ( 1st original group buy )
Newlumen, tap the bottom of the e04 with your hand a little firm. Does it blink?
No. It doesn’t blink.
Good point Blue…… :+1: … . Thank you.
K mine is broken then
I will see you on the e04vn forum.
I got my order of Sofirn Q8. It came with NarsilM v1.0. Flashed it to NarsilM v1.2, which works better.
Then also tried flashing it to Anduril (latest 09-07-2018), so far it seems to work properly too.
I didn’t encounter the “no switch light” issue that DB Custom mentioned… could it be related to the Aux-LED configuration? (which can be adjusted in Lockout mode: ie. 4 clicks to lock-out, then click-click-hold, then select the mode)
What is the Constant Output of Amps needed from the batterys to run this Sofirn Q8 does anyone know ??
