Well, that’s good news.
Are your DTP boards made of one solid piece of copper like Sinkpads and Noctigons?
Yes.
That is settled then
Now for the leds and we’re in business :heart_eyes:
waiting for the test
You’re amazing, thanks so much
Yaaaay! :+1:
Yes Led4Power… Go for it…
This will be ultra thrower for sure and I really really know that. No need for any special testing I guarantee that to whole forum :+1:
BUMP this topic to create more demand, which will help getting these (well, hopefully).
Thinking about this emitter, i have several lights waiting for this kind of LED, some of them for years already…
But i guess it is just a matter of time.
But we were all a bit worried about the flip chip trend, i guess.
Hope to see some warmer tints soon too.
I want green one
Maybe wait what Cree will come up with?
You mean like XHP35.2? :person_facepalming:
It’s sad to say, but I don’t have any new build plans for a Cree emitter (s). The last was a triple 50.2 and before that a quad 70.2. Just toys and shelf queens. IMHO, ~80cri NW HI emitters from them are the only things I might buy more of anytime soon for gift lights.
The present and near-future of my interests are practical builds. For me, that’s hiCRI arrays running sustainable currents in mule headlamps or Carlo tube lights and pocket throwers utilizing Black Flats. If these turn out as expected and help resolve the pencil beam issue of the BFs then paint me happy! Hoping to see these soon!
To quote Driver:
The waiting for this is gonna kill me .
I just found something:
Osram Application hints for high-current LEDs valid for OSLON Boost HX (KW CULPM1.TG)
It shows the internal structure of the LED and that one (obviously) shouldn't use non-dtp pcbs.
Also, I found some precise values regarding the luminance (these are stated in the product filter/selector):
At 6A and 1670 lumen the LED gives off 553cd which means the luminance is 278cd/mm2 (just divide by the die size - 1,9875mm2). 1670lm is at the center of the possible brightness range of the possible bins when the LED is being driven at 6A.
The luminance based on the lumens: 0,167cd/mm2 per lumen (scales linearily, just multiply with any lumens value to get the luminance at that specific brightness)
I’m not really good in this. Does this imply that the Boost HX has 2.7 times the luminance of even the KW CSLNM1-TG ? (based on the numbers you just posted in the KW… thread)
(edit: maybe the drive currents can not directly be compared)
278 cd/mm² at 83 lm/W? If yes - that’s incredibly good.
At this efficiency HWQP, Q8WP, XHP35 HI do a bit less than 150 cd/mm². XP-G2 is probably slightly behind. NM1 is nearing 200.
No. According to that thread KW CSLNM1-TG does 281.7 cd/mm² when driven to 900 lm.
Boost HX at 6A (which is not peak) does 278 cd/mm². According to the datasheet, that’s 340+ cd/mm² at 8A. And the output curve looks like it’s far from the peak.
Frankly, I find it a bit too good….
Added:
A 1.9875mm² Lambertian emitter driven to 1670 lm has 267.46 cd/mm². Or 160.1 cd/mm²/lm.
Thanks for the extra info Agro
