The There Are No Stupid Questions Thread
1218 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 1 hour 55 min ago
Umpi2000 wrote:
Thanks I hope someone can help me with a how to on this or another LED more suitable or better for the A6
It already has a top performing led, so I don’t understand.
Umpi2000
Last seen: 16 hours 26 min ago
If there is improvement to be had, why not?
I’d like to look at drivers and more powerful leds too, something nuts…
JasonWW
JasonWW's picture
There is no improvement, it’s already pretty much maxed out. The next step up would probably be to install an xhp70.2 and use a pair of 18350 batteries.
Oh yeah, if you don’t mind a TIR lens you can install a triple or quad led setup.
LichtAn
Last seen: 2 months 5 days ago
In some lights the LEDs don’t shut off instantly when I press the switch, but rather dim down until they’re completely dark which takes about 2-3 seconds. Why is this happening?
thijsco19
Last seen: 6 days 14 hours ago
Probably just a design choice.
It might be better for your eyes to have the light dim down instead of instant off.
LichtAn
thijsco19 wrote:
Probably just a design choice. It might be better for your eyes to have the light dim down instead of instant off.
I don’t think it’s by design. You can also just cut the power and the LED does the same. Maybe capacitors discharging?
joechina
Last seen: 1 week 1 day ago
Olight does dimming by design!
And you can also add a capacitor by design against bumps etc.
iosala
Last seen: 1 month 1 day ago
Can someone please poit me in the direction of getting my Q8 flashed with new UI (NarsilM 1.2 or Anduril). I can’t find a good tutorial on the job.
Thnak you verry much!
JasonWW
JasonWW's picture
iosala wrote:
Can someone please point me in the direction of getting my Q8 flashed with new UI (NarsilM 1.2 or Anduril). I can’t find a good tutorial on the job.
Thank you verry much!
Can you remove the driver to mail it to someone?
If so, that will save a lot of money for shipping.
You can try contacting Lexel who is in Germany about reflashing your driver.
You could send the head, but I’m sure it will raise shipping costs.
iosala
Thank you for the answer.
I know about Lexel, I already have one made by him.
I would like to try it myself, but I don’t know exactly how and what gear I need and how to go about doing it…
JasonWW
JasonWW's picture
This stuff is too complicated for myself, but I kinda want to learn so I’ve been keeping track of things.
Try this link for parts.
Here are some videos.
https://youtu.be/Ed0AdA7Kzno
https://youtu.be/VyJpPcmUtSM
iosala
Damn JasonWW, when people do give aways they should just stop and give they’re stuff to you instead :)))
Thank you sir, I will look in to it.
Barkuti
Barkuti's picture
Last seen: 5 hours 29 min ago
vovamile wrote:
Is it reasonably safe to put a protected 18650 (Sanyo NCR18650GA or LG INR18650MJ1) in a cheap USB rechargeable flashlight like the Sofirn SC31 and leave it with the USB charger cable plugged in for extended periods of time (days or weeks)? Or will i actually have to unplug the charger cable when its done charging for safety.
JasonWW already answered this and said “… The only possible issue might be that after the charger stops working it has a small drain and it could slowly discharge the battery so that after a week your battery may be dead instead of fully charged and you have to charge it all over again. …”. As far as I'm versed this should not happen because if the battery voltage drops a certain (usually small) amount while the flashlight is still plugged the charging should resume and top out the cell. You could even test this by switching the torch on for a short time while plugged, of course if it works. Best advice try and check it for yourself, no SC31 to test around here. Smile
Cheers Party
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
ZapperDubs
Last seen: 1 day 16 hours ago
Lightbringer wrote:
lightlight22 wrote:
singularity35 wrote:
Which end of the flashlight lights up? Silly
Both… hehe
I got one just like that!
I bought it at the Darth Mall.
If you don’t mind me asking, what is this? I’m genuinely curious, is it a frankenstein (‘s monster) of sorts?
JasonWW
JasonWW's picture
ZapperDubs wrote:
Here you go.
http://budgetlightforum.com/comment/1270360#comment-1270360
JasonWW
JasonWW's picture
djozz wrote:
It looks like I scratched away some solder mask to make a solder pad.
So your memory works as normal again?
I just added a 680 ohm resistor and measure 677 ohms from spring to body, but I still have next mode memory for some reason. ???
djozz
djozz's picture
Last seen: 23 sec ago
^ the other factor involved is the resistors inline with the leds in the tail, if they are too low, the influence on the driver is higher. I use at least a few kOhm. What are your values?
JasonWW
JasonWW's picture
I happened to have bought 2 of these tail light kits from Gearbest (two blue leds), so I checked the uninstalled switch.
It looks like 330 ohm? That doesn’t seem right. 33 with 1 zero?
djozz
djozz's picture
Yes, 2× 330 Ohm, 165 Ohm resultant resistance and that is very low, the leds are probably really bright?
I checked my X2R build and it has 3× 33 kOhm parallel, so 10 kOhm resultant resistance. My tail leds are green and still very bright. You may try a bit lower, say 10kOhm each, 5 kOhm resultant resistance.
CNCman
CNCman's picture
Last seen: 20 hours 27 min ago
I need some help with re-wiring a new driver to a side switch in a MF04.
Driver removed. Do I replace the 30 AWG wires with something bigger ?
Here is the original driver. It is marked for color wires.
Here is the new Driver.
Where do the side switch wires go ? I do not know.
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
JasonWW
JasonWW's picture
I see no need to replace any wires.
Do you have a DMM or some type of meter? I would find out what the original wires did.
The black is ground so I guess it’s a common ground design. So black wire to the G.
Confirm the white is for the switch. If so, it should go to the S.
The new driver only has output for one switch led so you need to choose which color led you want to connect to the new driver.
Maybe red wire is for red led and green wire for green led? What kind of switch lights are on the MF04? Whichever LED you choose you can attach that to the L which should be the MCU controlled LED output or you could attach it to the LS which should be a steady output.
CNCman
CNCman's picture
Thanks “ JasonWW “ Beer
It has a Breathing Green side switch light and it turns red after batteries get low.
It has been modded for the MF04 and the 2 wires are for the water pump.
I could hook it up and check it with a dmm, but I don’t want to risk damaging it.
Guess I may need to PM Lexel for help. Just hoping this was standard flashlight lingo that us newbies don’t know.
JasonWW
JasonWW's picture
Damaging it? You must not have understood me. Just check the switch wires for continuity. Put one probe on the black wire and one on the white wire and see if pressing the switch makes contact.
All these companies don’t have any wiring standard for switches. Some use a a common negative and some use a common positive. The switch itself is not polarity sensitive, but the LEDs are. You might also check that the red wire connects to the red LED and the green wire goes to the green LED. It’s definitely possible that the green wire controls the red LED and the red wire controls the green LED. I assume the two colors are on opposite sides of the switch. If you accidentally hook up the wrong color LED it’s fairly easy to go back in and switch it for the other wire.
The best thing to do is get a piece of paper or a notebook and write down the switch wires and what they go to and then draw a diagram so that you understand where everything goes and what it does.
Lexels connectors are fairly well known.
The S would be switch positive,
the G would be ground,
the L is swich led positive controlled by the MCU
and LS is switch LED positive constant on.
ryukin2000
ryukin2000's picture
Last seen: 1 hour 36 min ago
I have a solarforce L2T host sitting around collecting dust. Even if i get a dropin, it wont fet used much but at least it would be a back up or loaner. What is a good budget/value dropin module?
CNCman
CNCman's picture
Thank You for the help “JasonWW”. I’m just a newbie here with the wiring.
lampliter
lampliter's picture
Last seen: 1 week 5 days ago
I see people mentioning flipping a light; is that the same as flipping a house? Or is it some kind of mod?
House flipping is when a real estate investor buys houses and then sells them for a profit. In order for a house to be considered a flip, it must be bought with the intention of quickly reselling. The time between the purchase and the sale often ranges from a couple months up to a year. Question
It's only true if you believe it.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 3 min ago
“Flipping” would generally imply selling for a profit (else why bother?).
For a light, you could buy a light, not like it too much (artifacts in the beam, green tint, lousy UI, etc.) and just sell it even for a small loss to someone who doesn’t know any better. Big Smile
Dunno if that qualifies as “flipping”, but it’s almost the same thing, selling it to recoup some bux if you’re not gonna use it.
vinte77
Last seen: 1 week 3 days ago
Can anyone tell me how to find common ground on a driver?
JasonWW
JasonWW's picture
Yes, you need a multimeter of some sort. Put one probe on the outer edge of the driver which contacts the body and then use the other probe to poke around. Your looking for continuity.
If you give specifics, we can be more exact.
Boaz
Boaz's picture
Last seen: 12 hours 39 min ago
Why do people say “You cut yourself more with a dull knige compared to a sharp knife?
One downside to me finally learning how to sharpen my knives is... I have cut myself more often and much worse .
 Lets dispell this myth
