Also Texas Ace thank you big time for the response my friend about the shipping that is great to know about the very fast shipping. I keep going back and forth of getting a GT light but going to pull the trigger on picking it up in the AM.
Once DHL gets their hands on it you should have it in 2 or 3 days.
If you happen to live in a remote area of the Wind River Range, Elk City Idaho, or somewhere similar…… it might take a couple days longer.
Maybe they will… maybe they won’t.
No need for contemplation though. Lumintop will have to answer the question.
Good luck Mr. Scott, hopefully LT will just send you another tube. . :+1:
Is there any estimation of battery life for the GT70 NW with 8 cells (30Q) installed?
Sorry if this has been covered before but Google did not come back with any useful hits.
I’m debating whether to buy a faster charger (I currently have the Nitecore D4 and I’m looking at a Nitecore I8) for my batteries and if the GT70 chews them up fast enough then that might give me the excuse to go ahead with a new charger.
I don’t think there’s been any official run time tests with the GT70. With 150 brightness levels to give smooth ramping you probably need to switch to mode sets, pick a level and see how long it holds it. Maybe someone with 8 30Q can test this.
I know that I need to use matching cells within each 4X battery carrier and I ordered 8 30Q batteries with my GT 70 so I’m good to go.
I currently have a Nitecore D4 charger that only charge 4 cells at a time which means doubling the time needed to charge all 9 of the GT70’s batteries.
My question is if I don’t have time to charge both sets of 4 batteries and only charge one of the two battery sets, will it be safe to use both sets together with different charge state since they are connected in parallel?
Never put cells in parallel in different charge states. That is really bad for the cells, as there is going to be a huge amount of current flowing only limited by the voltage difference and internal resistance of the cell, well above the maximum charging rate of 4A for the 30Qs.
I sure hope this works with the flattop "30Qs" I just got in because my light should be here tomorrow or the next day. I say "30Qs" because these cells don't look like the other 30Qs I have. These still have a pink label but instead of the other markings I'm used to these just have a white label that say "IMR 18650 3000mAh 3.7V" I hope 18650batterystore.com is legit.
I believe you can run just one carrier with batteries. Check the manual.
Of course it’s better to run 2 carries w/ equally charged batteries to split the current but it is possible with the right batteries.
Finally, batteries all charged. What a light. Besides the intense hot spot, it has a nice spill, much more than the original. I also did a side by side comparison between the GT70 and MF04S. Both are NW. Lights are very similar in the size of spot and flood they throw, but the GT7 with 1500+ more lumen definitely dominates. :-)
