When will BLF bring out their own Headlamp????
184 posts / 0 new
Agro
Agro's picture
Last seen: 44 sec ago
Most so-called “protected 18650” are actually about 70 mm long. So really they are 18700, not 18650. They are widely, but not universally supported.
anycolourfloyd
Last seen: 1 year 8 months ago
Agro wrote:
Note: there are good 18700 batteries with built-in chargers.
They can be used as a substitute to having charging in flashlight.
This is not a perfect solution, less fool-proof, less comfortable to use, no 18400 equivalent.
But sometimes it may be better than an in-light charger due to cost or size limitations.
Definitely. Don’t want to put extra size and weight on the head for something that a lot of people won’t use.
leaftye
Last seen: 6 months 1 week ago
Let’s hope the Wowtac high CRI A2S happens.
The low mode should be lower.
pirate joe 22
Last seen: 1 day 8 hours ago
im in for 2
lohtse
lohtse's picture
Last seen: 5 months 6 days ago
pirate joe 22 wrote:
im in for 2
LOL think if there was someone who was actually interesting in making some they would be very happy to hear that you are “in for 2” but for not this is about seeing what interests there is and what people expect…
Problemes d'erection [url=https://www.viagrasansordonnancefr.com/]viagrasansordonnancefr.com[/url] meilleure pharmacie
led4power
led4power's picture
Last seen: 5 hours 15 min ago
DavidEF wrote:
Why even discuss the merits of spot versus flood? We should have both, with two separate optics! This would require a two-channel driver (or two drivers, independently operated?) Still, I can't think of any reason not to do so. Even cheap headlights are doing that, some better than others. High output versus low? That debate has been going on at BLF for a while and we will never get it resolved because some people have opinions that facts can't compete with. Let's define what the purpose of the headlamp is, then make it bright enough for that purpose. If it's going to _need_ long battery life, then a more efficient driver is recommended. For most drivers that means lower top output. But if it needs to accommodate seeing well into the distance, then more output is needed. If it has to do both, then a more expensive linear FET driver with high output capability and high efficiency even in low modes is the best choice. led4power has that, but not in two channel output AFAIK.
I did make some 2-channel drivers for custom orders:
This one is 1s headlamp driver for two triples (flood and spot), two e-switches and relatively complex firmware (but easy to use).
AEDe
AEDe's picture
Last seen: 2 weeks 19 hours ago
Another idea could be concept of minimalistic small and lightweight L-shaped headlamp.
As you can see most manufacturers do not care about this. Even ZL H600 mkx has 39g, and 98mm while old H60 has only 33g and 91mm.
If you look at H03 for example you can see many points where size and weight can be reduced. ( smaller optics, unprotected 18650, thinner driver…)
I think such concept with some BLF UI , and modern Hicri led could be interesting.
DavidEF
DavidEF's picture
Last seen: 4 days 8 hours ago
led4power wrote:
DavidEF wrote:
Why even discuss the merits of spot versus flood? We should have both, with two separate optics! This would require a two-channel driver (or two drivers, independently operated?) Still, I can’t think of any reason not to do so. Even cheap headlights are doing that, some better than others. High output versus low? That debate has been going on at BLF for a while and we will never get it resolved because some people have opinions that facts can’t compete with. Let’s define what the purpose of the headlamp is, then make it bright enough for that purpose. If it’s going to need long battery life, then a more efficient driver is recommended. For most drivers that means lower top output. But if it needs to accommodate seeing well into the distance, then more output is needed. If it has to do both, then a more expensive linear FET driver with high output capability and high efficiency even in low modes is the best choice. led4power has that, but not in two channel output AFAIK.
Wow! Nice! Crown Thumbs Up
- The YKK Philosophy
lohtse
lohtse's picture
damn that sounds and looks good
SKV89
Last seen: 3 days 21 hours ago
thijsco19 wrote:
I read that most of you want a headlamp that has high cri and high output.
What led is available that can do this?
The nichia 219c is not available anymore.
The Samsung LH351D is a nice options but reports say that it suffers from some green in the beam.. Not really good for a high color quality light.
I was shocked that my M43 with 12x LH351D 4000k 90CRI renders colors worst than the M43 with XP-L HI or XP-G2 4000k 5D tint because the LH351D tint is so much further above the BBL, everything is yellow tinted, whereas with the 4000k 5D, white looks natural white in comparison and colors actually appear more vivid despite being only 70CRI. It’s unfortunate we don’t have access to LH351D with a less yellow/green tint bin.
leaftye
I believe the best chance we have is a headlamp that will be available as a host. No glue. Removable 20mm lens with the depth for a Carclo lens. 17mm driver with threaded ring. Beefy solid shelf. Anodized “square” threads. Copper beryllium tail cap spring. Basically the things many of us have requested for years. Optionally, sell multiple tailcaps. A plain version comes with the headlamp, then versions with magnets some version or two of charging, or a lanyard hole, maybe a 1/4-20 hole, etc, could be swapped.
leaftye
zak.wilson wrote:
stephenk wrote:
Do you really want a FET controlled hot rod running on unprotected batteries strapped to your forehead? Plenty of good headlamp options out there!
Yes. Emisar should make a right-angle Nichia triple, with an option for the elliptical Carclos so the beam is wider than it is tall when used as a headlamp. Until then, Acebeam, Imalent and Thrunite have options for those of us who don’t fear exploding death, with the upcoming TH30 having a claimed output of 3300 lumens.
H30, and they’re claiming 4000 lumens. Not a good headlamp imo though.
I could be happy with an Emisar headlamp. Take the D4 and throw a kink in it. I’d still prefer distinct mode levels so I can more easily estimate battery life on very long hikes, but flashing the driver would fix that.
roughrider
roughrider's picture
Would it possible to have 2 or more groups?
Group A could be something similar to Zebralight with distinct modes and Group B could be a ramping one like the Emisar currently has. That would be pretty sweet if it’s possible.
L4M4
L4M4's picture
Last seen: 8 hours 27 min ago
LED-Tech just released the “Cobra25” Module – 25 LM301B (over 200lm/w) on Copper with a Uf of ~3V
https://www.led-tech.de/en/Cobra-25-Copper-Board-in-4000k
We are talking about 2446lm out of 15,35W at maximum brightness.
I think that this module would pe perfect for a headlamp – a lot of light with less heat than regular high-power LEDs.
SInce I have a non-modded SkyRay-King-Clone laying around, I think I will buy one of those. I am confident, that this thing can run pretty much forever without overheating.
LumacSledding
Last seen: 2 years 9 months ago
Yeah, seems to be 2 different groups indeed.
Lightweight and floody for close up work for long periods and then the people who need distance and power(like car driving lights)
Ledlenser actually has a headlamp which has 2000lm and 2 leds – both zoomies. But the thing kind of seems a bit fragile and massive.
Ferei lights has a combo headlamp with XHP35 HI and XML, if i remember correct – the closest one that i personally like. Never tested it but i am afraid it get s bit warm on higher modes. They also make a lamp HL55 – 2x XML – super compact head . Throwier but still with very usable spill. Separate battery box is 2 cells. Tried it in real life..except the beam color and stupid on/off switch its quite nice. At 500lm-700lm was pretty usable because of great beam.
Both reflector lights…and ramping UI.
Lupine went different direction – pretty beefy head with TIR and several(up tp 7) leds..i guess for the heat reasons. With the TIR you need to push the lamp a lot to get some distance out. I think running mostly around 1200lm to be usable in our line of work. Quite heavy beast and the batterypack design sucks…super un-comfy in pocket or belt. The programmable UI is cool.
Cobra light from Sweden uses the technique of several TIR optics with different angle and fogginess…that makes the head quite large also but beam pattern seems nice. Ultra expensive stuff imo.
All those lights are great for “driving” applications – lot of light in front of you and good spill to widen up the range of vision. I prefere the reflector lights better, the slight hotspot helps a lot in shitty weather.
With separated battery pack, up to 2 cells on the head is not a big issue for me when the thing is nicely balanced. Meaning that good straps and head – pack weight is kind of in balance. The cables should be somesort of flat heavy duty ones..because they indeed tend to break. Specially in very cold places. Cells should be changeable but also USB loading in box should be a option.
For close up work there seems to be better options with all skillhunt, manker etc… Atleast regarding price performance balance. The new Manker with 2 × 14500 could give a interesting platform for lighter but still pretty powerful lights.
Lumac Sledding Equipment
0skill
Last seen: 9 months 2 weeks ago
I'm in here is my very first prototype helmet lamp
Parts a made from aluminium and 3D printed plastic
!https://photos.app.goo.gl/PSJkJ4JAaixtBPeUA!
XHP70 driven by a led4power LD-3 all parts are made very simple and cheap TIR and GoPro mount and XHP70 came from aliexpress
Max output is ~4500-5000lm
What I would like to change when I got time is:
The lamp should be a bit lighter Output should be more efficient maybe I will change the design to a 2 LED design with lower current/LED and to different TIR lenses one with flood and the other very spotty
I would like to use the Lampe for mountain biking and for that purpose there is not really a good lamp available out there
0skill
Also available in 2S?
would like to drive 2x XHP35/50 or maybe 70 with it
leaftye
0skill wrote:
I’m in here is my very first prototype helmet lamp
Great project!
lohtse
lohtse's picture
Great project!
Certainly is..
Would be a good project to move to a headlamp format…
Nice work “0skill “
led4power
led4power's picture
0skill wrote:
Also available in 2S? would like to drive 2x XHP35/50 or maybe 70 with it
That driver is 1S, I have 90CRI 5700K MZ LED which is basically undomed XHP50 3V LED:
https://led4power.com/product-category/leds1/lumiledsluxeon/
iamlucky13
Last seen: 8 hours 30 sec ago
The recently announced Fireflies PL47 seems right inline with what BLF would come up with if a community headlamp project was started.
http://budgetlightforum.com/node/62288
Slightly different configuration than typical, and a larger 21700 battery, but a floody quad emitter with high CRI and high output options, and likely either Narsil or Anduril for the UI.
leaftye
That through head design for the battery is innovative. Can I pay with a nice set of nail clippers and file?
lohtse
lohtse's picture
Thought it is a nice design it looks bulky…. so am not sure how comfortable it would feel on the head…. Having come from Bulky Petzl headlamps and similar.. I feel the sheer size with the associated weight would be very off putting…. But who knows so lets see what is what when they FINALLY release the specs etc
leaftye
There’s no such thing as a one size fits all type of headlamp. At the very least, there’s room for two headlamps: light and heavy. Single 18650 headlamps try to find the middle ground, but for me they still skew too heavily to the heavy side, and that’s okay as long as it has decent output. I expect the same thing of this, and I’ll have zero interest in it if it has less than 2000 lumens, and probably won’t buy unless it has significantly more than 3000 lumens even if that’s in a short term turbo mode.
Quadrupel
Quadrupel's picture
Last seen: 4 hours 34 min ago
AEDe
AEDe's picture
The driver itself costs ~25$, it is good boost. So it is very unlikely to get whole light for 40$.
Quadrupel
Quadrupel's picture
Whats what im talking! We have already plenty of good and expensive headlamps in market. Make it cheaper, name it BLF “NiteSkillZebraOlight” and sell it for 39$ ;)) Link for reference how to sell cra.. : https://www.kickstarter.com/projects/biolite/biolite-headlamp-wildly-cap...
AEDe
AEDe's picture
Lol) Thanks for the link!
I had never seen a good flashlight project at KS. But many of them get a lot of money.
L4M4
L4M4's picture
You still haven’t Wink
Just look at the numbers.
330Lumen on high
3.5h on high
900mAh battery
that doesn’t add up.
900mAh for 3.5h means, that you only have ~0.9W per hour – and that doesn’t give you 330 Lumen.
Also, 330 Lumen with a super short lens don’t light up 75m
Also the 2nd, 330 Lumens need to be cooled, even with 200Lm/w (which their LED surely doesn’t have)
It’s like many Kickstarters, just a flashy campaign with nice renderings and photos, but the product itself is still not what you pay for.
lohtse
lohtse's picture
330Lumen on high
3.5h on high
900mAh battery
WOW those specs are just like those REALLY BAD China headlamp that sell for around £1-£5!!! When I see them I always look at what they say and then reduce them to 25% as thats FAR closer to the real specs LOL
