I just gave mine a tap, not charged sinceā¦ unno, probably since I first got itā¦ and it lit up niceānāwarm just fine.
I use it maybe 5-10min a pop, a coupla times per week just before going to sleep (main light off, ānightlightā just to keep from walking into walls).
I think I was the first to post that this lanterns battery tube gets way too hot. Some say it's fine but I personally don't like it. I like the lantern itself and have it plugged into my pc usb port where I use it everyday when night falls. Gives a great warm glow to my computer room. I never use it with a battery and am fine with that.
I agree on that it heats the battery, as i had a bad experience with an overheated laptop pull that began to vent the sweet smell of doom, (but then i tried to mod the lantern & then it died, then the second one i bought that i gave to a friend (who is a fellow expeditioner on our wilderness trips) that one drained its cell to a dangerous low level with some kind of short in the charging circuit. after all this i have flagged these T1 lanterns as problematic, unreliable, and a little dangerous.
Thatās why i took on the BLF lantern project, is to design & have built a lantern that is refined with all the features needed for a good lantern, that is lacking in the current market for such a product.
With as much time as i spend camping, on canoe expeditions, traveling in a RV living off the grid, even in power outages, i have had the opportunity to use & test most every consumer lanterns available, mod many of them to be better, and have found flaws that could be improved in all of them to be the ideal perfect lantern for what a lantern can be. This T1 have failed me on modification attempts to improve it, and with its lack of lockout, over sensitive touch control, heat issues, and now reliability concerns, its one i have lost trust in.
Even if worried about a heating issue with this unit, seems like a bit of common sense could take care of the issue.
One, use the dimming function to run the unit a bit below the max output.
Two, use the magnetic base to attach something like a small steel washer to act as a supplementary heatsink.
Iāve personally used my T1 quite a bit, and never noticed an issue in practice. Then again, I tend to prefer the quality of light when itās running relatively dimly.
I agree that a lockout switch would be a welcome addition to this design.
I also think it seems a bit odd that a separate switch under the base is used to turn the light off - it would seem to make more sense to use a long-press on the top sensor to turn the light off. I have a little Drok-branded dimmable rechargeable puck light that works exactly like this, and I love how easy it is to control. The little Drok is not as rugged as the T1, and doesnāt have a swappable battery, so I donāt take it on travel, but it serves very well as a nighttime bathroom light.
Of my three, one is constant on with no dimming and the bottom switch turns on the reds butt are overpowered by the constant high white leds and does not turn off the whites. The second does not respond to touch at all and only the red leds turn on by the switch. The third works as designed, too bad the quality control is so bad. :weary:
+2 ā¦ā¦ Iām pleased with mine. While it is not something I would take on an Everest Expedition, it works just fine if I use it within itās limitations.
Welcome keihin!!
I havent read of many reports of defective units but only 1 good out of 3 is not goodā¦ā¦ I definitely would have asked for a replacement/refund :disappointed:
I put the āconstant-on oneā in a ziplock with battery extant, pending emergency. The red-only one goes in my spare tire compartment. I am at a stage of life that the conflict with Chinese customer service is anathema to my well-being.
I really hope you donāt require me to prove myself by filming the defective units sent to me as they do. I donāt consider it worthy of a company I want to do any further business with.
LOLā¦ā¦Believe me, I completely understandā¦ā¦ I never understood the ātake a pictureā response, but it wouldnt hurt to shoot them an email(sometimes they just credit your PP account) or PM freeme to see if he could help.
Just received mine today. Wow, only 12 days! Mineās working perfectly. Top button changes modes at a slight touch. Nice! Bottom button for the red light works perfectly also.
I havenāt tried leaving it on high for a long time to see if it heats up but Iāll try that tonight. All in all, I really like it!
One of the two units I got had the same āstuck onā problem you described. The cool white LEDs are just always on at max brightness, but everything else seems to work. Feels like a soldering connection issue.
Emailed Gearbest, sure enough they asked for every piece of information imaginable, including a video. Sent them all that and got a refund (already have a couple more on their way; I think this is a fairly rare issue).
Iād like to take this defective one apart to look at it, but that seems like a difficult task!
I still have one of the three that still works, but i added a resistor to limit its maximum mode to lower the center post temperatures, and added an on/off switch on the side to lock it out as it can turn on to easily by accident.
