Way to go Dale! And excellent choice in emitters. I haven’t kept up with this thread, but my sofirn q8 arrived today and it’s one of my fav stock light under $40. Throws quite far and very bright. The funny thing is, I wanted to see if I can find if anyone posted stock lux numbers and I was browsing this thread and saw your post asking what we think between xhp50 or sst40?
I was gonna reply back after I finish with reading this thread, that I would personally opt for shaved sst40 for throw and high lumens.
Regular sst40 and xhp50 will give lots of lumens but there are lots of soda can lights that can already do this with even more lumens.
But not many or none out there with decent high lumens and throw.
Though I already had emptied my cart, a few days ago I got a message in my mail to “confirm but not pay” my order of the Q8. So I put the Q8 back into the cart and tried to do what they asked. This was the first time to opt for this procedure. At first the suggestions in this forum did not quite look fitting my case, but eventually I managed to get into the next level (we are awaiting your payment). Yesterday I got a noticication in my mail that the price was adjusted!! From then on it went smoothly. So I will be waiting for the postman too.
My late mother always said: I’ll be the first to admit when I’m wrong, but this time I’m right (as always).
Well now it is my turn. I should have listened better to myself, when telling others that you need to have patience in doing business with Chinese sellers (holidays, time-zones, deadlines, etc). In this case I did not have enough patience. I am glad Sofirn did. Thank you, Sofirn.
interesting…
My Sofirn Q8 flashed the low “batt signal” at 3.22v on my q35s tonight… at about 1/3 power….
yeah, not well calibrated. did a full shutdown at 3.13v.
this is an issue. :exclamation:
At 3V, there is a full low voltage protection cut off.
With the cells sagging under load, it could easily be going down the 3V mark, and then when measuring the voltage, it will be idling voltage, not under load voltage.
I think NarsilM v1.0 is 3v warning and 2.8v shut down. If it shuts down a bit sooner I don’t think I would call it an “issue”. The batteries are still virtually dead. I usually recharge at 3.6v or 3.7v.
I have not checked mine yet, but anything in the 3.2 V - 3.1 V range is OK with me. The batteries are about shot then anyway. Lower would not bother me either… the 3.0 V - 2.8 V would be fine too.
In most instances I am going to recharge them before they hit LVP anyway.
I don't know what q35s batteries are but here's the discharge curve of 30Q batteries (taken from HKJ's test):
At 3.22V resting voltage (=comparable to 0.2A discharge), there is 11% energy leftover in the battery (if you take HKJ's safe 2.8V as empty) , at shutdown 8%. The Q8 draws about 4-5A per battery, so at that discharge state the voltage under load is about 0.12V lower than the resting voltage, so 3.1 V in your Q8 at LVP-stepdown, which is a littlebit too high but nothing alarming, not much left in the battery anyway.
Or the throw of the threaded end is shorter, not allowing the ground contact to be made. Sometimes lights are like that, many lights you can’t flip the battery tube around for example.
the O ring on the Sofirn is in a slightly different place and it looks like in order to make that tube fit they removed a thread from the inside of the Sofirn head. You can see an entire extra row of threads in the BLF Q8 head
I need two more 35Es for the full set, but I had some things laying around to put an 'adapter' together. Precautionary measures like placing electrical/kapton tape over driver screws must be done but this could help in the scenario above or for using flat top batteries:
The 26mm OD copper washer stays in place as the friction against the batteries is greater than against the driver ring. The O ring, I thought, might inhibit contact but it didn't and the light works. I also had an idea to insert slim dowels, tubes, etc. to hold it centered in place. Another caution, the light is assembled on a flat surface, slowly, to make sure everything stays in place.
In the picture it looks like the bottom battery has damage to the wrapper. In that case nevermind the tape and screws it will just short to itself. Solder blob seems much easier
Also, in my example the batteries are making contact its the tube that isn’t. Ill just keep the original tubes with their own light but it does make you wonder what else they changed.
You're right about that. Good eye. These are some pack pulls and I used them for staging the photo. In practice, I would use some brand new batteries that are spread across a few lights at the moment.
