I have not seen anything high current in 32650 size, probably because they have trouble getting rid of heat.
For high current the best sizes are probably 18650, 20650, 20700 and 21700, both because they have larger surface compared to capacity (Better heat dissipation) and because the main development are on these sizes.
A battery pack meant for an electric vehicle does not necessarily needs to be of top discharge rate. It depends on the minimum discharge time you aim to subject your pack to. For a bicycle a 3Kg battery pack can be made of inexpensive, standard PLB INR26650-50A or INR26650-55A cells (the cells rewrapped by LiitoKala and Shockli among others). A 10S3P pack would have a 36V 15/17Ah rating, with 50A discharge rate without losing effective capacity down to 2.5V, which at least is 32.5V × 50A = 1625W load adjusted out to the motor(s). This is more than enough power for a bicycle, I believe.
Thank you for this clarification about a more favorable surface area for elements with a smaller diameter, dear HKJ. Those tables in which you display your large and useful work for all people to study the behavior of a variety of batteries, I think the most convenient and sensible of all that I have ever seen.
Taking this opportunity, I would like to sincerely thank you for this painstaking and valuable work that you have been doing for many years, slowly complementing these lists with the results of new tests. Meanwhile, despite this, more and more newcomers appear about the batteries, about which we do not know anything, but their advertising at the same time looks very tempting. Perhaps this is not a battery, but some kind of junk, but here is another example of such “unidentified flying objects” - [quote=97.36€ |10 stücke 26980 3,7 v 6000mAh Lithium batterie zelle hohe rate 15C Nicht 26650 3,7 v 5000mah 21700 für diy pack power EV AGV lampe roboter|Ersatzbatterien| - AliExpress]size 26980
[/quote]
You, by chance, do not plan to conduct your professional tests for them and then display the results in your table (26650)?
On the other hand, of course, their length is too large for a normal location inside the bicycle battery (the standard placement of the 26980 elements would make the battery too wide and protruding from the sides). However, their advertising is of interest to them, so it would be nice,
if your tables would also have results for these unusual items “26980”.
Since electric bikes have as many as two controllers for the voltage that disconnect the battery from the load-engine (one is in the battery itself, and the other is the power controller-regulator of the engine), high-current batteries are of most interest.
in which, when discharged during operation, after the voltage level of 3v, practically nothing more remains in their trunk with a capacity. That is, up to 3v they should be at a good voltage level at the same time with a high load current, and then their discharge line should drop sharply down (almost at an angle of 90 degrees) to the “2,5v” mark and there will be a minimum of energy in the remainder (aspire to 0 mAh).
I am planning on creating a 14S battery (51,8v). If I choose the elements of Golisi-4300mAh, then I can try to find a place for 14S x 3P (there is very little space in the frame of my bike). I like the Shockli-5500 (black) no less and they have more capacity, but it is possible that for some reason (commercial?) they have already been taken out of production, and today only remnants are sold, mixed from different lots into a big pile. This can lead to the fact that all Shockli-5500 will have a noticeably different internal resistance, and as a result a rapid deterioration in the overall battery balance.
I don’t know anything about PLB, but it’s still better to choose powerful I*MR current elements suitable for electronic cigarettes. How the IN*R elements deal with these tasks is not known to me.
@volchyonok, I’ve seen that cell before. It’s really interesting to see customs sizes surging in the market, like the 38120 LiFePO4 cell that was starting to be offered a while back used, and still have extremely low internal resistance.
The 26980 though looks huge. I have no problem believing it can sustain continuously 50-60A continuously with a capacity of 6Ah.
My normal test are limited to 70mm long cells and 30A, if I see a good reason I can go much higher, but for suggestions for tests I also have to look at the price of the cells, generally I have to pay for them. There are a lot of exception to that, some manufacturer are donating cells for testing and it will always help if people (i.e. my readers) ask them to donate cells to me
Regarding the iron-phosphate elements, I can say that they do not suit me, because for the battery I have already bought bms for lithium-ion batteries, which have 4.2v (3.6v or 3.7v). Regarding the constant rise in prices, I can answer that it needs to be said “many thanks” to the current owner of the dollar (:money_mouth_face:, the growth rate of which is often created from scratch and has no adequate soil for this. Many have already understood that modern leaders of different countries see the development of the economy not in the growth of production, but in a simple increase in prices for almost everything. That is, they do not create the economy, but make inflation.
Until we see real results on different current loads from a professional appraiser of HKJ elements, we can only guess what these 26980 are and what it really is. If you start surfing the internet looking for such items in 26980 other stores, then you can meet exactly the same elements of 26980 6000mAh, but with a completely different characteristic for the “C” discharge. For example, they may be marked not as “15C”, but as “3C”. How can this be, if in appearance they are exactly the same, including the color of the case and the negative conclusion partially protruding outside? Somewhere it says “10C” or “5C”.
That is, whoever wants, he will write as much or, after all, is it true about the ability to withstand current shocks of 60 amperes?
In principle, tests up to 30 amps can be considered quite sufficient and very informative, moreover, given the suitability of the elements for powerful electric motors, where several parallel “P” are used in each cell.
So, for example, when from the HKJ tables we see that if a single element heats up, but it successfully copes with its main task (in this case there will be several elements in parallel in our battery in each cell), then we get an excellent and powerful battery because as a result, the internal resistance and heating will be several times less. Moreover, in addition, the capacity of such a jar will be greater.
What is the total maximum power your bicycle motors will pull? As I said before, the Shockli (Power Long Battery) cells should work nicely. I see no point in using Golisi 4300mAh (true rating 30A continuous, probably the overrated Yodeli 26650 4300 40A rewrapped) cells unless you aim to set up some absurdly high powered bicycle or a very small battery pack, in which case I'd go with 18650s or 21700s.
Power Long Battery is manufacturing these cells for electric vehicles among other things, but of course I do not know how much will the cells last. If you aim for a durable battery pack I'd recommend choosing Samsung cells, they seem to be life cycle champions (related review: Bench Test Results: Which lasts longer? VTC6, 30Q, or HG2? @ E-CigaretteForum).
¿IMR? Sorry to say volchyonok, but as many others you've been mislead by false advertising. There are nearly no true IMR cells being commercialized right now, that chemistry is outdated. Check this article: Battery chemistry FINALLY explained @ BATTERYbro.
Do you believe the Golisi IMR26650 4300mAh is really IMR (LiMn2O4, Li-manganese)? FALSE advertising. LIES.
Most modern cells are LiNiMnCoO2 (NMC - INR), LiNiCoAlO2 (NCA), LiNiCoO2 (NCO) or maybe some other top brand secret recipe.
The LG HB6 is likely to be a true IMR cell, pretty low capacity too.
If you want a lightweight and powerful battery pack the best option probably is to make it with top brand cells (Samsung, Sony, Panasonic or LG). And as I've said before, if you need to power around 1000W of electric motors my above solution was already more than enough. Remember I've used conservative figures for my calculations, the pack above is even more powerful and if you go 14S3P it will provide over the top power if required. And remember, for accurate power output figures you need to substract loaded cells' voltage drop. Average nominal voltages (3.7/3.6V) are only seen at very low loads.
If you go with the PLB 5500mAh cells in 14S3P my conservative average sustained power output figure would be 45.5V × 50A = 2275W, with a maximum average sustained power output figure of 44.8V × 60A = 2688W.
Hope you can sort of understand this, it seems there's some language barrier.
Elements Shockli IMR26650 5500mAh-black is disguised elements from PLB INR26650-55A? Did the Shockli IMR26650 5250mAh-green, this also the original disguised from PLB (50A-5000mAh), or did this 5250-version of Shockli take it from another manufacturer?
Of course, Golisi 4300mAh-Gold will lose in terms of mAh and, accordingly, the maximum distance covered during the trip. But, according to the results and graphs of HKJ, they behave quite steadily at high load currents compared to the absolute majority of batteries from other manufacturers.
However now when you introduced us to the manufacturer of PLB, I lack the graphic data of bit characteristics from our famous researcher in the world of autonomous power sources - HKJ. I became interested in these PLBs (I liked the discharge curves of version 50A-5000mAh more), but where are the PLB-50A and PLB-55A results in the HKJ tables, which will allow to compare their characteristics with all other participants and direct competitors? If PLB-50A \ 55-A are so good, then why the PLB manufacturer itself is not interested in providing its elements to the well-known HKJ for the sake of its own benefit and successful promotion of its unfamiliar elements in the market. Yes, PLB maker has already shown us its own discharge graphs. But, why are they so small and poorly distinguishable for review and comparison? Why are pictures so dull and uninformative that are so important for making a purchase decision? https://www.powerlongbattery.com/Content/ue/net/upload1/Other/31531/6360980322031489824761548.jpg https://www.powerlongbattery.com/Content/ue/net/upload1/Other/31531/6360981837394597488448928.jpg
I also like the form factor 21700, so for now it’s hard to decide what to bet on - 3P-26650 or 4P-21700. 18650 I don’t want to consider at all, because I think that for high currents they are, all the same, too thin. The thing is, that batteries with their internal resistance are not ordinary passive resistors with their own rules about resistance. Elements are active chemical reactors with their own character for each, so you should not look at them just as we do according to the usual rules for resistors. Therefore, it is better to have a smaller number of large elements in each bank than a large number of small elements.
Well, let it be INR or with some other designation, but for me and for many other people it will be even better if we can evaluate their bit characteristics in the most convenient and competent HKJ-tables ( ͡ᵔ ͜ʖ ͡ᵔ)
Volchyonok, 26650 are not made by any of the 4 big manufacturers so they will never match the power density of the 18650, 20700, 21700. If it did, we would have 26650 with 7,000mah. That Power Long battery (Shockli 5500mah and KeepPower 6000) with about 5750mah seems to be the closest so far. So if power density is important to you I would stick with the smaller cells.
Had to fix your link mess, please use the link button to post links (button with globe and two chain links or just two chain links), do not quote.
Those cells look like the real thing, of course for as long as the providers are trustworthy.
In AliExpress you may have more luck if you search for "LiitoKala 26650" or "LiitoKala Lii-50A", sometimes really good sales arise (much lower price than the first link you posted).
If you can buy in alibaba reliably it could be a nice option. I see you found 55A cells.
100% FAKES. Panasonic actually made a low capacity 26650 long ago. Nothing of interest for you I'd say.
OMG JasonWW, volchyonok does not need the highest drain batteries he aims to build a decently big battery pack for a twin 500W engines powered bicycle. A 14S3P pack made with PLB cells is already plenty powerful enough for 1000W of electric motors plus electronic speed controllers, computer and whatever such setup may need additionally. He is probably russian, newbie in the forum and does not seem to communicate very well in english. Hope he doesn't gets even more confused with all of that. :facepalm:
Given his power requirements the best energy density to weight option for him would be a 14S6P pack made with high capacity/medium drain cells like NCR18650GA, LG MJ1/M36 or Samsung 35E cells, of course imho.
Yeah, most people use high capacity cells, like Tesla, for the most range and it can still provide plenty of raw power due to high number of cells. I don’t think he needs the highest drain.
≈50% longer than 26650s, this certainly improves the surface to volume cell ratios. But they certainly need to be rather good cells to stand a chance against PLB 50A/55As. ¯\_(ツ)_/¯
Yeah, they are only 6000mah, though. Either they are high drain/low capacity or else below standard. If it had the same chemical mix as the Shockli 5500mah, the mah should be closer to 8000-8500mah.
As far as I understand, neither Shockli, nor PLB really have their own developments, and if they have a real production in which they work with the very stuffing of their batteries (and not just engaged in dressing the outer shell under their name), then this most of the stuffing they take already finished form from someone from the largest manufacturers. Maybe, then one, then the other, then the third or fourth. And then there is some mysterious fifth national Chinese manufacturer, which supplies its most important stuffing under the name “INR26650-50A” and “INR26650-55A” for most of the elements, for example, for the manufacturer of PLB, LiitoKala, and many many other nameless. To make sure of this, you just carefully look at the market, where most of them even do not want to change the shell of the basic “INR26650-50-55A”, because it also costs money. Only some of the sellers decide to make a cheap sticker on the surface of these “INR26650”, for example, as does LiitoKala. They do not even hesitate to say loudly about the discharge current = 20A, and indicate only 15A for confidence. At the same time, they made an “update”, instead of 5000mAh, they now write 5100mAh )) 5100mAh
What about the size of 26980 can I say? These are elements that are based on the same “INR26650” filling, only the size of its internal roll is increased. Yes, they really should be better, but everything is relative. Better than what? This very “national Chinese basic” stuffing perfectly does only some then one manufacturer (the fifth one, unknown to most of us). But, since this filling is the national treasure of China, other manufacturers of batteries for batteries also have the right to make it. That is, make copies of it. I think that it is impossible to acquire the original stuffing, because it goes for the military needs of China. Therefore, such manufacturers sellers like Shockli, LiitoKala and hundreds of others can only choose between copies of the INR26650 filling. Someone chose a better manufacturer, someone worse, but in the end, according to the graphs of our esteemed HKJ, you can see that many of the elements have a very similar character of their bit characteristics. With only minor differences. And this is normal, because it is impossible to make absolutely identical copies in everything.
Shockli, for example (4300-Green), has a very noticeable problem at the beginning of the start at high currents, after which a pendant bag suddenly appears at the line, which then rises back to the main discharge line ( https://i.imgur.com/SKWqUWC.png ). This is a very big disadvantage because the reverse lift only seems like a good thing. In fact, it is due to the rapid heating of the element and the reduction of internal resistance in just such a negative way. This will affect the resource, which will be much lower than those of elements for which this effect is not observed. Another way out is it is not to shock Shockli with large currents in order to avoid such sagging at the start in the form of a temporary bag. And can anyone say why HKJ never showed its own measured data on the internal resistance of the still cold (before connecting any loads) Shockli-5500? - “Calculated internal resistance (ohm) - xxxx (ohm)” ??..
Samsung T-30 3000mAh original - today you can not buy it. Only original fakes (no letters in the title “TB” and with slightly different sizes from the original) Sammmmsung T-30
Well, or here is such a frank trash (apparently, also with a familiar filling of the type “INR26650-50 \ 55”) 21700 T30
As far as I know, Power Long Battery and Shenzhen Yongde Lixin Energy are cell manufacturers. Their official specifications do not necessarily follow the usual standards of the main manufacturers LG, Murata/Sony Panasonic/Sanyo or Samsung. Power Long Battery, for example, states/specifies 1C discharge rate, a lot higher than the usual 0.2C.
With regards to discharge rates there is no standard. Chinese manufacturers like to specify borderline high continuous figures which straight make cells overheat. Samsung endorses cycle life and is usually cautious, whereas Murata/Sony is aggressive and does not hesitate to list maximum continuous discharge ratings which may require temperature cut-off.
They can write whatever they like. Among top bad and completely good there are rewrappers of all kinds.
Some of the latest reviews of that seller are dubious. You may find other similar sales.
LOL!
Looks like Samsung 30T cells, if the seller is trustworthy that is.
That looks to be the same Lishen manufactured cell used by LiitoKala in their Lii-40A rewrap. Actual specifications are 4000mAh capacity and 3C maximum recommended continuous discharge rate (12A).
Now add to them also those salespeople that I showed you along with the links in the posts above. Then you will also find a whole bunch of exactly the same, just lesser known “PLB”. And they all have their own personal production with a turnover of about two million batteries per year, including completely identical versions of the “INR26650-50A and INR26650-55A. Even the shell is almost the same for everyone, but they all say that they make these elements independently in their own production. Often, even the characteristics with the description for these INR26650 are made as a copy. And this is true, because the main source of material for all is the same and structurally they are all twins.
The question is only one, the final product of which in the end turns out better. Shockli chose PLB manufacturer. And another of his competitors chose the neighboring manufacturer INR26650. Or also signed a contract with the same PLB, who knows them for sure. Items for ”Shockli-5500” bought from PLB. But, for the “Shockli-5250”, apparently they have now been selected from some other kindred PLB. Look, despite the number of the approximate value of mAh and the high current usage of both models 5500 and 5250, the graphs of their unloading noticeably differ from each other. In general, if you can order items directly from PLB itself, then why search for Shockli objects, overpaying for a simple new label, which inside the battery will still not be visible? In addition, there are suspicions that when buying batteries in order to reduce costs, Shockli asks the manufacturer not only for the absence of a factory label, but also prefers to place an order with a cheaper protective membrane (disables the contact of the element during an overload). That is why on the graphs we see a sharp drop under load at the very beginning of a more or less noticeable discharge in the form of a bag hanging down and then rising back, and even higher than the former.
This is the effect of poor contact of the protective plate, because of which it quickly overheats and only after this heating has good conductivity. This is reflected in the subsequent rise of the discharge line on the graphs after its entry into the bag. At the same time, completely unnecessary heating of chemistry occurs in the region of this membrane, which adversely affects the resource and durability. And such elements cannot be connected to a battery with a large number of cells at all, since they very quickly lose the balance of voltage and mAh. The usual internal BMS with its small balancing currents can not cope here.
In short, these are individual power sources, which are suitable only for smoking cigarettes, that is, they will be there good for what they are intended. And for different flashlights. For good such powerful flashlights, they also fit perfectly
