MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
Sure. I had it on the default temp settings, originally. Haven’t messed with much of the ui actually.
My meter doesn’t log, but I can take readings at intervals to see what it does over time.
Meaning to fully test these lights anyway.
Batteries on the charger, I’ll post back here when I’m done, hopefully tonight, possibly tomorrow.
I bumped mine up to like 185c and it still drops like a rock. Guess my host is not suited for this. I think my 50.2 4k 80cri peaks around 2050 lumens but only for a few seconds. Hoping your c8 soaks more heat and can be constant for longer. Maybe put it at 185 or 200c instead of disable at first
Here we are:
Both with fully charged VTC5a
This is the 4000k 50.2. Sphere multi for this color temp is 0.194641099 (ending battery voltage at 150 seconds was 4.01v)
View post on imgur.com
and
This is the 5000k 50.2. Sphere multi for this color temp is 0.200202433 (ending battery voltage at 150 seconds was 3.99v)
Time scales are the same. 10 second intervals from 0 to 150 seconds. For some reason the second graph lost that data.
And for reference: i’m using a maukka-light calibrated, 17” spherical, BaSO4 coated, integrating sphere with a drmeter 1330b
Looks like the C8 holding relatively steady turbo for 60-70s vs 10s shows that it is adjusting correctly. Now i’m curious if adding some type of heat sink to the coil on the underside would make any meaningful difference. Maybe no point testing such a thing until it bumps up to the 20-22mm size.
Would MTN Electronics ship small items with low value in an envelope to Europe? If you do not need many things the shipping costs more than the products themself!
Unfortunately, US shipping overseas is pretty expensive… and there’s nothing RMM can do about it.
Hi Richard,
As an aside, I’ve been one of your customers for awhile now and you folks have been great with reasonable prices and fast shipping.
I was wondering though when I ordered a couple of 26350 cells, one of them was leaking, (another gent here had a leaking cell also). I know you folks get super busy and I can appreciate that but I emailed you folks about it and received silence. You folks are usually very good at answering emails.
I didn’t ask for a refund or exchange, (I actually should have), but was just alerting you to the fact that your inventory of 26350 cells may contain some faulty examples.
Anyway and like I said, I’ve been very satisfied with many orders I’ve placed with you and just wanted to make you aware of this.
Team up with someone outside of US to cover international shipping?
But then the team member outside the US needs to get a cut, right? I think as good as Richard is, people who are not in the US are just better off not buying from the US as long as our shipping is so high. Or at least, they should weigh for themselves whether it is worth a little extra cost to buy from Richard. Certainly, for some people, it is worth it. :wink:
Yes, it is definitely worth the cost even if shipping to Europe. I like the driver DIY kits and the pre-programmed MCUs. I just thought if envelope shipping inside the USA is possible it might be available also for Europe?! MTN Electronics does a good job shipping overseas. All the components are packed well and the items contained are all listed neatly on the outside of the package. It even arrives in less than a month. You just have to need more than only one driver so that the shipping cost is at least equal to the items cost.
There are unique parts not available or hard to get elsewhere.
There are flashlight shops which could just add Richard’s stuff to the inventory. That’s a small cost for them. I believe may be able to set up their cut in a way that makes such arrangement beneficial to all - themselves, RMM, non-US buyers.
:crown: :+1:
Quick question. Can the 20mm mtn-ddm driver be filed down to 18-19mm and still work well?
I have one filed down to 18.4mm, works fine.
Awesome! Thanks!
For anyone who is wondering :slight_smile:
Great News! Congratulations Richard and Lisa on your new baby girl! :+1:
That’s awesome. Congrats Richard & Lisa! Children are such a blessing.
That’s good news. Congratulations Richard and Lisa, wish you all and your daughter the best.
Oh wow congratulations!!!
