The 6th Annual BLF / Old Lumens - Handmade - MtnDon's Entry (fini)
153 posts / 0 new
MtnDon
MtnDon's picture
Last seen: 15 hours 27 min ago
Smile Yes, I have a start! Took a while to get going.
I’ve changed my plan to be another lantern sort of a project. Mostly wood as in previous years.
I was in the shopthis morning and will post the first pictures shortly. For now this is just so everyone knows I am now ‘on task’. I will also notify the of this topic I just started.
Edited by: MtnDon on 11/26/2018 - 16:59
CRX
CRX's picture
Last seen: 5 months 2 days ago
Smile Thumbs Up
MtnDon
MtnDon's picture
First images.
Wood, specifically pine in a select grade. Nice knot free stock. This section is starting with two 3/8” thick x 5-1/2” wide (basically 10mm x 14cm) boards. They are clamped down to the worktable in the first picture by the two wider boards (2×4’s) to the right. The narrower board is a guide strip held perpendicular to the wood stock.
I cut three spacer strips to allow easy routing of the grooves to be cut with the router. The bit is a 1/4” (6.35mm) carbide straight/end cut bit.
One set of grooves completed, all grooves spaced 2-7/8” (about 73mm) apart.
Then I switched the boards about and cut more grooves at a spacing of 1-1/4” (about 32mm). The very observant may notice an extra groove… I made an error in groove spacing in the image above. I recut the boards and made these wider spaced grooves all over again, but did not photograph that step. The extra groove at the right end here will be chopped off and become kindling.
Each set of grooves was then trimmed to length using the mitre saw. The cuts were made very close to the side of the last groove, close enough to leave a small extra amount of wood that will be later sanded to precise length once things are fitted together.
Next strips were rip sawn off the grooved lengths. Done on a table saw.
I only need 16 of each but cut extras, just in case.
That’s all for now. Each strip needs to be fitted and sanded with fine, 220 grit, sandpaper. Back later, maybe even tonight.
DavidEF
DavidEF's picture
Last seen: 6 hours 24 min ago
Wow! Nice start! I’m interested in seeing where this is going! Glasses
- The YKK Philosophy
ToyKeeper
ToyKeeper's picture
Last seen: 34 min 19 sec ago
… a Jenga lantern? A miniature light house?
DavidEF
DavidEF's picture
A miniature Jenga lighthouse! Last one to move a board without the light going out WINS! Party
MtnDon
MtnDon's picture
Not a jenga, but that would be cool.
MtnDon
MtnDon's picture
Sanded the strip sides. Sandpaper sheet held down with miter guide and a couple of clamps. Complete with an action shot…. those are hard to do when you only have 2 hands and no helper.
ToyKeeper
ToyKeeper's picture
That awkward moment when a grown man posts a picture of himself vigorously rubbing his wood.
ToyKeeper
ToyKeeper's picture
Why, yes, my sense of humor is only about 8 years old. Why do you ask?
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 3 days ago
How do you always get these pics of yourself so quickly? It’s seriously impressive Toykeeper.
Also, my sense of humor is always changing everyday. So, technically, it’s still a newborn Smile
chops728
Last seen: 8 min 27 sec ago
I’m glad that’s not what happens in real life (Sawdust) Big Smile Big Smile
MtnDon
MtnDon's picture
LOL
ToyKeeper
ToyKeeper's picture
That’s odd. No sawdust?
Have you tried using sandpaper?
chops728
Unfortunately yes—— I’m a Carpenter Wink
gchart
gchart's picture
Last seen: 1 hour 1 min ago
Looking good! (and shuddering at the thought of sandpaper… ouch!)
Flashy Mike
Flashy Mike's picture
Last seen: 1 week 3 hours ago
Subscribed. I’m curious to see which beauty you’ll build this year.
FmC
FmC's picture
Last seen: 7 months 2 days ago
Nice start, Don Thumbs Up
djozz
djozz's picture
Last seen: 7 hours 5 min ago
Looks good, I like woodwork!
MtnDon
MtnDon's picture
The ‘sticks’ are called kumiko, in Japanese woodworking. These fit together to make a grid. I have played a little fast and loose with these as the do not have the interlocking that is traditional, but the end result is more or less the same. Traditional Japanese woodworking relies on precise fit and parts that fit together in a manner where one piece holds another in place. Very little glue and no mechanical fasteners like nails and screws.
I am gluing some of the joints around the perimeter. I am using liquid hide glue, a modern development of traditional hide glue. Traditional hide glue has to be heated to make it flow for use. This version stays liquid in the bottle, can be used at room temperature. Hide glue was the glue traditionally used for furniture. It can be removed by steaming or soaking parts in water. Hence, this project cannot receive an IP rating as immersion in water with soften the glue and it might fall apart. Wink Hide glue also has a longer open or worktime than the popular and good yellow glues.
There is a saying in woodworking that one can never have too many clamps.
One down, three more to go. In a few hours I’ll do another frame and so on.
The design is known as shoji (Japanese). Those who have been around here for a while may remember the shoji bookshelf doors from about a year ago…. link to a sidestep in a flashlight project topic, and a photo of the finished unit.
That’s not the best photo.
MtnDon
MtnDon's picture
Four sides to the light…
DavidEF
DavidEF's picture
Are you going to paper those? Is it rice paper?
MtnDon
MtnDon's picture
I’ll be using a laminated paper made for shoji screens. The lamination makes it much more resistant to finger punctures and staining. Leftover material from the bookshelving doors.
DavidEF
DavidEF's picture
Oh! Cool! Cool Thumbs Up
shirnask
shirnask's picture
Last seen: 1 hour 21 min ago
Big ring on top?
MtnDon
MtnDon's picture
shirnask wrote:
Big ring on top?
TBD
MtnDon
MtnDon's picture
FYI, the laminated paper is this one….
…and to affix the paper to the frame I’ll be using this tape.… Genuine Japanese product, not a word of english on the package
DBSAR
DBSAR's picture
Last seen: 3 hours 58 min ago
subscribed Smile looking forward to this.
Agro
Agro's picture
Last seen: 1 month 2 days ago
What’s the transmissivity of the paper? Do you know even rough numbers?
MtnDon
MtnDon's picture
Not a clue off hand. However, I will keep the question in mind and will measure the difference when I get to the stage of mounting the material on the grid frames.
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
Looking groovy Don. Thumbs Up
