The experiments with my AK-47 driver comes out rather good, I wished for:
100% - 25% - 6.3% - 1.5% but I got approx:
100% - 21% - 1.5% - glow, narrow pulses 5us on lowest, period 140us.
Changing only the low, high fuses from 0x79, 0xEF to 0x6A, 0xEF gave:
100% - 21% - 3% - 0.05%, broader pulses of 18us on lowest, period 480us. (this is near the 2 kHz Tido mentioned).
Changed the levels and ended with:
100% - 27% - 7.5% - 0.25%, Lumens measured to:
200Lm - 54Lm - 15Lm - 0.5Lm Very, very nice light, near the ideal light for me. It uses 20mA on lowest level and 1.06A on highest. The only draw-back is the click-speed. It should react on shorter clicks. How do I change that, Tido? Oh- I see now that we cross-posted..
I tried changing the SELFPRGEN bit in the BLF AA-Y4E light by writing 0xED to the high fuse but it would not change. Anybody know why?
0xEB was not good, the light never came on. I tried 0xED instead and now it reacts on very fast clicks, but it is still a lottery and I keep ending in the extended mode. How do I exclude that?
You can set the following in driver.c (line 48-50):
#undef EXTENDED_MODES // enable to make all mode lines available
#undef PROGRAMMABLE // user can re-program the mode slots
#undef PROGHELPER // indicate programming timing by short flashes
Then go into the "Default" directory and do your build there.
What voltage is the battery you are using? With my fuse settings, the µC would trigger a brown-out reset at 2.7V. Adding another 0.6V for the drop across the protective diode, your battery would have to be at or below 3.3V.
To build a driver without the extended modes group, just use the "Simple" configuration.
After enabling the prescaler in software and using 0x6A and 0xED for fuses the light is now almost perfect. Even the click response got better than before. The PWM frequency is about 260 Hz and there are no flickering to see. It is a 4 level, Simple model with outputs: 200 - 50 - 12 and 3 Lumen. There are almost proportionality between output and battery current so 1 Lumen costs about 5 mA in this light which is an Ultrafire WF-502B with R5.
Now I plan a bigger modding-event (strobe-killing) when my drivers arrives from DX, eventually.....
I am totally on board... what do we use? Shotguns, dynamite or nukes? ;-) Death to all strobes (and low PWMs)... I don't even go in clubs and disco's any more... lol
sixty545, could you write up a small summary on which configurations you used and how well they worked? I'm a bit confused by all the information fragments scattered throughout the thread so far . The report about the light not turning on with the brown-out detection set to 2.7V got me a bit worried.
Has anyone played around with the programmable version of the driver yet? I'd really love to hear some opinions about the UI.
No not yet - I would love to give you some feedback on the programmable version, but my BLF AA-Y4E board suddenly died last night (not related to your driver).
I am now waiting for some DX & KD driver boards to arrive so I can continue experimenting :-)
I went through a fast series of experiments and did'nt write them down in a protocol. I used this thread as a sort of protocol. I will not be able to recall the history of combinations (them old grey cells....) but I can try changing the brown-out bits again the next time I'm gonna program and then check if the light will start-up on the 4V power supply.
I'm trying to understand the button click functioning and timing, there are still too many non-reaction-clicks, I could use some hints here.
I found that the low frequency of PWM I have now, makes the digital lightmeter and the multimeter show varying values - I will try setting the CKDIV8 bit in low fuse back to 1 to have a faster frequency again but keep the divide-by-8 in software, let's see how that turns out.
Don't worry more, Tido. I tried the high fuse 0xEB again and this time it started fine. I must have had a broken power lead the first time .
I found out that a PWM period of about 1 msec is a good compromise between problems with narrow pulses (giving less than expected light) and problems with digital measuring instruments showing non-steady readout. I used 4.8MHz oscillator, clock divider = 8 (CKDIV8 = 0 ) and Timer Divider TCCR0B=1 (as in the original SW). Thus the low fuse is 0x69 and high fuse 0xEB.
The algorithm is quite simple. On start-up the program checks if the last time the light was on, it was on for more than two seconds (let's assume this is true for now). It then stores a marker in eeprom, saying that this time it was turned off after less than two seconds. Then it starts a timer and goes on setting up the light. This marker is removed after two seconds have elapsed.
Now let's assume that the light has been switched off before the marker has been removed. When the light is switched on again, the program finds the marker in eeprom and knows that it is supposed to change the mode.
So, you can only change the mode within two seconds after turning on the light and the power has to be off long enough to cause a shut-down or reset of the µC. If you want to change the mode after more than two seconds run time, you first have to tap once to start the two second timing and then again to actually change the mode.
Thank's, I think that really explains what happens.
Looking in the program I found this, are there writings to the eeprom all the time the light is on or am I missing something:
// write back state to eeprom but omit the mode configuration.
// Minimises risk of corruption. Everything else will right itself
// eventually, but modes will stay broken until reprogrammed.
eeprom_write_block(&state, 0, sizeof(State_t) - sizeof(state.mode_arr));
eeprom_busy_wait();
That would eventually destroy cells in the eeprom.
