What’s the transmissivity of the paper? Do you know even rough numbers?
Not a clue off hand. However, I will keep the question in mind and will measure the difference when I get to the stage of mounting the material on the grid frames.
Looking groovy Don. :+1:
Thank you. I had a week off from work and didn’t do a thing on this. Now I’m back home and must get back at it.
missed it by that much ....
Back again. Normal life and other projects took me away from this for a while. Once the glue was dried on the screen frames they were sanded. 150 grit and then 220 grit. Now they are smooth and more or less all the same size. Here are a couple of photos showing them. Pardon the dust.
So those 4 pieces, called screen frames will have the shoji paper glued to one side after they are stained and clear coated. The frames will be mounted into a skelteton, or framewoork, that will hold the four screens in a box-like configuration. There are 4 corner “posts” or stiles. Each is 3/4 x 3/4 inch and about 15 inches long, also select grade pine. I cut them to length a few weeks back. Today I started in working on them and had progressed to the stage beyond before I remembered I had not taken photos of the rough cut sticks. :person_facepalming: So we will jump to what I spent most of today on. I’ll try to show and explain how the rabbets were cut in the stiles.
To mount the screens the each stile needs two rabbets cut into them. A rabbet is a sort of a notch. I used a router to cut the material away. A jig was temporarily assembled utilizing wood pieces and clamps. In the photo, the 4” wide long board is the same thickness as the stile material. That board is to provide a base for the router to run along as well as support the stile as it is machined.
In this next photo you can see two 1/2” thick scraps of wood at left and right, held down with clamps. Those are placed to stop the router at the furthest left and furthest right along the stile. The short 3/4 x 3/4 blocks were cut to locate the stile the proper distance from the ends. Some measuring, math and lots of trial and error on trial sticks was needed to get everything sized.
The next shot shows a stile held in the jig. It has a rabbet cut. Each stile has two rabbets cut intothem.
This next shot is a closeup of the left end of the jigged parts. The piece with a #2 in a circle is the 3/4x3/4 spacers block. The thinner but wider piece just to the left of it is the router stop strip that is clamped down to the table. The strip of wood that disappears off to the right is a portion of a stile. Hope that all makes sense.
Next, is a photo attempt to show the router fence at the stop block. My photography is not the best, but maybe it helps understand the process. The red arrow points to where the black router fence is stopped from traveling any further left by the clamped down wood strip. That area is not in sharp focus unfortunately.
And to finish off todays work here is a shot that includes the 4 screen frames and the 4 stiles. Next I need to clean up the rabbets and check the fit of the frames into the rabbets.
The router fence has a fine thread machine screw that allows adjustment in small precise amounts.
After I get the rabbets sanded and fitted to the screen frames I will show how this goes together with rubber bands or something containing the assembly
Getting closer to the finish MD. Its looking real nice.
Nice woodwork :+1:
Looks great Don :+1:
What color stain are you going to do on the frames?
Awesome work!
I have not decided 100% yet. Either ebony (black) or a rust color. The bookshelving (and kitchen cabinets) I did a year ago is ebony with the same shoji paper in the bookshelving sliding shoji doors, as this lantern will get. The rust color is what we used on the hardwood (home) doors.
Not to derail the topic, but hardwood doors… man, don’t seem to see too many of those going in. They do have a great feel though!
Back on topic… I like the rust color, but the contrast of the ebony against the shoji paper looked really nice on that bookshelf.
Well, although I like the rust color better (at least in this picture), I think if you’re making this lantern the same design as the book shelving, maybe you should use the same ebony color. It would probably look odd to have two similarly built items to be stained with two very different colors. But, I could be wrong. It’s your build!
Thanks very much. That picture does not yet have the ebony stained oak trim around the door. The door is knotty alder, left with the knots as they fall with no attempt to hide or fill them.
It’s our son’s place. I’m his contractor who works for something to do and food. Next spring summer we plan on the next level up, 5 more doors like that and a bathroom renovation.
If I stain this one rust, I plan to keep it and then maybe make another to be done in ebony stain and give it to our son.
Aha! Then I change my vote back to Rust color.
More progress….
My original plan was to use a chisel to cut the round ends to the rabbet cuts to a square shape that would allow the screen frames to fit into the stiles. However, I changed my mind and decided to sand the screen frame corners round to match the rounded rabbet cut ends.
That’s 150 grit sandpaper. I used a block under the frame to be sanded to raise it off the worktable. I used a few different blocks to vary the height from poiece to piece to adjust where the work piece was on the sandpaper. The scribe lines were made using a scrap of aluminum with a 3/8” hole drilled… same size as the router bit used on the stiles.
In theory each stile and each frame should be pretty much identical in dimensions. However, in practise that does not always follow. So I have assigned a letter or number ID to each piece, made a map and will follow that pattern.
Here’s an idea of what this will look like. It was slightly tricky rubber banding this together with only two hands.
Next, I need a top and bottom. Not sure what they should be named, so I’ll just call them the top and bottom. I don’t want end grain showing so I need to cut strips to cap the end garin. These will be glued to the main piece and I’ll use dowels to make holding them in place easier. No metal fasteners. What I mean will be clearer as work progresses.
I have a jig for aligning the dowel positions and for holding the drill bit perpendicular to the edge of the pine board. It utilizes hardened steel inserts for three sizes of bits; 1/4”, 5/16”or 3/8”. It clamps and self centers.
Once those holes are drilled I used a couple of steel dowel centering pins to transfer the position of the holes to the piece of wood that is to be mated. Here are the pins in place. The smaller piece of wood has already been placed over the pins and tapped to allow the pin points to mark the positions.
I use a couple of clamps, using a light clamping force, to hold the two pieces of wood in alignment, then tap the upper piece to contact the dowel pins. There are other ways to get the alignment, but that is what works for me.
Then I drilled the small block on the drill press.
Last image for now… The small block is glued to the larger piece with assorted clamps to hold alignment. The dowel holes have just enough sloppiness to allow slight misalignment of the two pieces. The sideways clamps help with that. The two larger clamps provide the clamping force to make a good bond between the large and small blocks.
Oh! I see!
