The aux LEDs turn red at 3.3V and turn off entirely at 3.0V. The amount of power drawn while off drops to a very low amount which I think is lower than the cell’s self-discharge rate.
The main LED driver also has low-voltage protection, causing it to shut off when the battery is too low.
So there isn’t much risk of having the battery drained below safe levels.
Thank you, very helpful to know.
Ever since I learned my Astrolux S42 breathing mode can deplete the battery to 2.38V, I am concerned with any type of drain when the torch is “off”. I do a head lockout on the S42.
The ROT66 has redundant protection and with the low draw you mentioned gives me comfort enough to not lock out the ROT66 when not in use. Happily too as the Aux LEDs are pointless if you can’t leave the torch “on” to admire.
The S42 was very badly designed, in general. But the breathing mode, in particular, is something I’ve avoided on purpose. It’s a nice-looking effect, but it greatly increases standby current. It’s implemented by drawing a slow triangle wave on the PWM duty cycle value, which requires running PWM while the light is off, which requires leaving the MCU on instead of going to standby. So the “standby” current is about 4 to 5 mA.
I usually aim for standby current in the range of 0.2 mA to 0.001 mA. So… no breathing mode.
The ROT66 with aux LEDs runs a bit higher than that, like 0.2 mA to 0.5 mA, but that’s pretty okay with a multi-cell power source like it has. That should last about 2 to 5 years on standby… and the user can turn the pots on the aux LED board to reduce the brightness as far as possible.
It’ll get more confusing when we get drivers with 16-bit PWM counters. Then it’ll be 0 to 255 sometimes and 0 to 65535 sometimes. But probably still 150 ramp steps, because that number seems to work pretty well.
Ah so that’s what you meant by 125/150 earlier. I’m gonna try experimenting with maybe 120/150 or 115-110/150 to see if I can get a slightly lower output that will manage heat better.
Man, the temperature calibration was a good 10c or so off on my particular ROT66 from the looks of it. I didn’t have a thermometer on hand to get a completely accurate reading of my room temp, but I do know it was around 18-22c, so I dialed in 22c just to play it safe. My ROT66 read 35c!
I also changed the temp limit from 45c to 55c.
I also set the ramp ceiling from 125/150 to 120/150, and now it manages what looks like a 1100/1200 lumen output for at least 10 minutes without any heat issues. It did get warm, but it never got super hot, so I think I found the level where it can shed heat well enough on the SST20 4000k version.
You didn’t have the light running beforehand, did you? If so, the lights internal temperature might have been higher than its external temperature. I mention it because a lot of people forget about this.
I let it rest 30 minutes. It wasn’t cold to the touch like my other ROT66, but at the same time it had ample time to shed any heat. I’m going to go back later on and re-calibrate the temp again when it is cold to the touch to get it completely accurate though.
I can’t say why these specifically, but we’re using such basic MCU’s probably because until recently, we weren’t using much of their capabilities. I mean, at one point, as far as I know the norm seemed to be essentially a convoy style Nx7135 single channel 3 or 5 mode light… doesn’t really need much of a chip to control that. Anyway, apart from the limitations we’re starting to have (and, after all - it’s not as if an atmega is gonna fit in a d4) they’re not that bad. Easy to program, for one thing.
My ability to resist finally broke down last night. My wife is probably not going to let me live down buying another light, but oh well. I went with black on the hope she’s less likely to notice it.
I’m really looking forward to my first experiences with Anduril and SW45K ranked emitters. The only other 219B light I have is just R9050 binned, I think.
I'm still working on my cover story. Maybe if I mod my Convoys with illuminated tailswitches I can confuse her.
My fall back would be to distract with a gift, but she's not a jewelry person, so I've got to figure out something else.
I keep hoping that if she sees the right copper, brass, anodized titanium, or otherwise fancier lights, she'll catch the bug. So far, it hasn't worked.
