Cree changed production process for XP-G2 emitters!
:person_facepalming:
And I got my first 5 black flats today and putted two in a GT mini and a Convoy L2. Now I need to order these….
LOL… Yes you need :beer: It is better, nicer and most important:
“The biggest difference compared to BLACK FLAT is thermal pad, which is ELECTRICALLY NEUTRAL, this means you can use this LED with any standard XP DTP boards – there is no need for LED PCB/driver GND isolation!”
I literally finished the GT mini an hour ago.
Just to metion to everybody that you can use it with FET drivers also but you need to have low current cell like LG BD118650 or those Panasonic or Sanyo GA.
It will pull around 5.7 –6A on low current 18650 and more than 7.15 on Samsung 30q or better.
Worth to mention that performance will start to drop after 6A so don’t use it above that mark!
But the best would be linear driver with around 5.5A current draw.
One thing to mention… At 3.3A current draw little king gives same performance as the best G2S42B emitter at 4.8A!
Yes you heard that right…
You could easily have old g2s42b performance at only 3.3A draw and of course plenty… Really plenty of run time on single 18650 cell :+1:
But the spot size will be less than the S42B.
anyone did a revied those led ,performance chart OSRAM KW Vs S42B chart? djozz ?
Since these leds are pre-production samples exclusively available via led4power and only announced a day ago, there are no nice charts yet. But led4power has done some testing himself and gave the relevant numbers, and l.i. has done some very succesful mods. That should get people started prepared enough.
Is such a chart much needed?
so its time to upgrade my courui d01 kd reflector
You sent a payment of €24.85 EUR to RA ELEKTRONIKA
Yes spot size is smaller…
Yes… Guys you don’t even have to afraid of direct driving these with fet drivers just use low current 18650 cells. I guarantee that :+1:
But of course Samsung INR30Q or better high current cell could potentially kill it. As I said i did 2 minutes continuous test with 30Q and it survived. It pulled over 7A of current…
Djozz and Ko3fe will do proper test anyway.
I would say that sweetspot for best performance is around 5.8-6A anything above and performance starts falling.
But if you’ll drive it to from 3.3-3.5A you will still have lux performance as best G2S42B! Isn’t that cool? Especially for smaller reflector or smaller aspheric lights?
How do you know they are pre production?
Several distributors already have them in stock.
Mouser doesn’t have them in stock but you can still purchase them as individual units.
https://octopart.com/search?q=KW%20CSLNM1.TG&start=0
They have been produced, so how can it be pre production? :partying_face:
Then you can use a shorter focal length aspheric, or put a pre-collimator lens in between, less light wasted, larger spot size with roughly the same intensity.
It will be good with smaller diameter optics too.
Maybe l4p used some marketing talk here, but it says so on his site: “Limited pre-series production in stock!”
Well I know that certain guy from UK got exclusive on Osram 4715as(infrared) emitters. So bigger dealers can get pre-production series for testing that is for sure and 1000 pcs reel is like sample order or something like that.
If they find you interesting they will send if not they will reject offer.
Oh, weird, idk.
It says on label: "Pre-series production", I guess that means they made several reels of those for customer testing purposes before they started mass production(it takes ~3months to make them).
Huh interesting
Not familiar with these, What Cree comparative tint are the LEDs? Will it cost an arm and a leg to have them shipped to the USA?
Might want to give them a try on some of my small EDC’s
Thanks!
AlexGT
Check his site, led4power.com, for shipping options and costs.
