BG says opposite.
1 x Astrolux S43S 4x XP-G3 or Nichia 219C Copper 18350 Flashlight (Without 18650 body tube)
Martin, Will S41/S42 body lego with S43’s head & tail cap??
My A6/S41 18650 body is slightly shorter but does lego with S43 n tail cap
BG says opposite.
WOW - i totally missread that!
you are right...
and i tested the S41 body+tailcap and it worked .
Will 106xx Carclo Lens fits S43?
Am I correct in thinking the aluminium S43 has a single spring on both ends? It does about 10A.
This S43S seems to have a button on the driver and double springs on the tail cap. It pulls 15A.
I guess they bumped up the power due to the copper head.
S43 is button head too, dual spring tailcap
Can you please Martin to find out if a tube from Astrolux S1, S41, S42 can be used for Astrolux S43.
He said in post #26 that S41 does work:
Thanks, I did not look at the previous answers.
That’s fine. I’d still like to know if S42 tube would work too. Do they all fit together?
The S43S head in the picture and video is obviously different…???
The head is the same, maybe you mean the bezel shape on the end? Martin is asking about that.
Now we’re getting somewhere!
I’ve got an S42S I’m gonna cannibalize :smiling_imp:
I never picked up the S42S editions since the UI wasn’t’t good.
How hard was that bezel to get off? Mine feel glued on my S41S editions.
You have the S41S tailcap. Does it interfere with the e-switch…How’s that working?
no glue, but I remember the first Oring broke when I opened it (lubed the spare and it's good since then)
click the tailcap is like turning the original tailcap
but the switch is not glowing in off
I ordered a second with 219C for my S41S.
So the tail switch acts as a lockout?
yes
question-the copper head version has a longer turbo time or the same as the original allu version?30 seconds for turbo for both?
Since copper has 42% more heat capacity than aluminium and better heat transfer, it should last about 40-45 seconds more than the aluminium version, and cool off faster.
I ordered S43 (the regular version, not copper) with Martin’s code and have received the unit. I tried comparing it with S42.
some comments:
- S43 is longer than S42
- S43 now accommodates protected 18650s (not that these are recommended for the quad-LED) where the S42 does not (I used a Wuben ABE2600 protected 18650 2600mAh to check if it fits)
- using the S42 (S1) 18650 tube on the S43 works, and seems to also accommodate protected 18650s
- using the S42/S1 18650 tube on the S43 will make the flashlight a little bit shorter
(even with the S42 + S43 18650 tube + S43 tailcap compared to the S43 + S42/S1 18650 tube + S42/S1 tailcap = the former is still longer overall)
- tested the S43 with included 18350 tube: protected 18350 doesn’t seem to work (it seems to screw in, but maybe still lack a bit so it didn’t touch)
- testing the S42 + S43’s 18650 tube + S43 tailcap: protected 18650 still won’t fit (regular 18650s fit)
- the S42 & S43’s 18650/18350 body tubes and tailcaps will “lego” with each other properly (tried all combinations) — only concern is the length of the battery (protected 18650s will only fit if using the combination mentioned above); not that protected 18650s should be used on this flashlight…
- S42 head uses spring, while the S43 head is a nipple-top (I did test several of my flat-top 18650s, which seem to work; although I haven’t exhaustively tested if all flat-tops will work well)
update:
did some more testing with the “nipple” side of the S43:
- using S43 + S42/S1 18650 body tube (which is a bit shorter than the S43 18650 body tube) + S43 tailcap, again using the same flat-top VTC6 and flat-top 30Q, shaking the flashlight doesn’t cause the light to disconnect or flicker
I notice that the S43S 18650 body tube (ie. the 18650 body tube pre-included with the S43) is listed as “coming soon” and not yet available separately in BG’s website.
Only US$10.14, buy best DIY Spare 18650 Body Tube 18350 To 18650 Tube For Astrolux S43 / S43S LED Flashlight sale online store at wholesale price.
It would also be a good alternative to those who ordered S42 in 18350 tube. The S43 18650 body tube has reversible pocket clip position.
The Mateminco S03 copper seems to be the same flashlight as the Astrolux S43S, but the link to Neal’s Gadgets does not seem to exist yet. Mateminco’s version seems to have a slightly different body tube design. Maybe Martin can give some comparison if he has both flashlights on hand already…
(the below link leads to a “404 not found”)
https://www.nealsgadgets.com/collections/mateminco/products/mateminco-s03-copper-quad-xpg3-nichia-219c-2100lm-edc-flashlight-narsilm-v1-3
sorry - I have no S03
