I made “disposable” ones that way. The wires/magnets I keep, but would use those whote tubular “foam” (blown LDPE, I think) to wedge ’em in 1-cell chargers for my 26650s when I wouldn’t want to unpack a bigger charger.
Like now, with the Cometas, I needed to charge a 26650 that I had in an F13… dug up the wires, and ♫ viola ♫, instant charger!
I was the one who told that info on TLF. :person_facepalming: I tested my early 2017 S42’s front bezel which only took 2 or 3 rounds and then … no way to close the gap.
Thank you, M4D M4X, for doing this lego. I wondered if the colored S42S tubes would fit the S43S. I’m not very pleased about the black anodisation, your colorful version looks much better and tempting!
Turned the Lumintop Tool AA into a UV flashlight.
I used a SK68 clone driver (1 mode, AA/14500), a Nichia UV 365nm from Convoy S2, and a UV filter from the S2 as well.
To make it shorter, I am using it with the magnetic tail (making it a 1 mode twisty), not the clicky tail!
Seems like he got an aspheric fresnel lens, which are kinda rare, as you can tell from the sharp die projection in the spot.
It’s still very low performance compared to what a normal aspheric glass lens would do, closer to 3Mcd.
Of course it has it’s advantages like being cheaper and lighter.
Nice UV Tool MascaratumB! I take it that you had to sand the filter quite a bit smaller?
I tried the new Osram KW CSLNM1.TG led in a BLF D80. I made a 12x7135 biscotti driver by adding 4 chips. In the end I measured only 3.9A so 1 chips is probably not cooperating, but 3.9A is pretty nice for this led anyway.
The output is 710 djozz-lumen which is close enough to max, and I think I did a good job focussing it (I combined two centering rings, one inside the other, both sanded down on the underside until the rims were paper-thin), see the beam at 5m distance, but still I got “only” 140 kcd throw on max, while I hoped for 170 kcd.
It has become a nice little light though, I think this led fits very well in the D80…
Thanks djozz!!
Yes, I had to use a “dremmel”-like tool (Parkside from Lidl ) and had to grind it (with a disc) for a while!
Method: I used the original Tool AA lens to draw and cut a DC-Fix circle and “glued” it on one side of the filter. After that, I put the disc in perpendicular position towards the lens and started grinding until some glass started to jump. From then on, I’ve passed in circles on the edges of the lens until it fit on the flashlight! The DC-Fix circle not only helped to make the “tour” around the lens, but also prevented some glass breaking in an already fragile part!
And it was it I’m not very good at these things, but it works well, and most of all, it is small
And that’s what I’d call a tight spot!! Nice :sunglasses:
Put a Black Flat in my D1.
I don’t how much we can trust the numbers but I get about 100kCd out of it. D1S is about 350 with the same LED and M3XS about 400.
I need to re-focus the D1 farther with a centering ring though
EDIT : crap pic of the M3XS beam, nice and tight :
