Its taken me awhile to remember where I used a similar optic. Justin sent me the optic. Cant remember the diameter but thought you may have used one in your mod.
I think that optic might be Ledil Iris, if it’s ~38mm. Doesn’t look like Khatod PL1672.
Edit: measured actual Ledil Iris optic at 35.0mm. 38mm includes the holder diameter.
I received the KW CSLNM1.TG leds today. I will do an output test one of these days (if maukka or Koef3 do not beat me to that ), but for now I measured tint at 0 degrees, 30 degrees, 60 degrees.
0 degrees: 6100K on top of BBL, CRI 68
30degrees: 5800K creeping up above BBL, CRI 67
60degrees: 5300K going further up, CRI 65
WAIT! Dots? Are these some kinda micro-COB emitters or something? Won’t those tiny dark spots make it challenging to get max luminance in a thrower?
Same as the black flat, not any significant variation when on high power.
Completely invisible after all the imperfections on optics.
Thanks Enderman!
You’re welcome
The “white flat” looks so pretty
Thanks Hoop, nice info.
Can’t wait to get mines !
I forgot to put my old test results:
I calculated/estimated lumens from my lux numbers and datasheet bin specification.
Yellow marked lumens calculation are based on old black flat measurements at 1A as reference (made by koef3 I think), non-marked lumens are based on ~middle of bin lumen number at 1A from datasheet (330lm, actual middle is 335lm).
Using yellow for calculations….
If this emitter really has 1.0609 mm² and 952 lm we’re at 285 cd/mm².
Note that according to package drawing in the datasheet this LED is 1.0609 mm² minus rounded corners.
Also note that the Blackie HWQP while nominally 1.0609 mm² minus cut corner was measured at 1.12 mm².
I tried to measure the size based on djozz photo, but haven’t really arrived at satisfactory numbers…
Assuming that it actually is 1.0609 mm² it is much more efficient than the previous generation (in terms on intensity vs. efficacy). I’m really anxious to see a Koef3 test where I can compare it with the competitors directly…
That’s what I’m seeing, note that I’m far from fully trusting the chart.
Interesting point:
I still think there’s something that we don’t understand about Synios. If we add it to the chart with intensity that can be calculated for a Lambertian 0.503 mm² emitter, it looks like this:
Likely coincidence though.
My son and and a friend who was coming to play at our place had way too much energy so I kicked them onto the streets to play in the playground a few streets away. So that freed some time for the led test.
Note that I used my standard test method with all the added disclaimers about how it is done. Especially note that I keep using the djozz-lumen although I know that it is between 7% and 10% too high, I do this to be consistent, so results can be compared to all my earlier led tests.
I used a DTP 16mm led4power board for reflow because those pads matched the smaller Oslon pads of the led just a bit better than a Noctigon. And indeed the reflow went easy.
As I noticed before my maximum is at a lower current than other testers, the cooling seems less well done in my set-up. Part of it may be that I usually apply a generous amount of solder during the reflow, a bit more than the minimum needed (with Oslon-sized leds on 3535 boards, excess solder can not be squeezed out by tapping on the led). This results in a somewhat (not much though) thicker solder layer that may add to a slightly higher thermal insulation of the led.
I stopped the test at 7A. The led emitted angry blue light then, but I kept it 2 minutes at 7A to see if it could handle it, and it did. Afterwards I turned the current down to 4A and kept it there for half an hour, the output was only 1% less than the initially measured output at 4A, so the led seemed to have handled the 7A maltreatment with no problem.
amazing.
ahaha look at that poor xp-e2
Thanks for the testing guys!
So in the end the lower Vf is probably why the performance is better. It simply has to deal with less heat at the same current.
What die features determine Vf? In other words: if you want your LED to have low Vf, what do you do to achieve this?
I only know that flip chip LEDs have a lower Vf. Presumably because the resistance of the current spreader is much lower (it replaces the bond wires). The remaining Vf is caused by the actual led junction. It is specifically for blue LEDs (red LEDs for example have a lower Vf). There are probably additional factors which I don’t know about.
Also, die size is a factor. You always need to compare LEDs with the same die size (current density). That will show you that the XP-G2 is really old technology.
Osram UX:3 LEDs like the ones above use vertical current spreaders (the little dots) to distribute the current more evenly.
We are getting really off topic here…
New coupon codes:
L4P-8of100 for every order over 100€
L4P-12of150 for every order over 150€
L4P-22of200 for every order over 200€
L4P-40of300 for every order over 300€
3of50 coupon is replaced by discounted registered shipping which is automatically applied for every order over 50€.
Coupons are not valid for bare Samsung leds since there is already qty discount under product options.
Can you set samsung price for 100?
Lower VF is good not only for lower temps (and more output) but also higher efficiency and longer regulated runtime in single-cell lights.
I hope that one day LEDs have a low enough Vf that they can basically run at full power until the battery is drained without the need for boost circuitry.
These CSLNM1.TG are 100% the best thrower LED in existence, I highly recommend people buy it
PM sent.
