Sofirn C8F 21700 Teardown and Review
Referencing this post;
Dale shows the following;
Sofirn ……………………………30Q…………………………Sony VTC4
  1. 0.552 Lumens…………………0.552 Lumens………………0.587 Lumens
  2. 37.50 Lumens…………………22.29 Lumens………………22.81 Lumens
  3. 83.15 Lumens……………………82.8 Lumens………………84.53 Lumens
  4. 890 Lumens………………….872.85 Lumens………………931.5 Lumens
  5. 1338.6 Lumens……………1314.45 Lumens…………….1400.7 Lumens
  6. 3015.3 Lumens……………3018.75 Lumens…………….3125.7 Lumens
    ……2756.66 at 30 sec…………….2691 at 30 sec
This is stock from what is described.
Amp draw do not know.
After 18 gauge wires and new mosfet went well over 4000
Bottom line, If I can’t see the difference I do not need to be buying a new battery form just to be “like the new kids”
Like the New Version just can not justify another version at this time.
Thanks!
Keith
His lumen tube reads way higher than mine. This is why I don’t use his lumen numbers. The amp draw is more accurate.
The best thing about the 21700 version is the new ramping mode UI with one click on/off. This is why I never bought the 18650 version.
OK, that’s cool
Good info.
I just spent some time to dig up my post with my own lumen numbers and seems like Dale’s measurements are spot on
I grabbed a few 40T to try them out in my light.
I’ve got the SIRa800 and 18 gauge from the driver to mcpcb installed.
Turn on with sofirn battery gave me 3,904 and 3,504 at 30s
Turn on with 40T gave me 4,024 and 3,764 at 30s
3% difference, negligible IMHO
Both tests, batteries fresh off the charger. Measured in a maukka light calibrated sphere.
Mtn. D4-v2 driver in mine, I got 3890lm on the Sofirn battery 4430-4400lm on 2 of my 30T batteries.
This does not invalidate my statement. It still holds true.
I’m guessing there is some kind of bottleneck with this 21700 driver.
The 18650 version light seems to be capable of higher output then the 21700 version which is the opposite of what it should be.
Did you measure the stock driver output in lumens and tail amps?
How many tail amps are you drawing with the new driver?
I’m curious what effect a straight driver swap can do.
D4v2 driver with 20awg leads,18awg TC bypass 30T off the charger at 4.21v….4460lm.
No doubt 18awg leads will get you a bit more… I don’t have the patience for it on this light. :smiley:
I think I figured out a small design flaw in the manufacturing that is causing reduced output.
It seems the new aluminum driver retaining ring is not able to fully tighten down on the driver (at least my driver). I thought it felt strange as it only tightened up to one point and then would go no further. I used some marker dots to confirm this. The ring seems to be squeezing the driver lightly instead of firmly.
The 2A difference I saw earlier with my battery tests and again a 1A difference after I swapped to 18 ga led wires. I can move the driver around when the retaining ring is about 1/16 of a turn from its “tightened” position.
So maybe the driver pcb is a bit thinner than it was supposed to be or maybe the threads are not cut far enough. Maybe they should have continued using a brass retaining ring. I’m not sure.
I will relay this information to Sofirn.
Thanks for the review and also the analysis on why the Sofirn C8F 21700 may sometimes be underperforming… Hope Sofirn will solve the “underperforming” issue soon.
They already know the old FET is not the best, so it hurts performance a little. They have already switched to a better FET.
I don’t know if all the lights have a weak contact on the driver retaining ring. Some may.
I also recommended they swap the led wires to 18ga. It’s a cheap way for them to boost the output even higher.
Here’s an update. I swapped out the factory wires (I think 22ga) with some heavier 18ga. I ended up shortening them about an inch, but that’s barely long enough. I recommend 1/2” shorter at most.
Once I got a decent connection with the driver retaining ring, output jumped up quite a bit. Look at the bottom of the page. I was in a rush so I only did Turn On and 15 seconds for both tail amps and lumens with each battery.
The Sofirn battery gained about 2 amps and 400 lumen. 3,450 lumen, wow!
The 30T battery gained about 1.5 amps and 300 lumen.
The 50E battery gained about 1.4 amps and 300 lumen.
The little Samsung 30Q gained about 1 amp and 300 lumen.
So some pretty nice gains just by swapping to 18ga wire. :beer:
But I thought your lumen sphere is calibrated with Maukka lights so it should be reading about the same as mine. So if Dale’s measurements are similar to mine, then shouldn’t it be similar to yours?
Very nice info. So the 30T measured 3,400 lumens, which is less than the Sofirn 4000mah because of bad connection? Also the performance of the Sofirn 4000mah is very impressive. Seems like a rewrapped Samsung 40T.
I don’t know why, but my lumen tube seems to read a bit lower than others. Not so much with other TA Tubes, but with some other different designed measuring tubes.
Like when it comes to the xhp70.2. Dale can measure lights with that emitter at 6000-7500 lumen.
With my L6 I can only get 5300 lumen at turn on. This is with 2 different color temp leds and Liitokala cells drawing 17.6A. Even with Aspire 4300 cells drawing 19.6A, I only see 5500 lumen at turn on.
Keep in mind that Dale does not use a TA lumen tube. He uses a lumen tube design with no diffusers and calibrated by a wide variety of factory lights. (Unless he has recently bought a Maukka calibrated light). I think he always uses turn on numbers and never anything lower.
So I always take his, and everyones, lumen results with a grain of salt. People should not take my lumen numbers as exact, but just in general.
I am really surprised your lumen numbers and Dale’s are really close. Have you compared the output of several factory or modded lights between him and you or just a few?
Besides the C8F, I haven’t compared my numbers with any of his. I guess the diffuser on the TA tube evens out the beam for more accurate result whereas other lumen measuring devices might favor concentrated beams.
I would say the 30T and Sofirn 4000 are pretty much similar in this particular test. I think the emitters and circuit are starting to max out. We might see the 30T gain an advantage again if we swap out the skinny driver bypass wire with an 18ga. I’m guessing here.
If we go back to the skinnier stock led wire test, we see the 30T has a definite advantage with about 0.4A and 200 lumen more. So it is the better cell when it comes to high amp loads and having lower internal resistance. Dale has used a pair of 30T on a triple xhp70.2 light and they drew about 48A-50A. I don’t think the Sofirn 4000 would do as well in this extreme test.
Also, I did this last set of tests pretty fast and the light only cooled down for maybe 2 minutes between each pull. It’s not ideal, but still gives a pretty good idea of the differences.
We also know the Sofirn 4000 is not a 40T. It’s made in a different factory (in China) for the electric vehicle market. It’s definitely a good cell. Maybe it’s a Lishen LR2170SA 4000mah? The Liitokala 4000mah 21700 is a rewrapped Lishen and this cell performs really well also. I don’t know, but they do seem very similar.
Yes, very throwy lights do measure even higher with his tube. I think I found his tube sometimes measures between 8% to maybe 16% higher than mine on average.
He may know a few other tricks to boost output as well. Like using warm batteries fresh off the charger. I’ve heard warming up the batteries gives them some extra oomph. He might replace the lenses with UCP which have lower losses, etc… Dale just gets all the highest output. I can’t compete with him. He’s the king! Lol
