Since the lantern will be symmetrical top/bottom, it makes me think about gcharts’s flippin’ lantern idea.
Hahaha… a lot of my ideas tend to be “flippin’ ideas”
That’s looking great, Don. I assume you’re going to spray the finish?
By the time it is finished there will be a more or less obvious up and down.
Oh hi gchart! I didn’t see you there! Were you there the whole time?
Oh yeah. Spray clear coat but the stain will be applied to the screen frames by laying them in a tray of stain and letting them soak for a few minutes. The main skeleton will have the stain applied by brush. The stain then gets wiped by hand. To try a clear coating with a brush would be frustrating at best. So, yes, spray; even though maybe only 25% sticks to the wood parts.
Coming along nicely, Don.
Progress this afternoon…
This is the bottom plate, viewed from the underside. The penciled outline is for the lipo battery. The 4 ‘pin-pricks’ are centers for the 1/4” drill bit that will set the corners.
To removethe bulk of the material I used a 1” forstner bit in several places. The drill press was set to drill to 1/4” deep.
The edge and non drilled material was removed with a chisel. The workpiece is clamped to the table top.
The lipo battery temporarily installed to test the fitment. This is the bottom plate temporarily installed and viewed from the underside.
Here we have two pieces; the bottom plate and a “cap piece” (the thinner piece). The work is being held upside down… the thinner piece will be facing down when the lantern is assembled. The thinner piece is slightly over 1/4”thick at this point. That is the two color led that indicates what stage the charger is in.
There will be two of these thinner”cap pieces” on the bottom. The smaller will be more or less permanently secured over the led and charger while the larger cap will be the battery cover.
The led is fitted into a recess drilled and chiseled out of the bottom plate.
The charger board is set into another recess. There willbe additional slots cut to route the wiring through.
That is only a 1 amp charger. There will be a small heat sink that protrudes through the bottom cap piece. I have yet to decide which heat sink I’ll be using.
For those not familiar with woodworking this is the router with bit and fence that was used to cut a “rabbet” out of the edge of both the top and bottom plates. What this cut out is for will become readily apparent in a future photo. The fence sets the width of the rabbet to 7/16” and the router base height is set to limit the depth of the cut to just under 1/4”.
The photo is just for illustration. In use the work piece is flipped over with the edge where the rbbet is against the black router fence. And the router and work is flipped over, the work piece clamped to the table with the router moving left to right along the edge.
Hmmm… :question:
Looking good MD. the lantern that is.
A little more work to end the day….
The plan is to have a voltmeter located in that bottom plate edge, alongside the charger indicator led. In the next image I am carving the notch for the meter. It is one of those 3 digit led meters.
The voltmeter is to be wired into the battery with a normally open momentary contact push button switch. Press the button to get a voltage reading. The switch was scavenged from some old board from something that was junk. The red smudge on the wood is my blood. I inadvertently (gently) touched the chisel blade with my finger tip… I keep my chisels sharp.
There is one more cutout to be made. The small board that mounts the micr usb inlet port for the charger will be located on the bottom plate edge around the corner from the led indicator. I hope to get that dome tomorrow.
The bottom plate board is upside down on the bench. The digital meter decimal points are located at the lower edge of the display when viewed correctly.
A little more work tonight….
There needs to be a switch. I have chosen a small Omten 1288 reverse clicky. It will be mounted in one of the stiles, or legs, down low. Pictured below in the leftmost leg you can see the cutout.
That recess was a tad difficult to make. This pine is softer than I am used to and the wood fibers sometimes tear more than slice no matter the sharpness of the chisel. Fortunately pretty much all the chiseled areas will be hidden in the finished product.
Here’s a shot with the 1/4” chisel cutting out the bottom of the slot.
Please pardon my photography for its lack of clear focus. Here’s the stile with the switch recess and a 1/4” hole bored up from the bottom. The two wires to and from the switch will be hidden inside the stile. They will run up inside the stile.
The wires run up and then will exit the stile at or near the bottom plate of the lantern. That is the plate that holds the battery, charger and other sundry parts. I’m shining a flashlight up from the bottom bore hole.
OOOPS!! I made an error and drilled the exit hole in the wrong place. Oh well, the error will be hidden by the bottom plate. I may plug that hole with a length of dowel. Doing so might make t easier to thread the wire into the correct hole.
Next, not too good of a picture…… The switch slot is shown in the stile (the bottom direction is to the left. You can see the correct exit hole for the wires about center in the picture. The bottom plate is visible to the right in the picture. The recess is the battery recess. It is difficult to make out, but in the bottom plate there is a carved out channel for the wires from the switch.
That channel was carved with a carving tool I acquired over the summer. It is a Vee shape, very sharp, with a short handle that makes it easy to hold.
Last for tonight, here is a teaser shot showing the top plate, viewed from above. The 3/4” hole will facilitate the mounting of the LED mcpcb and permit what I believe will be more than adequate cooling. Details to follow; the final few parts should arrive in Mondays post.
Rubber bands still holding things together.
I'm a little bit of a woodworker myself and I must say this is some next level stuff for me. Thanks for the schoolin MtnDon. Great work, I can't wait to see the finished piece.
^ Indeed, excellent woodworking skills.
Next level stuff for sure.
Yep, this is coming along very nicely :+1:
Another classy piece of woody light is forming
Good work
Looking great, MD!
Very Nice :+1:
Wow your on a role mate most of us are just starting lol
Time to replace the rubber bands with dowels and glue…
The brown stuff is liquid “hide” glue. It has a long open or work time compared to more common yellow wood glues. That makes it easier to assemble the multiple pieces. The drawback is mainly that it is not waterproof, so no IP rating on this light, and that it is not quite as strong.
Multiple clamps with a rubber band temporary assist.
Some parts came in today’s post. The square piece of sheet copper I had lying about. I drilled a center 3/8” hole and 4 smaller ones for screws to secure this plate to the underside of the wood upper plate, inside the lantern.
The 2 copper discs were purchased from Bopper metal online; 18 gauge, 3 inch diameter. I drilled the 3/8” center holes.
The brass cylinder is a 1/8” IPS (internal pipe size) all threaded nipple. FYI, it has an OD of 3/8”. It and the three pieces above all came from grandbrass.com. They sell a wide assortment of parts used for electric household lamps. All sorts of bits and pieces for DIY building or repairing of lamps. The copper hoop is drilled and tapped to accept the1/8” IPS nipple. The two small cylindical copper items are 3/4” diamter x 3/4” long. One is drilled completely through and tapped 1/8” IPS while the other is drilled partways and tapped leaving a solid cap-like end.
The mcpcb is from mtnelectronics and has a Nichia 219C 3000K emitter.
A close up of the nipple, spacer and cap……
The mcpcb is glued to the copper cap using arctic alumina thermal adhesive.
Voila! The rubber band is to keep the shoji screen frames from falling out. There will be pins installed later to hold them. Illustrated is the copper heat sinking for the led.
The discs are spaced with 1/8” thick copper washers I found at my local True Value Hardware store. You may note that I have trimmed the length of the upper ends of the 4 corner stiles.
Next we can see the 4 x 4 ” copper plate on the underside of the upper plate. The cap is threaded onto the nipple. Then the 3/4” thick copper spacer is threaded on above the 4 x 4 plate. That spacer is hidden in the hole drilled through the center of the upper wood plate. Then on the outside the round discs are slid on with the 1/8” washer spacers, with the hoop screwed on top. The lantern can be held by the hoop as well as hung.
So from the mcpcb to the copper hoop there is, in effect, a solid copper path for heat distribution and dissapation., clamped together by the brass nipple threaded inside the copper parts.
Wow, that’s neat-o and nifty! :student:
I would have never thought of that, or anything like it. Nice work! How tightly do those copper parts interface with each other? Would it make any improvement if you put some Arctic Alumina between them?
