I have a solarforce L2T host sitting around collecting dust. Even if i get a dropin, it wont fet used much but at least it would be a back up or loaner. What is a good budget/value dropin module?
I see people mentioning flipping a light; is that the same as flipping a house? Or is it some kind of mod?
House flipping is when a real estate investor buys houses and then sells them for a profit. In order for a house to be considered a flip, it must be bought with the intention of quickly reselling. The time between the purchase and the sale often ranges from a couple months up to a year. :question:
“Flipping” would generally imply selling for a profit (else why bother?).
For a light, you could buy a light, not like it too much (artifacts in the beam, green tint, lousy UI, etc.) and just sell it even for a small loss to someone who doesn’t know any better.
Dunno if that qualifies as “flipping”, but it’s almost the same thing, selling it to recoup some bux if you’re not gonna use it.
Yes, you need a multimeter of some sort. Put one probe on the outer edge of the driver which contacts the body and then use the other probe to poke around. Your looking for continuity.
It has to do with the fact that you have to apply more pressure to the blade of a dull knife in order to cut something which can lead to the blade slipping and you accidentally cutting yourself. A really sharp knife requires very little pressure to cut something.
Yes you might ‘touch’ yourself with the blade more often and thus having the possibility to cut yourself.
But a dull knife won’t cut your skin as easy as a sharp knife.
So yes, with a dull knife you increase the possibility that the edge of the blade touches your skin when handling a knife.
But with a sharp knife you increase the possibility to cut yourself when the blade touches you.
I have done a lot of dry walling. Use a utility knife all day everyday. Cutting yourself does involve how much pressure applied but also presence of mind and a little luck. Knock on wood, never cut myself scoring drywall. Bought a knife once. First time I opened it I cut myself. Never liked that knife.
Specifically, I’m looking for common ground spots to wire an e-switch for the meldx driver (I know I can just PM Everett and get the answer). However, it got me thinking that I wanted to figure out a way to do it in general since I have a multimeter. I usually do my wiring for drivers looking at pictures or looking at the labels on drivers but I don’t understand more technical stuff to do more custom driver mods (I can stack chips, change out small parts on drivers, and add resistors for tail lights).
Some friends of mine use to take people for bushcraft and wilderness life training.
As most people used to work with knives do, they went with the usual "“You cut yourself more with a dull knige compared to a sharp knife" and usually started teaching people how to sharpen their knives and tools before using them but after some time they eventually decided to remove the "really sharp" part of the sharpening lessons because it was obvious that even with the best safety precaution people who are not used to work with cutting tools (and even some who are used to ;-) ) will cut themsleves anyway and that cuts made with a not-so-sharp knife were a lot less harmfull.
I have heard “a sharp blade is safer than a dull one”
Perhaps with knives it isn’t true in actual practice.
However pertaining to power tool blades (table saw, circular saw, etc.) it is definitely true. A sharp blade will handle the material feed in a predictable manner. If it is dull it will resist cutting and can lead to kick backs and other dangerous situations.
Sorry for the mini PSA. But remember you are the softest thing in the shop. Both a sharp or dull blade can hurt/injure you faster than you can say “ouch”. Using a sharp blade (in a proper manner) will reduce the chances of an incident.
Here is one of his drivers where you can see the circuit pretty well. We know the edge is ground because the retaining ring clamps here. So anything directly connected to the edge is also a common ground. You can probe these to confirm.
Thanks JasonWW. So the battery ground is separate from the all the other ground spots? Does that mean that you can connect the e-switch negative wire to the ground ring as well?
Most drivers, maybe not all, have positive battery power going straight to the led then the negative side of the led is controlled by the driver to give the correct brightness level. The driver circuits regulate how much current gets to the driver ground/flashlight body.
The negative from the battery usually goes directly into the body of the flashlight.
The MCU, or little computer brain of the flashlight, will have multiple legs or pins on it. A particular pin will be assigned to the e-switch through the software/firmware User Interface. So this pin has a small positive charge on it looking for a ground signal.
The e-switch is just a simple spring-loaded contact. When you push it you get continuity through the two wires. So one switch wire will go to the MCU pin and the other switch wire will go to any type of main body ground (any of the green areas I labeled).
When you press the switch, the small positive signal from the MCU pin connects to ground and the MCU senses this and performs it’s function (turn light on/off, etc…)
So a regular two wire switch does not care which wire is used for ground or the MCU pin.
The exception to this is when you have small LEDs on the switch PCB (lighted switch). These types of switches typically will use a single common wire to act as either a positive or negative for both the switch and the LEDs next to it. So these types of switches are polarity sensitive, meaning the correct wire needs to be going to ground and the other correct wire needs to go to the MCU and led circuits.
I have several accidental cuts on both hands and arms after keeping knives razor sharp. Just carelessly closing one almost reached bone. Nothing like knowing its sharp if needed for protection. It took some experience to learn how to better handle the razor sharp ones. Now my every day carry ones are a little less than razor edge but still very sharp.
I have got a question about a 26mm FET+7135 driver (MTNElectronics). I soldered it myself and put it in a zooming light with XHP70.2. Recently I noticed that soon after turning the flashlight on the led starts to flicker slightly. I am not sure what the reason is and how I can solve it. Is the led or the driver components responsible? Any suggestions are welcome!
