USB power meter/tester thread - YZXStudio, Power-Z, RDTech and more.
404 posts / 0 new
molitar
Last seen: 2 years 3 months ago
Hello can anyone advise me on what would be best tester for my needs?
1. Support DASH for Oneplus Phone (seems not many testers actually support Dash)
2. Test cable resistance for Micro USB and USB C
3. Test voltage and current being supplied to the phone
4. Test chargers to make sure they are actually charging correctly (I assume this is what PD Triggers are?)
5. Bluetooth would be nice as it makes it easier to read when using in a charger and screen is facing in wrong direction to wall
Also what would be a good load tester for this as I know it’s required for proper cable testing.
Thanks for any advice as I had already tried one and it did not properly support Micro USB so I had to send it back.
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 14 hours ago
1. Yes. It’s quite rare for meters to actually support Dash Charge Passthrough
2. Yes.
3. Yes. Most meters can do this.
4. Yes and no for USB PD triggers unless you want to pay hundreds of dollars. There is a USB load which can trigger protocols like QC 2.0 and 3.0, but not PD, which is the HD35.
5. Yes. It’s very nice.
The UM24C supports everything you asked for, and has inputs for micro-USB and USB-C, although you can only see if Dash Charge works via the main USB port:
https://www.aliexpress.com/item/RD-UM24-UM24C-for-APP-USB-2-0-LCD-Display-Voltmeter-ammeter-battery-charge-voltage-current/32845522857.html?spm=2114.search0104.3.11.12cd1853mHfnxf&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_10130_318_10890_10547_319_10546_317_10548_10696_10084_10083_10618_452_10139_10307_532_204_328_10059_10884_323_325_10887_100031_320_321_322_10103,searchweb201603_55,ppcSwitch_0&algo_expid=1036ce4e-3306-4eea-9458-dc6f1f8c9557-1&algo_pvid=1036ce4e-3306-4eea-9458-dc6f1f8c9557&transAbTest=ae803_5
It’s a really nice meter, and as you can see, it does support Dash Charge:
The 3,5A current to the phone proves it works with Dash Charge, along with OP3 phone connected to it of course.
molitar
Thanks for the advice. Watched reviews and it looks easy to navigate unlike the awful navigation of the AVHzY CT-2 I tried. It was a nightmare for me to get to the screens I wanted to get to and all and I will never pick up another single navigation like that system again.
It appears I will need a load tester for cable resistance testing. What model would you recommend?
angerdan
angerdan's picture
Last seen: 1 hour 26 min ago
RD HD35 – it’s the newest model.
https://de.aliexpress.com/item/RD-HD35-Trigger-QC2-0-QC3-0-Electronic-USB-Load-resistor-Discharge-battery-test-adjustable-current/32935083204.html
Here’s a review of the HD35:
http://budgetlightforum.com/comment/1376269
eevblog.com/forum/testgear/trigger-usb-load-hd2535-test/
Other choices:
http://budgetlightforum.com/comment/1359941#comment-1359941
angerdan wrote:
That’s my classification:
wireless data/professional
Electronic load ZKE EBD-USB+
display/advanced
Electronic load 35W 3A with OLed display J7-f
RD Electronic USB load LD25
variable current/multiple use
USB Load 4-13V 3A
YZXStudio Load ZL1000
fixed current/cheap
USB Load resistor 1A
USB Load resistor 1A-2A usb output
USB Load resistor 2.2-4.7-10-20ohm with fan
USB Load resistor Juwei 2.5-5-10ohm
BlueSwordM
There is a choice for the HD35+UM24C in the link above that I provided.
It’s a really useful tester, as it can trigger protocols like QC 3.0, and can draw up to 35W of power if the port can output it.
molitar
Awesome thanks.. Got the tester and load ordered.
BlueSwordM
BTW, guess what I just found:
https://www.fasttech.com/products/1023/10048999/9654020
A QC 3.0 to VOOC/Dash Charge converter.
Meaning we can now have powerbanks with Dash Charge Wink
angerdan
angerdan's picture
Video review about the YZXStudio ZY1280 from dodge_911:
EdT
EdT's picture
There is now also several UM25 clones which are several dollars cheaper than the RuiDeng UM25/25C that are selling for the cost of a UM24, but the AliExpress sellers don’t mention if it is the UT25 or UT25C with Bluetooth options:
DIY More UT25/25C
Also there seems to be another new company selling a unit similar to the UM25 I have never seen before selling on Banggood:
Tese
xnode
Last seen: 1 week 1 day ago
New models out: RD T66 & TC66C
PHeller
Last seen: 17 hours 5 min ago
I recently bought a J7-c “4-way” USB Digital Tester and I can’t seem to find anything that’ll put out more than .7 amps. Even my wall chargers listed as 2.1A won’t do it (to my iPhone 8) nor will a battery saying 2.1A output.
Do I need a special cord for my iphone to draw 2.1A?
dodge_911
dodge_911's picture
Last seen: 2 years 1 month ago
Got the TC66C incoming for a video Smile
:: YouTube ::
http://bit.ly/dodgereviewsyt
:: Discord ::
http://discord.gg/fqJEDyy
:: Join the Discord ::
we need more BLF'ers!
chx
Last seen: 2 years 4 months ago
So if I gather correctly, the ZY1280 can convert QC to PD 2.0? That’d be pretty nice. Any other device with a similar feature but a simpler to use UI? These single button devices are not my favorite.
This would allow reusing all the useless QC ports… the LVSUN LS-PD87-2C / HyperJuice 87W alone would charge both of my laptops and my phone (45W, 30W, 15W, all USB C).
BlueSwordM
See, the problem is that it’s power limited.
QC Type A chargers, which encompass almost all of the chargers on the market, are limited to 18W output, which would only be useful with some low power USB PD devices like the Pixel.
Something like QC 4.0 would work, but the protocol already includes compatibility with USB PD, so that’s not useful.
chx
BlueSwordM
Oh that’s the second QC 3.0 Type B charger that I’ve seen.
Nice.
chx
Excuse me, what…? QC 2.0 had a Class B , QC 3.0 had no thing/ What I am missing?
BlueSwordM
There are type A and type B QC chargers.
Before USB PD was more standardized, there were different types of QC 2.0/3.0 chargers.
Type A on 2.0/3.0 was limited to 18/24W.
Type B on 2.0/3.0 limit was raised to 60/100W.
will34
will34's picture
Last seen: 2 hours 38 min ago
Considering how quickly usb-C PD is getting standard on laptops and phones, I don’t think USB-A would stay relevant for long for high power charging.
PD is getting things straighten up and more and more reliable chargers are coming to the market. Gone are the days where PD power supplies would maintain high voltage output even after cable reconnect which was the #1 reason for device failures. Most chargers now won’t even put out 5V unless communication with receiving device has been enabled and PD direction has been set.
I have a surface pro 6 which I use a Chinese engineered adapter to charge with a PD adapter and USB C cable. It works by “tricking” the power supply to put out 15V. It’s been working great so far.
Many phones have skipped any other type of quick charging technology and do the jump to PD directly, like iPhones. However data transfer protocols over USB-C is still a big ugly mess and would probably take a few years for most devices to standardize.
I have on the way the new zendure Supertank and Superport, both offering 100W PD 3.0. The powerbank its a bit of overkill because at highest output I would drain it completely in less than an hour. And because it was designed for these large loads, it’s not very efficient at lower power drain levels. I plan to review it when it arrives but I don’t really have the tools for a super detailed review. This is why I haven’t bothered to work on a omnicharge ultimate review either, great device btw, extremely versatile.
chx
Well, from what I have seen phones go in every direction but USB C PD. Like, Huawei released a 10V 4A (WTF?) charger last fall — I guess 12V 3A USB C PD wasn’t good enough? There’s all that crap Oppo pulls off… And did Samsung stop their bullshit USB A QC – over USB C charger as they did with the Galaxy Book 12? That was some major standard breaking sorcery I am telling you.
Laptops, yeah, those have standardized on USB C PD very quickly.
EDCba
Last seen: 6 months 4 weeks ago
You need a “good” cable, but most cables can do it. The thing is, 2.1A is the peak, and phones might only use it for initial charging (<50%). I think I’ve only seen the X series go above 2A. My 7+ maxes out at about 1.8A.
xnode
Most quick charge phones charge at 1.7A up to 80-90%. The iPad Pro charges at more than 2 amps until 90% or so.
TheIntruder
Last seen: 3 days 10 hours ago
I’m ready to graduate from the more typical cheap, hard-to-read USB meter I have and onto something better, like an RD UM25 or UM34. Now trying to decide between the two.
I may be missing something, but on balance, I can’t discern why the UM34 would be favorable over the UM25, given the small price difference.
Am I missing something? Are there testing scenarios that escape my mind for which the UM34 is suitable but the UM25 is not?
BlueSwordM
The UM34 supports Dash Charge/VOOC protocols.
TheIntruder
According to RD’s own comparison table, they both do, and the UM25 supports Huawei’s fast charge protocols in addition.
That would be a minor consideration anyway, since I don’t envision a device that utilizes yet another proprietary fast charging standard in my future. I’m fine with USB PD and hope that’s where it will be centered. QC has enough critical mass to continue, and QC4 will have PD compatibility, which will help.
On paper, the 25 is superior in almost every regard, except that it has a USB 2 and not USB 3 port, but I’m not sure how relevant that is when these meters are only taking power measurements.
That’s why I’m puzzled.
BlueSwordM
By my testing, only the UM34 supports Dash Charge/VOOC charging via a USB-A port.
TheIntruder
Thanks. Those are the kind of nuances I seek.
The sales material associated with the early reviews of the UM25 did not indicate that support like the current table does, so I guess it was added to the UM25 in an update at some point.
Do you have the C version? I figure it’s better to have it, than regret not getting it, but the mention of ads in the smartphone app would be a bummer.
BlueSwordM
Yes, I do have the UM25C, UM34C, and recently acquired the TC66C.
Only the UM34C supports Dash Charge due to the additional pins of the USB 3 connector on that meter.
No ads in the smartphone version.
xnode
I’ve already received the RD TC66C, however when I connect it between the charger’s cable and the smartphone, it doesn’t charge:
If I connect the YZXStudio between the wall charger and the cable it charges to 1.7 amps aprox. Where could the problem be?
Does anybody know how to contact RD’s tech support? On AliExpress’s page there isn’t any email available.
RD TC66/TC66C Type-C PD trigger USB-C Voltmeter ammeter voltage 2 way current meter multimeter PD charger battery USB Tester
will34
will34's picture
It seems like the data lines are not receiving any signal. It shows 0V – & + and default 1.5A DCP. The YZX meter detects the load and is forcing the charger to put out a different charging protocol and it starts to charge. There is voltage reading at the end of the cable so I guess the issue is at the phone’s side.
It could be many reasons this happens and without knowing which phone, charger and cable you’re using there’s no way to troubleshoot. Have you tried to manually trigger PD or QC 5V? In theory that should work.
