Some more checks on the BLF D80 with KW CSLNM1-TG led. (Should this led get a dedicated thread btw?)
First, I was not happy with the quite random centering that twisting a 3535 centerpiece provides, so I modded the centerpiece: with a scalpel I cut new corners 45 degrees from the original corners, fixing the 3030-sized led much better. So the flashlight has two centerpieces, one locked around the other, both sanded very thin at the underside for exact focus, now also exact centered.
With the led perfectly centered in 3 dimensions the beam was superb.
Now I measured throw again, first on the almost full 30Q (4.08V): 140 kcd (as I measured before), then let the light run for half an hour (it got hot, I estimate 70 degrees! A biscotti driver has no thermal stepdown, and a 3.9 amp flashlight produces some 15W of heat), the battery was now 3.59 V, so wel over half empty. Measured throw again and still got 125 kcd.
I did the same test with the same battery on a C8 with dedomed XP-G2 S4 2B. Started at 4.08 V with 141 kcd, and with the cell at 3.59 V I measured 90 kcd.
So the low voltage combined with the much needed current regulation of the biscotti driver makes the output and throw of a flashlight with the new Osram led more constant than a light with a direct driven S4 2B.
Plus the current is a bit lower for the same throw.
Thanks for the answer mate Maybe I should thing reversely, then, sanding the driver till the 16mm and the extra by sanding the flashlight hole!! Thanks again!! :+1:
Trying to set the max power of my LD-A4. 10+ clicks enters main menu, OK, 5 fast clicks blinks and power goes down. 1 click enters current adjustment, OK, 1 blink and current goes down again. I click 7 times for 4.75A. I get 15 blinks in response. What’s up?
BTW 30 seconds of idle time was WAY too fast for me, I needed over a minute just to read the relevant section.
LED4POWER, can you tell me tint bin of the LH351D 4000k 90CRI you are selling? It says SPHWHTL3DA0GF4T0Q6, which means tint bin is T0 but there is no T0 tint bin.
