Review request for HKJ [Rechargeable Batteries]
EAIEP 18650 2500mah INR18650-25R discharge lithium batteries electronic cigarette Battery 18650 2500 25R
EAIEP New Original INR18650-33E 3300mAh Li-lon Battery 18650 3.7V Power Rechargeable batteries Max 30A discharge
Finally sources for Klarus 18GT-36UR start showing up.
Pricey beast. :confused:
https://www.ecologeek4u.com/catalogue/lampes-klarus/batterie-klarus-18gt-36ur-18650-3600.html
https://www.ledsupermall.com/klarus-18gt-36ur-3600mah-3-6v-micro-usb-charging-high-discharge-18650-li-ion-battery.html
LoL thanks. I'd have likely chosen the same models. Both 33E and VTC7 seem to use the same cell underneath and I wonder if they could be rewrapped LG MJ1 cells. With respect to the penta-leg top 25Rs, no idea.
That cell is likely to use one of the top OEM available high capacity cells, maybe an LG M36.
Steep pricing. I'd look for alternatives.
Cheers ^:)
I believe there are no alternatives of equivalent quality.
It seems that most of usb-rechargeable 18700 cells use 18650B or similar cells, low discharge and OK capacity.
Klarus has used 18650GA in their cells before in their “3600” cells and I expect that’s what’s inside this one; better at both discharge and capacity than others. Though yes, it may come with a M36 or something similar.
Aside from a better cell this might have a lower-resistance protection circuit as well.
If they aren’t already in the test queue, would you please test the Liitokala 21700 4000mAh 5C discharge
from Aliexpress store 133859 (Edit: Reality is bent*. I have no idea what is real anymore)
https://www.aliexpress.com/item/Liitokala-21700-li-lon-battery-4000-mAh-3-7V-15A-discharge-rate-power-5C-ternary-car/32848013569.html
You can get them at the 11/11 sale price.
*bent
sharply curved or having an angle.
“a piece of bent wire”
synonyms: twisted, crooked, warped, contorted, deformed, misshapen, out of shape, irregular
2.
INFORMAL•BRITISH
dishonest; corrupt.
As real as any other AliExpress seller.
Lishen LS21700SA OEM cell, true 3C rating. Already reviewed in their yellow Lii-40A wrap.
Cheers ^:)
I agree. It is hopeless. There are too many Liitokala stores and websites to know what is what. I edited my post.
Liitokala’s website at http://www.liitokala.com.cn links store 217753. < sigh >
217753 has the yellow 21700s and the black and gold 26650s.
Store No.217753
shenzhen, Guangdong, China
http://www.liitokala.com.cn/Contact.asp
LiitoKala Power Co.,LTD(DongGuan battery factory)
Add: No.38 Changsheng Road, Tiantangwei, Fenggang Town, Dongguan City, Guangdong,523690,China
website: www.liitokala.com.cn
Contact: ZhangNi
TEL: +86 13760394452
Email and Skype : liitokala@126.com
Office hours: (HK Time) Mon - Sat: 9:00am - 22:00pm
The “other” LiitoKala website at http://liito-kala.com/ links store 133859 < big sigh >
This one has the pink 21700s that might also show up in red or blue. They also sell the blue 26650s
Add: 6th Floor,Ling wu industral Road 8 D,Shenzhen Guanlan Junzhibu,Guangdong province,518110,China
Tel: +86-13417331508
Email:emily@liito-kala.com
Office hours: (HK Time) Mon - Fri : 9:00am - 6:00pm
Purchase link:
https://liitokala.aliexpress.com
Just found this fairly priced sale for Panasonic NCR18650BM cells: https://www.192led.com/product/2pcs-3-7v-3200mah-10a-18650-li-ion-rechargeable-battery/
Couldn't find any meaningful review besides this video:
SKV89 mentioned this cell back in January.
Maybe a high quality cell for small electric vehicles.
Cheers :-)
The cells that you propose have the same specifications as this model: Panasonic NCR18650BD 3180mAh - 10A - 18650 - Li-ion - Rechargeable batteries | NKON
What are the differences between these two cell models (both from Panasonic)?
¯\_(ツ)_/¯
There's the “BD” and the “BE”, and now this “BM”. All I can say is the capacity figures that guy in the video gets, even if at 0.25A discharge rate, are rather beefy.
I miss some formal Panasonic cell reviews.
Cheers
You forget the BF and BL too, lol, it’s really unclear their name, it seems to me that the BE and BL are 7-amp cells, the BF meanwhile gives 4.9 amps it seems to me?
My informations about Panasonic cells:
BE - 1. generation of Tesla Model S 85 cells with carbon anode (unconfirmed)
BM - 2. generation of Tesla Model S 85 cells with C-SiO anode (parameters confirmed by direct comparison with Tesla 85 cells (MY2016) and many cycle life tests in my lab)
BD - is BE or BM technlogy based cell without bottom vent (unconfirmed)
BF and BL cells are based on other technology, I think BF and BL both are C-SiO anode succesors produced by Sanyo of an old Panasonic NCR18650B. (unconfirmed)
Do you have information about NCR18650PD, NCR18650PE and NCR18650PF?
Only a guess that it is the evolution/modification of the same 2900mAh technology. I have personal experiences only with PF cell which is an old fashion Panasonic low DCIR cell with great cycle life. (PF has lower DCIR than BM and slightly better cycle life, but it is also slightly more expensive USD/kWh). PD seems to me as PF with bottom vent. I heard about PE for the first time from you.
Here you can find more info and comparsion sheet between PD and PF from Panasonic Panasonic PF NCR18650PF: 2900mAh, 10A – 18650 Battery | BATTERY BRO
Found a source of genuinely wrapped chinese (?) OEM 26650 cells:
26650 - OTHER section @ Lucky Electronics Store AliExpress
Cheers ^:)
This should be better than any 9V battery that you tested. I see no seller, but maybe you could get a sample pair?
The specifications do not look very good. I do not like 3.7V nominal, 4.2V charge voltage and 2.75V cut-off for 9V batteries, they are specifications for a single cell.
Hmm…3.7V? I missed that. Indeed that doesn’t look good.
For clarification purposes, Henrik's latest LiFePO4 cell review -Enerpower 18650 3.2V 1800mAh (Blue)- confirmed a well seated suspicion I had with regards to the brand-name OEM behind the 3x wide leg tops: Heter Battery.
Cheers ^:)
Eeerm… LiFePO4 batteries' state of charge versus charging voltage
Cheers
